楼主: strivenbu
cadence最新PR软件soc91(encounter91)加破解(见图)
发表于 2011-1-18 06:56:48 | 显示全部楼层
Thanks a lot. I want it now.
发表于 2011-1-19 10:17:47 | 显示全部楼层
./patch_cadence: Permission denied
not complete ,cant using
 楼主| 发表于 2011-1-20 13:22:29 | 显示全部楼层
回复 44# vanduongbk
"source patch_cadence"
发表于 2011-1-20 21:21:47 | 显示全部楼层
thank very very much
[vanduongbk@localhost working]$ encounter
Checking out Encounter license ...
Encounter_Digital_Impl_Sys_XL 9.1 license checkout succeeded.
You can run 2 CPU jobs with the base license that is currently checked out.
If required, use the setMultiCpuUsage command to enable multi-CPU processing.
This Encounter release has been compiled with OA version 22.04-p052.
 楼主| 发表于 2011-1-21 09:46:14 | 显示全部楼层
回复 47# vanduongbk
不客气,呵呵
发表于 2011-1-24 09:52:28 | 显示全部楼层
感谢,重点是sfk啊
发表于 2011-1-26 12:51:29 | 显示全部楼层
DDDDDDDDDDDDDDDDDDD
发表于 2011-1-26 20:48:04 | 显示全部楼层
DDDDDDDDDDDDDDDDDDDDDDDD
发表于 2011-1-27 10:21:23 | 显示全部楼层
9.1 可以从RTL到GDS2 吗
发表于 2011-1-28 15:45:33 | 显示全部楼层
他们说9.1 比8.1慢是真的吗?
GMT+8, 2025-10-31 04:01 , Processed in 0.019488 second(s), 3 queries , Gzip On, Redis On.
