查看: 11924|回复: 10
Assura04.14.001-616 在CentOS7 x64 里的破解问题
发表于 2014-12-4 07:47:10 | 显示全部楼层 |阅读模式
安装了上述软件及ic616等,virtuoso 运行没问题,但当执行assura后,弹出一框说:The Assura drc run "xxx" failed! 记录文件显示没有效license:
Operating Mode: Legacy Mode is Off
Checking out license for Assura_DRC
*WARNING* Failed to obtain license for Assura_DRC
No Assura license available.
Checking out license for Phys_Ver_Sys_DRC_XL
*WARNING* Failed to obtain license for Phys_Ver_Sys_DRC_XL
Checking out license for Phys_Ver_Sys_LVS_XL
*WARNING* Failed to obtain license for Phys_Ver_Sys_LVS_XL
ERROR (AVMAIN-10003): No Assura or PVS license available. Exiting. Check license server settings.
我是用min4max老大帖子http://bbs.eetop.cn/thread-452284-1-1.html里提到的破解与license来做的,里面明明有assura的license:
FEATURE Assura_DRC cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=E1F63D122144E948
FEATURE Assura_DV_design_rule_checker cdslmd 1000.000 permanent uncounted HOSTID=ANY \
    SIGN2=DBE9E839D7AC0F77
FEATURE Assura_DV_LVS_checker cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=308BF87A2258B320
FEATURE Assura_DV_parasitic_extractor cdslmd 1000.000 permanent uncounted HOSTID=ANY \
    SIGN2=B2D969426F4F5915
FEATURE Assura_LVS cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=F1BA31FEE158E544
FEATURE Assura_MP cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=0A348E7EFDC057B6
FEATURE Assura_OPC cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=E4F12814134DEE5D
FEATURE Assura_RCX cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=B1D8650802E0AF85
FEATURE Assura_RCX_Adv_Process cdslmd 1000.000 permanent uncounted HOSTID=ANY \
    SIGN2=9836E4FB14279113
FEATURE Assura_RCX-FS cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=5D982E040C94A60D
FEATURE Assura_RCX-HF cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=68B12E17188EB10D
FEATURE Assura_RCX-MP cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=5EAA2E052889A70D
FEATURE Assura_RCX-PL cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=62A32E012886AB0D
FEATURE Assura_SI cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=D4538B83319F38D7
FEATURE Assura_SiMC cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=25632A99E842B807
FEATURE Assura_SI-TL cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=7B5AAF2FD41F7985
FEATURE Assura_SiVL cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=228012870166A3FF
FEATURE Assura_UI cdslmd 1000.000 permanent uncounted HOSTID=ANY SIGN2=D6518D832DA13AD5
诸位大侠能否给看看问题是咋回事儿?
多谢了!
 楼主| 发表于 2014-12-4 13:03:00 | 显示全部楼层
这么快就给深埋了:)
发表于 2014-12-4 21:26:25 | 显示全部楼层
    我那个帖子中的license.dat是从网上弄到的,我没有对其中每一个FEATURE都进行过核对,所以不能保证每一个FEATURE都是正确无误的,并且那个license.dat还缺少大部分最新版工具所发布的新FEATUREs。因此我前几天发了另一篇专门讨论license问题,见:http://bbs.eetop.cn/thread-470308-1-1.html
要确保相关工具的license strings (license keys)在FEATURE行中表达无误,最好的方法是去每个工具目录下的子目录/doc中查看User Guide或类似的文档(PDF文档),从中找出正确的licens strings,然后在那个license.dat生成工具的输入文件cadence.txt加入这些新FEATURE(需要按照我的那片正文中给出的FEATURE格式),再在Windows平台上运行生成license.dat
 楼主| 发表于 2014-12-4 23:44:04 | 显示全部楼层
回复 3# min4max
非常感谢回复!好,我有时间研究研究。
发表于 2015-3-14 01:12:06 | 显示全部楼层
where can we find this version: ASSURA04.14.001  ?  Somewhere on baidu server ?
Thanks
发表于 2015-10-15 22:37:29 | 显示全部楼层
回复 3# min4max
   好像用了您的方法还是提示没有license
发表于 2017-4-26 00:44:53 | 显示全部楼层
楼主解决了吗? 相同问题 OS 7
发表于 2017-6-18 17:14:56 | 显示全部楼层
要加HOSTID吧?
发表于 2018-11-24 10:05:01 | 显示全部楼层
学习中。。。。
发表于 2021-9-1 21:27:22 | 显示全部楼层
非常
GMT+8, 2025-12-23 05:15 , Processed in 0.033786 second(s), 6 queries , Gzip On, Redis On.
