查看: 74228|回复: 248
ADS2013.06 已经可以完整使用了
发表于 2013-10-5 14:40:44 | 显示全部楼层 |阅读模式
Agilent ADS 2013.06 License file
1- Replace the files with original ones:
            I)-ADS root folder
            II)- C:\Program Files\Agilent\EEsof_License_Tools\bin
2-Restarting is needed if below procedures did not work.
3- Copy the license file to somewhere and change the "FFFFFFFFFFFFFFFF" inside it with your favorite Mac Address.
If below procedures did not work, just disable all of your network adapters except the one that you are using its address inside the license file.
4- No need to define ADS_LICENSE_FILE variable. If you have previously defined it, just remove it. You need to use a license server in this version.
5- Run 'aglmmgr.exe' inside "C:\Program Files\Agilent\EEsof_License_Tools\bin" folder and add the license file by using buttons and just follow the wizard.
6-If you'd succeed to patch it and the license file was detected, a window with a green mark will inform you that your license is valid and you're ready to run. At the end, just look at the license availability inside 'aglmmgr.exe'. If it shows "100", it means that you have done well but if it shows "0", it means you can not run ADS.
7- Once again, If you had any problem, just reboot your system and try again.
8, can run FEm ?
very very important:
Just for academic purposes, commercial use is strongly prohibited.
好消息!!!
ADS2013.06 已经可以完整使用了 (Momentum、fem)都能使用..河蟹文件还是我之前发的那个..
关键只在--所有该做的都做了之后......确定 C:\Agilent\ADS2013_06\Momentum\10.24 <-这个子夹名称一定要是 10.24
如果你在河蟹时,是被改成 ......Momentum\10.20 !? 那就rename 成......Momentum\10.24  即可.
常见问题;
1-. 不需要改时间区域
2-. 装不好,卸载之后提示无法安装??
把 C:\Program Files (x86)\Zero G Registry\.com.zerog.registry.xml
及 C:\Program Files\Zero G Registry\.com.zerog.registry.xml
这两个文件砍了 ***Zero G Registry是个隐藏属性子夹!
ADS2013.06_FEM_crack1.part1.rar
13.79 MB, 下载次数: 9355 , 下载积分: 资产 -5 信元, 下载支出 5 信元
ADS2013.06_FEM_crack1.part2.rar
12.46 MB, 下载次数: 8537 , 下载积分: 资产 -5 信元, 下载支出 5 信元
 楼主| 发表于 2013-10-5 14:47:47 | 显示全部楼层
ADS2013 RE_place ADS2009
发表于 2013-10-5 18:34:23 | 显示全部楼层
唉,出口转内销,我发的那个被人转到mwtee后又内销回来了
发表于 2013-10-5 22:04:06 | 显示全部楼层
谢谢分享,非常good。
喜欢这样的分享。
发表于 2013-10-6 09:37:51 | 显示全部楼层
建议楼主尊重本站原创者的劳动成果,删除附件,指向原作者链接
发表于 2013-10-6 15:11:04 | 显示全部楼层
我了个顶!
发表于 2013-10-7 12:16:15 | 显示全部楼层
发表于 2013-10-7 12:56:11 | 显示全部楼层
這樣不好吧!!別人辛苦得來的,要尊重他
轉發這樣不好
发表于 2013-10-8 07:31:27 | 显示全部楼层
要尊重別人辛苦得來的.
发表于 2013-10-8 12:01:20 | 显示全部楼层
lovemini 不是早就发过了吗?  这人是何用意???
GMT+8, 2025-11-27 00:44 , Processed in 0.028732 second(s), 6 queries , Gzip On, Redis On.
