在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 13116|回复: 64
[Wiley-IEEE Press]《Digital Transmission Engineering Second Edition》
发表于 2008-11-1 14:17:58 | 显示全部楼层 |阅读模式
一本好書
可視為初階的Digital Communication書
對MLSE有清析的推導, 此外也說明了幾種重要
的wireless channel特性及之下的performance
建議想釐清基本觀念的人看
【原书作者】:John B. Anderson
【ISBN 】:ISBN-13 978-0-471-69464-9
                 ISBN-10 0-471-69464-9
【页数 】:468
【出版社】 :A JOHN WILEY & SONS, INC., PUBLICATION
【出版日期】:2005
【文件格式】:pdf
目录:
1 Introduction to Digital Transmission
1.1 Some History and Some Themes 2
1.2 Why Digital? 6
1.3 Contents of the Book 7
1.4 The Computer Programs 11
References 12
2 Baseband Pulse Transmission
2.1 Introduction 13
2.2 Properties of Pulse Trains 14
2.2.1 Pulse Formatting 14
2.2.2 Overlapping Pulses: The Nyquist Criterion 17
2.2.3 Orthogonal Pulses 25
2.3 Pulse Train Spectra 29
2.3.1 General Spectrum Problem 30
2.3.2 Linear Modulation Spectra 31
2.3.3 Spectral and Power Out-of-Band Plots 32
2.4 Transmission Impairments 35
2.4.1 Intersymbol Interference 35
2.4.2 Eye Patterns 36
2.4.3 Channel Filter Effects 39
2.5 Signal Space Analysis 43
2.5.1 Maximum-Likelihood and MAP Receivers 43
2.5.2 Definition of Signal Space 45
2.5.3 Signal Space for White Gaussian Noise 50
2.5.4 Decision Regions and Signal Constellations 53
2.6 Maximum Likelihood Receivers 56
2.6.1 ML Receiver Error Calculations 56
2.6.2 ML Receiver Implementations 63
Problems 74
References 77
3 Carrier Transmission
3.1 Modulation with a Carrier 79
3.2 Phase-Shift Keying 81
3.2.1 Binary PSK 82
3.2.2 BPSK Spectra 85
3.2.3 Quaternary PSK 87
3.2.4 Envelopes and I/Q Plots 93
3.3 Quadrature Transmitter and Receiver 93
3.4 Generalizations of Phase-Shift Keying 97
3.4.1 General PSK 97
3.4.2 Offset QPSK 100
3.4.3 Differential PSK 102
3.5 Quadrature Amplitude Modulation 105
3.5.1 QAM Spectra and Error Performance 107
3.5.2 Partial-Response Signaling 115
3.6 Frequency-Shift Keying 119
3.6.1 Basic FSK 120
3.6.2 FSK Spectra 123
3.6.3 FSK Examples 126
3.6.4 CPM Coded Modulation 129
3.7 FSK Detectors 131
3.7.1 FSK Maximum-Likelihood Detection 131
3.7.2 Coherency in FSK Detection 132
3.7.3 Digital FM View 133
3.8 Transmission Impairments 135
3.8.1 Filtering 137
3.8.2 Other Signal Impairments 142
Problems 144
References 148
Appendix 3A Baseband Representation of Bandpass Filters 149
Appendix 3B Bandpass Noise 153
Appendix 3C Discrete-Time Implementation and Simulation 157
4 Synchronization
4.1 Some Synchronizer Principles 161
4.2 Phase Synchronizer Circuits 164
4.2.1 Raised-Power Loops 165
4.2.2 Remodulation and Costas Loops 168
4.2.3 S-Curves and Lock Points 169
4.2.4 Effects of Error in the Phase Reference 171
4.3 The Analog Phase-Lock Loop 174
4.3.1 PLL as a Control System 174
4.3.2 Phase Transient Responses 177
4.3.3 Responses During Acquisition 186
4.4 PLL Responses to Noise 188
4.4.1 Gaussian Channel Noise 188
4.4.2 Phase Noise 192
4.4.3 Data Noise 194
4.5 Design Examples 195
4.6 Digital Phase-Lock Loops 203
4.6.1 Review of z-Transforms 204
4.6.2 Simple Conversion of Analog PLLs 205
4.6.3 Second-Order Discrete PLLs Based on an Accumulator 210
