查看: 5348|回复: 8
[转贴] CIC compensator
发表于 2011-6-19 03:38:29 | 显示全部楼层 |阅读模式
Simple wideband CIC compensator
Simple wideband CIC compensator.pdf
245.92 KB, 下载次数: 45 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-6-20 16:53:16 | 显示全部楼层
感謝分享~~
发表于 2011-6-20 16:56:38 | 显示全部楼层
Abstract :
A simple design for wideband compensation of a cascaded-integrator-
comb (CIC) decimation filter is presented. The proposed multiplierless
linear  phase  finite  impulse  response  compensator  works  at  a  low
sampling rate and requires only three additions/subtractions. The struc-
ture of the filter is independent of the decimation factor and the number
of the cascaded CIC filters K. However, the proposed filter requires K
or K 2 1 stages, depending on the parameter K of the CIC filter.
发表于 2013-3-4 11:33:58 | 显示全部楼层
想要理解一下怎樣補償
否則程式都寫不出來
謝謝大大
发表于 2013-3-4 11:55:49 | 显示全部楼层
book?
发表于 2013-3-6 00:05:52 | 显示全部楼层
What is it?
发表于 2013-5-17 13:56:09 | 显示全部楼层
ISOP补偿效果不是很好 还有比这好的的吗
发表于 2023-4-1 20:39:16 | 显示全部楼层
kkkkkkk
发表于 2023-4-2 10:25:09 | 显示全部楼层
Thanks!!!
GMT+8, 2025-12-8 02:30 , Processed in 0.020754 second(s), 3 queries , Gzip On, Redis On.
