DATE: 07-26-2013 HOTFIX VERSION: 013 ============1/55 to 20/55==================================================================
CCRID PRODUCT PRODUCTLEVEL2 TITLE
111368 CAPTURE CORRUPT_DESIGN Capture - will not produce allegro netlist with 10.0
134439 PD-COMPILE USERDATA caCell terminals should be top-level terminals
186074 CIS EXPLORER refresh symbols from lib requires you to close CIS
583221 CAPTURE SCHEMATIC_EDITOR Option to have the Schematic Page Name as a Property in the Titleblock
591140 CONCEPT_HDL OTHER Scale overall output size in PublishPDF from command line
801901 CONCEPT_HDL CORE Concept Menus use the same key "R" for the Wire and RF-PCB menus
813614 APD DRC_CONSTRAINTS With Fillets present the "cline to shape" spacing is wrong.
881796 ALLEGRO_EDITOR GRAPHICS Enhancement request for Panning with Middle Mouse Button
887191 CONCEPT_HDL CORE Cannot add/edit the locked property
911292 CONCEPT_HDL CORE Property command on editing symbol attaches property to ORIGIN immediately
987766 APD SHAPE Void all command gets result as no voids being generated on specific env.
1001395 SIP_LAYOUT ASSY_RULE_CHECK Shape Minimum void check reports lots of DRCs which are not necessary to check out.
1030696 ALLEGRO_EDITOR INTERACTIV Enh - Allow another behavior of PAN movement using middle mouse in Allegro
1043856 ADW TDA Diff between TDO and DE-HDL Hierarchy Viewer is confusing to the user
1046440 ADW PCBCACHE ADW: ImportSheet is not caching libraries under flatlib/model_sym when the source design is not an ADW project
1077552 F2B PACKAGERXL Diff Pairs get removed when packing with backannotation turned on
1079538 F2B PACKAGERXL Ability to block all 窺ingle noded nets?to the board while packaging.
1086362 ALLEGRO_EDITOR SHAPE Enhancement request to autovoid a via if shape cannot cover the center of the via.
1087958 PSPICE MODELEDITOR Is there any limitation for pin name definition?
1087967 CIS UPDATE_PART_STAT Update part status window shows incorrect differences
1090693 ADW LRM LRM auto_load_instances does not gray out Load instances Button
1097246 CONCEPT_HDL CORE ConceptHDL - assign hotkeys to alpha-numerical keys
1099773 CONCEPT_HDL CORE DE HDL goes into recursive loop if a custom text locked at site level is deleted from Tools > Option
1100945 SCM SCHGEN SCM generated DE-HDL has $PN placement issue
1100951 PSPICE SIMULATOR Increasing the resolution of fourier transform results in out file
1103117 RF_PCB FE_IFF_IMPORT Enh- Allow the Allegro_Discrete_Library_to_ADS_Library_Translator to output in its original unit
1105473 PSPICE PROBE Getting error messages while running bias point analysis.
1106116 FLOWS PROJMGR view_pcb setting change was cleared by switching Flows in projmgr.
1106298 ALLEGRO_EDITOR INTERACTIV Copy Shape uses last menu pick location as origin and not the Symbol Origin as specified in Options.
1106626 CONCEPT_HDL CORE Concept HDL crashes when saving pages
1107086 ALLEGRO_EDITOR INTERACTIV manual void with arc's goes in wrong direction during arc creation
1107172 CONCEPT_HDL OTHER Project Manager Packager does not report errors on missing symbol
1108193 CONCEPT_HDL CORE Using the left/right keys do not move the cursor within the text you're editing
1108603 PCB_LIBRARIAN VERIFICATION PDV Tools Verification > View Verification (CheckPlus) leaves <project>.cpm_tmp.cpm
1109024 CIS OTHER OrCad performance issue from Asus.
1109109 CAPTURE NETLIST_ALLEGRO B1: Netlist missing pins when Pack_short property pins connected
1109466 ALLEGRO_EDITOR ARTWORK Artwork create some strange gerber lines for fillet.
1109647 SIP_LAYOUT DEGASSING Shape degassing command enhancement - control over what layers are counted in even/odd layer sets.
