在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3341|回复: 3
综合OpenSPARC T1, DC就崩溃了。
发表于 2009-10-5 22:40:56 | 显示全部楼层 |阅读模式
这里有人综合OpenSPARC T1么?我用dc2008, dc2009都出现了下面的错误。奇怪的是,我用dc2005就可以综合完毕。
现在新版本的dc这么不稳定么?
下面是dc_shell.log
Opening include file /home/leon/research/tmp/ldpc_env_test/OpenSPARCT1//design/sys/iop/include/sys.h
Presto compilation completed successfully.
Current design is now '/home/leon/research/tmp/ldpc_env_test/OpenSPARCT1/design/sys/iop/ctu/rtl/ctu_clsp_synch_cljl.db:ctu_clsp_synch_cljl'
Loaded 1 design.
Current design is 'ctu_clsp_synch_cljl'.
Loading verilog file '/home/leon/research/tmp/ldpc_env_test/OpenSPARCT1/design/sys/iop/ctu/rtl/ctu_clsp_synch_dldg.v'
Detecting input file type automatically (-rtl or -netlist).
Running DC verilog reader
The tool has just encountered a fatal error:
If you encountered this fatal error when using the most recent
Synopsys release, submit this stack trace and a test case that
reproduces the problem to the Synopsys Support Center by using
Enter A Call at http://solvnet.synopsys.com/EnterACall.
* For information about the latest software releases, go to the Synopsys
  SolvNet Release Library at http://solvnet.synopsys.com/ReleaseLibrary.
* For information about required Operating System patches, go to
  http://www.synopsys.com/support
Release = 'C-2009.06'  Architecture = 'linux'  Program = 'dc_shell'
Exec = '/home/leon/synopsys//syn-C-2009.06/linux/syn/bin/common_shell_exec'
'235898956 235900826 236020427 236255197 206774082 196590121 195804837 193064931 193052043 192783435 164743509 164761680 164839202 164839384 164875370 187146087 187142580 187115518 198390393 194977427 194941076 197594634 195076117 192781256 192781730 198393867 198394281 186452881 186230589 149351927 149355863 149357989 149360765 149470263 151325340 235640911 237442362 237448442 237607506 237628885 237452471 237471962 237448442 237449280 235608528 235621089 235640911 237442362 237448442 237449280 235633501 235640174 147974476 147974621 147993151 147995389 147996684 134623051 134609034 -1211840651'
 楼主| 发表于 2009-10-5 23:43:25 | 显示全部楼层
有人综合其他设计,有遇到类似的情况么?
发表于 2010-4-13 12:35:43 | 显示全部楼层
感兴趣,它自带的文档里面对工具版本有说明吗?
  还有一种可能是DC没装好吧,你另外找个例子跑跑试试
贴一下你机器和系统配置吧
发表于 2015-12-9 18:23:31 | 显示全部楼层
有时候是这样的 换个版本试试
GMT+8, 2024-4-27 01:24 , Processed in 0.026661 second(s), 9 queries , Gzip On, Redis On.
