查看: 2859|回复: 7
[求助] 本人新手,在自学ICC2010 lab新建库 出现以下警告,请问怎么回事?谢谢!
发表于 2014-7-16 21:30:45 | 显示全部楼层 |阅读模式
本人新手,在自学ICC2010 lab新建库 出现以下警告,请问怎么回事,如何解决?谢谢!
Warning: Layer 'METAL' has rounded fat table thresholds '(0, 0.3, 1.76, 10)'. (line 456) (TFCHK-055)
Warning: Layer 'METAL' has a pitch 0.41 that does not match the recommended wire-to-via pitch 0.66. (TFCHK-049)
Warning: Layer 'METAL3' has a pitch 0.41 that does not match the doubled pitch 0.82 or tripled pitch 1.23. (TFCHK-050)
Warning: Layer 'METAL4' has a pitch 0.515 that does not match the doubled pitch 0.82 or tripled pitch 1.23. (TFCHK-050)
Warning: Layer 'METAL5' has a pitch 0.81 that does not match the doubled pitch 0.82 or tripled pitch 1.23. (TFCHK-050)
Warning: Layer 'METAL6' has a pitch 0.97 that does not match the doubled pitch 1.03 or tripled pitch 1.545. (TFCHK-050)
Warning: CapModel sections are missing. Capacitance models should be loaded with a TLU+ file later. (TFCHK-084)
 楼主| 发表于 2014-7-17 08:33:59 | 显示全部楼层
新手 求大神帮忙解答
发表于 2014-7-17 08:55:33 | 显示全部楼层
你可以man一下,tf 里面的,只是 warning 而已,可以不管
 楼主| 发表于 2014-7-17 09:38:38 | 显示全部楼层
回复 3# zero_0
谢谢回复,那是不是在ICC操作中所产生的所有 warning 都可以不管?
发表于 2014-7-17 09:51:47 | 显示全部楼层
回复 4# iclayoutcn
    不是
 楼主| 发表于 2014-7-17 09:58:14 | 显示全部楼层
回复 5# zero_0
那就是说每个warning 还是得看下,分析下原因才行?
发表于 2014-7-19 17:07:16 | 显示全部楼层
這些只是提醒你告知有線和線之間或線和via之間的drc  rule的問題,
但是還是要去看是否嚴重,或再作幾次global route可解決,
如不行那只有一個辦法,用手工去壁開pitch rule
 楼主| 发表于 2014-7-21 11:43:18 | 显示全部楼层
回复 7# tlhuang168
  非常感谢你的详细解释
GMT+8, 2025-7-7 14:33 , Processed in 0.021264 second(s), 9 queries , Gzip On, MemCached On.
