在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 50974|回复: 106
SOC Encounter 8.1的安装讨论
发表于 2009-10-16 09:56:34 | 显示全部楼层 |阅读模式
在下列链接中下载了Encounter8.1:
http://www.eetop.cn/bbs/viewthre ... ght=Encounter%2B8.1
并按照:
http://www.eetop.cn/bbs/thread-171890-1-2.html
提供的安装方法进行破解,
软件的安装过程很顺利,按照我个人的理解,设定了环境变量,如下:
setenv CDSDIR /eda/cadence/ic5141:/eda/cadence/soc81
setenv CDSHOME /eda/cadence/ic5141:/eda/cadence/soc81
setenv CDS_ROOT /eda/cadence/ic5141:/eda/cadence/soc81
setenv CDS_INST_DIR /eda/cadence/ic5141:/eda/cadence/soc81
setenv CDS_INSTALL_DIR /eda/cadence/ic5141/tools.lnx86/dfII:/eda/cadence/soc81/t
ools.lnx86/dfII
setenv CDS_LIC_FILE 5280@192.168.0.239
setenv CDS_Netlisting_Mode Analog
setenv OA_HOME /eda/cadence/soc81/oa_v22.04.032
set path = ( $path /eda/cadence/ic5141/tools.lnx86/bin )
set path = ( $path /eda/cadence/ic5141/tools.lnx86/dfII/bin )
set path = ( $path /eda/cadence/ic5141/tools.lnx86/plot/bin )
set path = ( $path /eda/cadence/installscape/iscape/bin )
set path = ( $path /eda/cadence/soc81/tools.lnx86/bin )
set path = ( $path /eda/cadence/soc81/tools.lnx86/dfII/bin )
set path = ( $path /eda/cadence/soc81/oa_v22.04.032/bin )
(系统中已经安装了ic5141)
然后source .cshrc
在运行encounter的时候遇到了如下error提示,并停止运行:
/eda/cadence/soc81/tools.lnx86/fe/bin/32bit/encounter: symbol lookup error: /eda/cadence/soc81/tools.lnx86/fe/bin/32bit/encounter: undefined symbol: xmToggleButtonWidgetClass
没有弄明白错误提示的是什么样的symbol没有定义,应该如何定义。
有哪位大侠用这种方法安装成功了的?能不能提供一个license设定方法和正确的环境变量的设置?
对了,在破解的过程中,前面有很多文件被“change”,但是有一些warning和两个error,我看了一下,应该是关系不大的:
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Devel/PPPort/PPPort.bs - skipping
                                error: failed to read+write: sfk - skipping
[001/1/2] celtic/bin/32bit/make_cdb
[001/1/2] tlfUtil/bin/tlfEncrypt
41% lib/libstdc++.so.5.0.3 : 0 chanerror: failed to read+write: lib/SuSE/libXm.so.2 - skipping
[001/1/2] synth/bin/32bit/rcl
[001/1/2] synth/bin/64bit/rcl
warn : cannot read:
18042 files checked, 108 changed.
2 errors, 94 warnings occurred.
从破解更新提示中,可以发现,破解过程做了108次的changed,检查了18042个文件。
先谢了!!
 楼主| 发表于 2009-10-16 11:51:16 | 显示全部楼层
问题已经解决!!!!
发表于 2009-10-16 12:10:02 | 显示全部楼层
怎么解决的 说来听听啊
发表于 2009-10-16 13:20:51 | 显示全部楼层
对,能不能给个安装步骤谢谢
 楼主| 发表于 2009-10-16 13:49:12 | 显示全部楼层
首先我没有说清楚,我是在RHEL5上面安装的,在RHEL4上安装就没有问题。
其次在RHEL5上安装,首先提出的error是:
error while loading shared libraries: libXm.so.3: cannot open shared object file: No such file or directory
然后,我就做了一个link如下:
#ln -s /usr/lib/linXmu.so.6 /usr/lib/libXm.so.3
我的本意是结局这个问题,确实,这个error不报了,但是,就报了一个新的错误,如1#所述。
后来参考了别人对linXm.so.3的理解,实际上是link建立的有问题,删除刚刚建立的link,并重新建立下列link:
#ln -s /usr/X11R6/lib/libXm.so.3 /usr/lib/linXm.so.3
然后重新运行encounter,一切都ok!
发表于 2009-10-16 15:46:52 | 显示全部楼层
终于安装成功了!!!
遇到的两个问题
一个命令是
source .bashrc
另一个是
soc81/share/license/里面要放置license.dat(内容无所谓)
发表于 2009-12-25 11:00:47 | 显示全部楼层
终于安装成功了
发表于 2009-12-30 10:27:01 | 显示全部楼层
你们都太强了.....
发表于 2010-1-9 19:18:23 | 显示全部楼层
安装成功!谢谢!
不过SOC81的OA version 22.04-p032,我之前已经安装好IC610,其用的OA版本较老,当把OA_HOME指向SOC81的OA,则icfb启动不了,有以下错误提示:
/opt/eda/ic610/tools/dfII/bin/32bit/icfb.exe: /opt/eda/ic610/tools/lib/libgcc_s.so.1: version `GCC_4.2.0' not found (required by /usr/lib/libstdc++.so.6)
启动encounter没问题
而把OA_HOME指向以前IC610安装时装的老版本openaccess,则icfb启动没问题,而encounter启动时出错
看样子两个软件不能共存了,有哪位高手帮忙解决一下,谢谢~
发表于 2010-1-11 04:57:58 | 显示全部楼层
9# deleter THANKS
GMT+8, 2024-5-9 01:08 , Processed in 0.027135 second(s), 5 queries , Gzip On, Redis On.
