查看: 8050|回复: 12
[求助] AMS +elaborate+error
发表于 2010-11-23 09:31:57 | 显示全部楼层 |阅读模式
ncelab: *W,CUNOUN: Cannot find any unit under chrt18base.RFNMOS_1P8:spectre in the design libraries.
ncelab: *E,CUCFUN: instance 'NM0' of the unit 'RFNMOS_1P8' is unresolved in 'pllmml.dts:schematic'.
这个问题如何解决啊!
网上有人如下解决:
Because the AMS simulation is different from spectre, so we must use the CIW-Conversion Tool Box-AMS simInfo form Spectre to creat the simulation information of the PDK.
我做了如下尝试:
liberary name:                                              the library name of the PDK:chrt18base
process allcells in the library:                           select
process only cells with the following view:         not
if AMS simulation information exists:
only copy termmapping field:                           not
overwrite ams simulation information:               select
mark a cell as a primitive:
if any of modelmame/model/modelname are found:           select
if the cell has a spectre view:                                          select
但是还是没有成功,本站上也有人提过类似问题,但是没有人说得很详细啊!
有遇到过这个问题又成功解决的吗?
救救我啊!
 楼主| 发表于 2010-11-23 21:10:39 | 显示全部楼层
我尝试过这个方法
CIW也提示已经有了rm1的AMS simInfo
为什么还会出现这个错误?高手指点下啊!
发表于 2010-11-23 21:12:25 | 显示全部楼层
回帖拿分
发表于 2013-2-28 15:42:03 | 显示全部楼层
我遇到了相同问题 用LZ的办法转了以后可以过elab了 cdf里头有了ams信息 谢谢
发表于 2013-6-27 22:14:13 | 显示全部楼层
我用楼主的方法,解决了此问题。谢谢楼主!
发表于 2014-7-2 21:22:27 | 显示全部楼层
我想用一个spice文件替换掉一个schematic模块,也是报出这个类似的错误,不知道怎么解决呢!
发表于 2014-11-24 15:16:52 | 显示全部楼层
直接在list view加了symbol,解决了
发表于 2015-10-9 15:54:11 | 显示全部楼层
谢谢楼主,我用你的办法可以解决问题。
发表于 2016-3-8 22:54:07 | 显示全部楼层
受教了
发表于 2017-3-14 10:03:32 | 显示全部楼层
我按照楼主说的执行了,也按照7楼说的(在list view加了symbol),可是现在还是不行。
ncelab: *E,CUCFUN: instance 'NM5' of the unit 'nchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'NM4' of the unit 'nchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'NM3' of the unit 'nchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'NM2' of the unit 'nchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'NM1' of the unit 'nchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'NM0' of the unit 'nchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'PM7' of the unit 'pchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'PM6' of the unit 'pchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'PM5' of the unit 'pchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'PM4' of the unit 'pchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'PM3' of the unit 'pchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'PM2' of the unit 'pchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'PM1' of the unit 'pchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'PM0' of the unit 'pchrf' is unresolved in 'Divider.CML_to_TSPC:schematic'.
ncelab: *E,CUCFUN: instance 'R0' of the unit 'hrpolyu' is unresolved in 'GSMC_R013S7G0.HRPOLYU:schematic'.
ncelab: *E,CUCFUN: instance 'NM11' of the unit 'nchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'NM10' of the unit 'nchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'NM12' of the unit 'nchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'NM9' of the unit 'nchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'NM8' of the unit 'nchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'NM6' of the unit 'nchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'NM5' of the unit 'nchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'NM4' of the unit 'nchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'NM3' of the unit 'nchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'NM0' of the unit 'nchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'NM2' of the unit 'nchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'NM1' of the unit 'nchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'PM9' of the unit 'pchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'PM11' of the unit 'pchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'PM10' of the unit 'pchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'PM8' of the unit 'pchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'PM7' of the unit 'pchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'PM6' of the unit 'pchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'PM4' of the unit 'pchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'PM5' of the unit 'pchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'PM3' of the unit 'pchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'PM2' of the unit 'pchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'PM1' of the unit 'pchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
ncelab: *E,CUCFUN: instance 'PM0' of the unit 'pchrf' is unresolved in 'Divider.Dual_modulus_2or3_20170313_Ri_symbol:schematic'.
GMT+8, 2025-11-23 03:48 , Processed in 0.023953 second(s), 6 queries , Gzip On, Redis On.