1109926 CONCEPT_HDL CORE viewing a design disables console window
1110194 SIP_LAYOUT WIREBOND If OpenGL settings for display of dynamic net names is enabled, should be visible while push/shove wirebonds.
1112357 SIP_LAYOUT WIREBOND wirebond command crashes the application
1112395 CONCEPT_HDL CORE 璞BASE\G?for global signal is not obeyed after upreving the design to 1650.
1112658 CAPTURE PROPERTY_EDITOR Changing Part 澶raphic?value from property Editor Changes Occ refdes values to instance
1112662 CAPTURE PROJECT_MANAGER Capture crashes after moving the library file and then doing Edit> Cut
1113177 PCB_LIBRARIAN CORE Pin Shapes are not getting imported properly
1113380 ALLEGRO_EDITOR INTERACTIV Change layer to - option for package type .dra is not available in 16.6 release
1113656 SIP_LAYOUT WIREBOND Enable Change characteristic to work without unfixing its Tack point.
1113838 SIP_LAYOUT DIE_ABSTRACT_IF probe pins defined in XDA die abstract file are added with wrong location
1113991 CAPTURE GENERAL Save Project As is not working if destination is a linux machine
1114073 APD DRC_CONSTRAINTS Shape voiding differently if there are Fillets present in the design.
1114241 CAPTURE SCHEMATIC_EDITOR Port not retaining assigned color, when moved on the schematic
1114442 PSPICE PROBE Getting Internal error - Overflow Convert with marching waveform on
1114630 CONCEPT_HDL ARCHIVER Archcore fails because the project directory on Linux has a space in the name
1114689 CONCEPT_HDL CORE Unknown project directive : text_editor
1114928 F2B PACKAGERXL 激rror (SPCODD - 5) while Export Physical even after change pin from A<0> to A
1116886 CONCEPT_HDL CORE Crefer hyperlinks do not work fine when user use double digits partitions for page Border.
1118088 ALLEGRO_EDITOR EDIT_ETCH Should Plan accurate and Optimize be removed in 16.6?
1118734 APD EDIT_ETCH Multiline routing with Clines on Null Net cannot route in downward direction
1118756 ALLEGRO_EDITOR SHAPE Shape clearance parameter oversize values getting applied to Keepouts
1119606 CONCEPT_HDL MARKERS Filtering two or more words in Filter dialog box
1119707 CONCEPT_HDL CORE Genview does not use site colors when gen sch from block symbol
1119711 F2B DESIGNSYNC Design Differences show Net Differences wrongly
1120659 CAPTURE PROJECT_MANAGER "Save project as" does not support some of Nordic characters.
1120660 CONCEPT_HDL CORE Save hierarchy saves pages for deleted blocks.
1120817 SIP_LAYOUT SYMB_EDIT_APPMOD Rotate Pads commands not working while in the Symbol Edit App. mode
1120985 PSPICE MODELEDITOR Unable to import attached IBIS model
1121171 CONCEPT_HDL CREFER PNN and correct property values not annotated on the Cref flat schematic
1121353 ALLEGRO_EDITOR INTERACTIV Local env setting will change after saving and reopening.
1121382 ALLEGRO_EDITOR INTERACTIV Undo command is limited to two for this design
1121540 F2B PACKAGERXL pxl.chg keeps deleting and adding changes on subsequent packager runs
1121558 ALLEGRO_EDITOR MODULES Unrouted net and unrouted connection when module is placed of completely routed board file.
