查看: 8129|回复: 11
[求助] contact/via数+1/-1的skill程序
发表于 2018-5-25 13:35:55 | 显示全部楼层 |阅读模式
悬赏150资产已解决
virtuoso作图时,大片区域内可以auto打孔(contact/via),有哪位大神有skill程序可以通过快捷键使得contact/via数+1/-1
最佳答案
查看完整内容
有问题的话 可以私信我 hiSetBindKey("Layout" "AltUp" "CtAsUp()") hiSetBindKey("Layout" "AltDown" "CtAsDown()") hiSetBindKey("Layout" "AltRight" "CtAsRight()") hiSetBindKey("Layout" "AltLeft" "CtAsLeft()") procedure(CtAsUp() prog(() CtAsMain("1") ); ); procedure(CtAsDown() prog(() CtAsMain("2") ); ); procedure(CtAsRight() prog(() CtAsMain("3") ); ); procedure(CtAsLeft() prog(() CtAsMain("4") ); ); p ...
发表于 2018-5-25 13:35:56 | 显示全部楼层
有问题的话 可以私信我
hiSetBindKey("Layout" "Alt<Key>Up" "CtAsUp()")
hiSetBindKey("Layout" "Alt<Key>Down" "CtAsDown()")
hiSetBindKey("Layout" "Alt<Key>Right" "CtAsRight()")
hiSetBindKey("Layout" "Alt<Key>Left" "CtAsLeft()")
procedure(CtAsUp()
prog(()
CtAsMain("1")
prog(()
CtAsMain("2")
prog(()
CtAsMain("3")
prog(()
CtAsMain("4")
procedure(CtAsMain(mode)
prog((cv curwin groupId tfId obj objType mode1 objType obj_origin px1 py1 techFile rota conviaName contVia orParams refParams cutRows cutColumns rows_n cols_n select_new contViaParams1 contViaParams)
mode1=mode
cv=geGetEditCellView()
curwin=hiGetCurrentWindow()
groupId=leGetEditFigGroup(curwin)
tfId = techGetTechFile(cv)
obj=geGetSelectedSet()
objType=car(obj~>objType)
cond(
((mode1=="1") detR=1 detC=0)
((mode1=="2") detR=-1 detC=0)
((mode1=="3") detR=0 detC=1)
((mode1=="4") detR=0 detC=-1)
if(objType!="stdVia"
then
warn("obj need to be stdvia")
else
obj_origin=car(obj~>origin)
px1=xCoord(obj_origin)
py1=yCoord(obj_origin)
techFile = techGetTechFile(cv)
rota=car(obj~>orient)
conViaName=car(obj~>viaHeader~>viaDefName)
contVia=techFindViaDefByName(tfId conViaName)
orParams=car(obj~>viaHeader~>overrideParams)
refParams=setof(i orParams car(i) != "cutRows" && car(i) != "cutColumns" )
;i=nth(0 orParams)
cutRows=1
cutColumns=1
foreach(i orParams
if(car(i)=="cutRows"
then
cutRows=car(cdr(i))
);eng_id
if(car(i)=="cutColumns"
then
cutColumns=car(cdr(i))
);eng_id
);end_foreach
rows_n=cutRows+detR
cols_n=cutColumns+detC
if(rows_n<=0
rows_n=1
if(cols_n<=0
cols_n=1
contViaParams1=list(list("cutRows" rows_n) list("cutColumns" cols_n))
contViaParams=append(refParams contViaParams1)
select_new=dbCreateVia(cv contVia px1:py1 rota contViaParams)
if(groupId!=nil
then
dbAddFigToFigGroup(groupId select_new)
);end-if
    dbDeleteObject(car(obj))
    geSelectFig(select_new)
);warn-if
);end-prog
);end-procedure
回复
发表于 2018-5-25 17:47:37 | 显示全部楼层
xn=fix((W-d*2+s)/(s+len));d为AA enclose CT的长度,s为CTs 间距,len为CT边长,W、L为AA宽长
yn=fix((L-d*2+s)/(s+len))
CT=dbCreateViaShapeArray(11个arguments)
起始点横、纵坐标可以这样写:(W-xn*len-s*(xn-1))/2+AA横坐标   (L-yn*len-s*(yn-1))/2+AA纵坐标
附上dbCreateViaShapeArray的用法
回复
 楼主| 发表于 2018-5-28 14:44:28 | 显示全部楼层
回复 2# 艹天道
   我的意思是对已经存在的contact/via,如何通过skill来增加或减少
contact/via的个数
回复
发表于 2018-6-21 22:09:24 | 显示全部楼层
*Error* eval: undefined function - leGetEditFigGroup
回复
发表于 2018-6-22 17:29:31 | 显示全部楼层
回复 5# maomao198477
   你用的版本有点低~~  你把group的所有相关函数都干掉吧~~应该也可以
回复
发表于 2018-6-22 17:33:00 | 显示全部楼层
如果是ic5141 或者613 之类的较低版本,可以用这个
procedure(CtAsUp()
prog(()
CtAsMain("1")
prog(()
CtAsMain("2")
prog(()
CtAsMain("3")
prog(()
CtAsMain("4")
mode1=mode
cond(
        then
        else
        ;i=nth(0 orParams)
        cutRows=1
        cutColumns=1
foreach(i orParams
        then
        cutRows=car(cdr(i))
        );eng_id
        then
        );eng_id
        );end_foreach
        rows_n=cutRows+detR
        if(rows_n<=0
                rows_n=1
        if(cols_n<=0
                cols_n=1
        );warn-if
);end-prog
);end-procedure
回复
发表于 2018-6-23 23:00:51 | 显示全部楼层
*WARNING* obj need to be stdvia
回复
发表于 2018-6-24 20:23:03 | 显示全部楼层
回复 8# maomao198477
   东西是我再617下用的 615 616 都还可以用的。我没有5141环境调试~~ 简单看看写法吧
回复
 楼主| 发表于 2018-6-25 12:41:26 | 显示全部楼层
回复 4# 3512596
    谢谢,试了一下,可以用的
回复
GMT+8, 2025-9-13 11:49 , Processed in 0.030524 second(s), 5 queries , Gzip On, Redis On.
