查看: 2854|回复: 6
[招聘] 美光半导体技术-SSD ASIC Verification
发表于 2013-12-17 11:26:11 | 显示全部楼层 |阅读模式
Dear All, Micron is now looking for talents who are familiar with UVM/OVM/VMM verification method.
Those who are interested in this position, please kindly contact Ella Wang via ellawang@micron.com
P.S. this position will be locate in Shanghai
Here I attached the JD below for your reference.
Job Description
As an SSD ASIC Verification Engineer at Micron, you will part of a team that develops leading edge System On Chip solutions for Micron.  You will be part of a team that is driving innovation into next generation solid state memory controllers and the resulting storage and server products.
Responsibility:
Defining, designing & verifying, modeling, and implementing of controllers for Micron's SSD efforts.
Developing design specifications, conducting hardware architecture & design tradeoffs, mapping NAND management algorithms into hardware implementations, performing logic design, implementation and block verification.
Working in close collaboration as part of a team that includes other Digital Designers, Verification and Firmware Engineers, System and Algorithm Engineers, Physical Design Engineers and FPGA Engineers.
Qualification:
Proven track record of contributing to the development of ASIC based products by assisting with the overall concept, design and optimization of digital and analog ASIC circuits.
Good background in Verilog/SystemVerilog and verification methodology; knowledge of C or other HVL would be a plus
Proficiency in Verification techniques, at both a block and system level, to work with the verification engineering team to support excellence in design principles and practice
Knowledge and experience performing timing analysis/debug and implementing design improvements.
Experience in developing block and chip level test benches, test plan creation.
Experience with OVM/UVM, object oriented design principles, Mentor Questasim SV, Power Aware, SVA assertion.
The ability to work with firmware teams in developing co-simulation environments and system models
Good communication skills, with the ability to convey complex technical concepts to other design peers in verbal and written form.
A high level of self-motivation and the ability to be a self-starter.
Good written, verbal and presentation communication skills.
BS in EE/CS with 3+ years work experience or MS in EE/CS with 1+ year work experience
发表于 2013-12-17 22:31:05 | 显示全部楼层
where
 楼主| 发表于 2013-12-18 16:05:45 | 显示全部楼层
回复 2# duanli112
    base 在上海
发表于 2013-12-18 16:07:05 | 显示全部楼层
你们是不是asic deisign的职位不要人了?
 楼主| 发表于 2013-12-18 18:27:24 | 显示全部楼层
回复 4# jooz
    目前ASIC design的职位已有较属意的人在谈
 楼主| 发表于 2013-12-25 10:48:54 | 显示全部楼层
欢迎投递简历给我
发表于 2018-3-26 17:48:28 | 显示全部楼层
回复 1# ellawang
     thanks for sharing
GMT+8, 2025-10-15 07:17 , Processed in 0.045860 second(s), 4 queries , Gzip On, Redis On.