1121585 ALLEGRO_EDITOR OTHER Drill Hole to Shape Same Net Spacing with Dynamic Shapes shows wrong result.
1121651 CAPTURE SCHEMATIC_EDITOR "PCB editor select" menu option is missing
1122136 SIP_LAYOUT PLACEMENT Moving a component results in the components outline going to bottom side of the design.
1122340 CAPTURE NETLIST_ALLEGRO Cross probe of net within a bus makes Capture to hang.
1122489 CONCEPT_HDL OTHER Save _Hierarchy causing baseline to brd files
1122781 CONCEPT_HDL CORE cfg_package is generated for component cell automatically
1122909 CONCEPT_HDL CORE changing version replicates data of first TOC on 2nd one
1123150 CONCEPT_HDL CORE property on y axis in symbol view was moved by visibility change to None.
1123176 ALLEGRO_EDITOR UI_FORMS Negative values for pop-up location is not retained with multiple monitors (more than 2)
1123815 ALLEGRO_EDITOR GRAPHICS Embedded netname changes to a different netname
1124369 ALLEGRO_EDITOR INTERACTIV Sliding a shape using iy coordinate does not work indepedent of grid.
1124544 CONCEPT_HDL CORE About Search History of find with SPB16.5
1124570 APD IMPORT_DATA When importing Stream adding the option to change the point
1125201 CONCEPT_HDL CORE Connectivity edits in NEW block not saved( lost) if block is created using block add
1125314 ALLEGRO_EDITOR INTERACTIV Enved crash during setting of library paths in user preference
1125366 CONCEPT_HDL CORE DE-HDL craches during Import Physical if CM is open on Linux
1125628 CONCEPT_HDL CORE Crash on doing save hierarchy
1130555 APD WIREBOND Wirebond Import should connect to pins of the die specified on the UI.
1131030 PSPICE ENVIRONMENT Unregistered icon of Simulation setting in taskbar
1131083 ALLEGRO_EDITOR INTERACTIV Bug: 16.6 crash in changing the mode in Find filter window
1131226 ALLEGRO_EDITOR PLACEMENT When Angle is set in design parameters while placement component is rotated but outline is not.
1131567 CONCEPT_HDL OTHER Lower case values for VHDL_MODE make genview use pin location to determen direction.
1131699 PSPICE PROBE Probe window crash on trying to view simulation message
1132457 CONCEPT_HDL CORE The schematic never fully invokes and has connectivity errors.
1132575 CONCEPT_HDL CORE 2 pin_name were displayed and overlapped by spin command.
1132698 ALLEGRO_EDITOR EDIT_ETCH Slide Via with Segment option with new Slide command
1132964 ALLEGRO_EDITOR SHAPE Same net "B&B via to shape" errors created when adding shape
1133677 CONCEPT_HDL CORE Cant delete nor reset LOCATION prop in context of top
1133791 CONCEPT_HDL CORE Cant do text justification on a single selected NOTE in Windows mode.
1134761 CONCEPT_HDL CORE Why does Mouse Pointer/Tooltip display LOCATION instead of $LOCATION property
1135118 ALLEGRO_EDITOR INTERACTIV Mirror and other editing commands are missing for testpoint label text in general edit mode.
1136420 CAPTURE GENERAL Registration issue when CDSROOT has a space in its path
1136808 PSPICE STABILITY Pspice crash marker server has quite unexpectedly
1136840 CAPTURE SCHEMATICS Enh: Alignment of text placed on schematic page
1138586 ADW MIGRATION design migration does not create complete ptf file for hierarchical designs
1139376 CONCEPT_HDL CORE setting wire color to default creates new wire with higher thickness
1140819 APD GRAPHICS Bbvia does not retain temp highlight color on all layers when selected.
1141300 CONCEPT_HDL CORE DE HDL hier_write save hierarchy log reports summarizes Successfully saved block x while block was skipped
