在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 5546|回复: 5
哪里有mips的systemc model?
发表于 2008-3-30 12:50:33 | 显示全部楼层 |阅读模式
如题!!!!
发表于 2008-4-12 12:21:18 | 显示全部楼层
http://www.es.ele.tue.nl/mininoc/ Introduction
This is the website for the MiniNoC, a Network-on-Chip (NOC) based multi-processor System-on-Chip (SoC) with 4 simplified MIPS processors. Two applications are available to download and run on this system as well as the tool suite required to get a working implementation of these items on a Xilinx FPGA that is on the BenOne development board of Nallatech. The website describes the NoC-based MPSoC (hardware) and the applications (software) design flows as well as the tools used in the process. The NOC design flow describes the steps needed to convert the SystemC/C++ sources of the MiniNoC into a hardware simulator or into an FPGA implementation. The application design flow describes the steps needed to compile and run the example applications gossip and a JPEG decoder on the hardware simulator or on the actual MiniNoC in FPGA.
发表于 2009-12-22 12:15:12 | 显示全部楼层
thank you
发表于 2010-3-31 10:39:42 | 显示全部楼层
绝对牛逼的帖子!
发表于 2010-8-24 10:52:11 | 显示全部楼层
非常有價值,感恩!
发表于 2010-9-8 15:26:40 | 显示全部楼层
good book
GMT+8, 2024-4-26 11:24 , Processed in 0.025653 second(s), 8 queries , Gzip On, Redis On.