4.7 Symbol Timing Recovery 214
4.7.1 Early–Late Gate Synchronizer 214
4.7.2 Timing Based on Zero Crossings 216
4.8 Frame Synchronization and Networking 219
4.8.1 Sequences and Their Boundaries 220
4.8.2 Finding a Frame Marker 227
4.8.3 Hierarchical Networks and Their Synchronization 231
Problems 236
References 241
Appendix 4A: Data Noise in QPSK 242
5 Channels
5.1 Guided Channels 248
5.1.1 Characteristics of Wires and Cables 249
5.1.2 The Telephone Channel 253
5.1.3 Glass Fibers 256
5.2 The Simple Radio Link 258
5.2.1 Antennas and Propagation 258
5.2.2 Receiver Noise 261
5.2.3 Detailed Link Budgets 270
5.3 Terrestrial Radio Channels 276
5.3.1 Reflection, Refraction, Diffraction, and Absorption 276
5.3.2 Medium-Wave and Shortwave Propagation 282
5.3.3 Statistical View of Terrestrial Channels 283
5.4 Fading Channels 285
5.4.1 Basic Ideas of Fading 285
5.4.2 The Rayleigh Fading Model 288
5.4.3 Time Dispersion in Fading Channels 295
5.4.4 Long-Term Model Variation: Shadowing 299
Problems 302
References 307
Appendix 5A: Simulation of Fading 309
Appendix 5B: Stochastic Process Analysis of Fading 311
6 Error Correction Coding
6.1 Channel Models and Information Theory 316
6.1.1 Basic Channel Models 316
6.1.2 Information Theory in Brief 318
6.2 Basics of Parity-Check Codes 323
6.2.1 Maximum Likelihood Reception with Block Codes 325
and the BSC
6.2.2 Parity-Check Code Definition; Syndrome Decoding 326
6.2.3 Cyclic Codes 330
6.3 Code Performance 331
6.3.1 Decoder Error Probability 331
6.3.2 Coding Gain 333
6.3.3 Behavior of the Minimum Distance 335
6.4 Trellis Coding 339
6.4.1 Convolutional Codes 339
6.4.2 Code Trellises 344
6.4.3 Some Other Trellis Codes 347
6.5 Trellis Decoders 352
6.5.1 The Viterbi Algorithm 354
6.5.2 Trellis Error Events 356
Problems 359
References 361
7 Advanced Topics
7.1 Discrete-Time Channel Models 363
7.1.1 Receiver Models 365
7.1.2 Models Derived from MF and PAM Receivers 373
7.2 Equalizers I: The Linear Equalizer 378
7.2.1 Zero-Forcing Linear Equalizers 379
7.2.2 Least-Square Error Linear Equalizers 385
7.3 Equalizers II 390
7.3.1 Nonlinear Equalizers 390
7.3.2 Fractional Spacing and Adaptivity 395
7.4 Modulations Over the Fading Channel 398
7.5 Noncoherent Demodulation 404
7.6 Spread Spectrum 408
7.6.1 Direct Sequence Spread Spectrum 410
7.6.2 Pseudonoise Sequences in Spread Spectrum 416
7.6.3 Frequency-Hop Spread Spectrum 419
Digital Transmission Engineering.rar
2.64 MB, 下载次数: 395 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-11-7 13:54:43 | 显示全部楼层
严重支持,好
发表于 2008-11-17 10:46:52 | 显示全部楼层
坚决支持!!!!!!!!!!!!!非常感谢!!!!!!!!!!!
发表于 2008-11-17 10:48:12 | 显示全部楼层
thanks for your information..........................
thanks..........................................................
发表于 2008-11-19 14:13:32 | 显示全部楼层
灰常灰常好!支持!
发表于 2008-11-20 11:37:48 | 显示全部楼层
thanks
发表于 2008-11-20 11:55:20 | 显示全部楼层
thanks
发表于 2008-11-22 07:07:58 | 显示全部楼层
xie xie
发表于 2008-12-30 18:36:44 | 显示全部楼层
感謝!!
发表于 2009-1-3 11:30:20 | 显示全部楼层
good book.
GMT+8, 2025-7-13 14:48 , Processed in 0.029927 second(s), 9 queries , Gzip On, MemCached On.
