查看: 3816|回复: 4
dracula问题求助
发表于 2017-11-7 16:15:54 | 显示全部楼层 |阅读模式
最近公司有个项目,要用dracula做验证,但是做lvs的时候碰到下面的问题,在运行jxrun.com后会报一个错误如下:
***/dracula/bin/64bit/LVSCHM: symbol lookup error: ***/dracula/bin/64bit/LVSCHM: undefined symbol: dbm_open
其中***是dracula的路径,我省略了。
在网上找遍了,没找到解决方法,请求支援。
发表于 2017-11-23 11:46:01 | 显示全部楼层
FROM
    https://community.cadence.com/ca ... elp-for-dracula-lvs
                                Offline        Andrew Beckett        over 4 years ago
I believe this function comes from the "gdbm" shared library - running "ldd" on the LVSCHM executable suggests to me that it's from there:
         linux-gate.so.1 =>  (0xf7782000)
        libgfortran.so.3 => /usr/lib/libgfortran.so.3 (0xf76ab000)
        libm.so.6 => /lib/libm.so.6 (0x00522000)
        libnsl.so.1 => /lib/libnsl.so.1 (0x0067a000)
        libdl.so.2 => /lib/libdl.so.2 (0x0051b000)
        libgdbm.so.2 => /usr/lib/libgdbm.so.2 (0xf76a3000)
        libtermcap.so.2 => /lib/libtermcap.so.2 (0xf769f000)
        libelf.so.1 => /usr/lib/libelf.so.1 (0xf7687000)
        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x0056b000)
        libc.so.6 => /lib/libc.so.6 (0x00389000)
        /lib/ld-linux.so.2 (0x00367000)
My guess is that your OS has an outdated or incorrect version of libgdbm.so.2 (I've seen one report saying that this doesn't work on SuSE, but I've got nothing to back that up). I see from your hostname that you are probably using Ubuntu, which is an unsupported operating system - so maybe that's the root cause?
Regards,
Andrew.
libgdbm.so.2 error  ?
 楼主| 发表于 2018-1-22 16:01:04 | 显示全部楼层
回复 2# andy2000a
   太感谢了!
发表于 2021-3-6 15:42:51 | 显示全部楼层
请问下怎么解决的?
发表于 2021-3-15 14:06:25 | 显示全部楼层
请问下怎么解决的>>
GMT+8, 2025-9-22 16:10 , Processed in 0.014525 second(s), 3 queries , Gzip On, Redis On.
