查看: 9175|回复: 12
[求助] 请问VCS+HSIM混合仿真怎么提速,实在跑的太慢了
发表于 2019-2-11 16:01:33 | 显示全部楼层 |阅读模式
发表于 2019-2-11 21:20:05 | 显示全部楼层
看仿真精度,用VCS+XA试,主要是并行和计算精度
 楼主| 发表于 2019-2-12 15:38:59 | 显示全部楼层
回复 2# dcircuit
   您好,我主要是跑SRAM的bist的仿真,SRAM有64kb,XA具体是指哪款软件?
发表于 2019-2-12 15:41:47 | 显示全部楼层
回复 3# 黑崎一护776
XA 就是customer sim, 也是synopsys 的工具. 速度比hsim快很多, 精度似乎也不差.
发表于 2019-2-12 17:31:59 | 显示全部楼层
针对不同的block设置合适的精度
 楼主| 发表于 2019-2-12 17:44:47 | 显示全部楼层
回复 5# 09微电子小贝
   就只有一个SRAM的BIST测试,我SRAM大小压不下去,测试算法也不能压下去
 楼主| 发表于 2019-2-12 17:45:33 | 显示全部楼层
回复 4# haichao89
   学校的服务器没有这软件。。。。。。。唉
发表于 2019-2-12 19:57:37 | 显示全部楼层
sram用finesim比较好
发表于 2019-2-13 22:37:55 | 显示全部楼层
回复 7# 黑崎一护776
装一个上去
FineSim® is a multi-core accelerated circuit simulator well-suited for simulation of large, complex analog circuits, as well as DRAM/SRAM/Flash memory design. The CustomSim™ FastSPICE simulator delivers superior transistor-level verification performance and capacity for various classes of design, including custom digital, memory, and analog/mixed-signal circuits. HSPICE, FineSim, and CustomSim support a comprehensive set of reliability and variability analysis features, with the cornerstones being high-performance engines and common modeling and analyses technologies. For full-chip mixed-signal verification, Synopsys’ VCS® AMS mixed-signal verification solution combines the industry’s fastest RTL and circuit simulation engines (VCS, CustomSim or FineSim) to deliver the best performance and capacity for mixed-signal SoC regression testing for advanced functional and low-power verification.
发表于 2020-6-13 09:47:51 | 显示全部楼层
多谢高手指点
GMT+8, 2025-10-24 20:19 , Processed in 0.016520 second(s), 3 queries , Gzip On, Redis On.