1141723 ADW PURGE purge command crashes with an MFC application failure message
1143448 CAPTURE GENERAL About copy & paste to Powerpoint from CIS
1143670 SIP_LAYOUT OTHER Cross Probing between SiP and DEHDL not working in 16.6 release
1143902 ALLEGRO_EDITOR DATABASE when the shape is rotated 45 degrees the void is moved.
1144990 PCB_LIBRARIAN CORE PDV expand & collapse vector pins resizes symbol outline to maximum height
1145112 CONCEPT_HDL CORE Warning message: Connectivity MIGHT have changed
1145253 CONCEPT_HDL CORE Component Browser adds properties in upper case
1146386 ALLEGRO_EDITOR INTERACTIV Place Replicate Create add Static shape with Fillet shape
1146728 F2B PACKAGERXL DCF with upper and lower case values on parts causes pxl to fail
1146783 ALLEGRO_EDITOR INTERFACES Highlighted component is missing from exported IPF file.
1147326 CONCEPT_HDL CORE HDL crashes when trying to reimport a block
1148337 CAPTURE ANNOTATE Checking "refdes control" is not giving the proper annotation result
1148633 SIP_LAYOUT INTERACTIVE Add "%" to the optical shrink option in the co-design die and compose symbol placement forms
1149778 CAPTURE SCHEMATICS Rotation of pspice marker before placement is not appropriate
1149987 PCB_LIBRARIAN PTF_EDITOR Save As pushing the part name suffix into vendor_part_number value
1151748 ALLEGRO_EDITOR OTHER If the pad and cline are the same width don't report a missing Dynamic Fillet.
1152206 CONCEPT_HDL CORE ROOM Property value changes when saving another Page
1152755 CONCEPT_HDL COPY_PROJECT Copy project hangs if library or design name has an underscore
1152769 PSPICE ENCRYPTION Unable to simulate Encrypted Models in 16.6
1153308 ALLEGRO_EDITOR DRC_CONSTR Creating Artwork Getting Warning "DRC is out of Date" even when DRC is up to date
1153893 F2B DESIGNVARI 16.6 Variant Editor not supporting - in name
1154185 SIG_INTEGRITY SIGNOISE Signoise didn't do the Rise edge time adjustment.
1154860 ALLEGRO_EDITOR MANUFACT Double digit drill character overlaps with figures triangle, hexagon and octagon in NC drill legend
1155167 ALLEGRO_EDITOR EDIT_ETCH Via structure placed in Create Fanout has incorrect rotation.
1155728 CONCEPT_HDL CORE Unable to uprev packaged 16.3 design in 16.5 due to memory
1155855 SCM SCHGEN A newly user-defined net property is not transferred from SCM to DEHDL in Preserved Mode
1156274 ALLEGRO_EDITOR INTERFACES Exported Step file from Allegro is wrong
1156316 CONSTRAINT_MGR OTHER Break in functionality while creation of pin-pairs under Xnet in Constraint Manager
1156351 CONCEPT_HDL CONSTRAINT_MGR Loose members in Physical Net Class between DEHDL and Allegro
1156547 ALLEGRO_EDITOR DRC_CONSTR Etch Turn under SMD pin rule check through pin Etch makes confused.
1156779 CONSTRAINT_MGR OTHER Electrical Cset References in CM not working correctly
1157167 ALLEGRO_EDITOR SKILL axlPolyFromDB with ?line2poly is broken
1158042 ALLEGRO_EDITOR DFA DFA_DLG writes the dra file name in uppercase.
1158718 CONCEPT_HDL CHECKPLUS Customer could not get $PN property values on logical rule of CheckPlus16.6.
1158970 ALLEGRO_EDITOR SCHEM_FTB Changing LOCATION to $LOCATION in DEHDL does not update the .brd file
1158989 ALLEGRO_EDITOR INTERFACES pdf_out -l creates a PDF
1159285 APD DXF_IF DXF_OUT fails; some figures are not exported
1159432 ALLEGRO_EDITOR SHOW_ELEM http:// in the Show Element in 166 do not have HTML link to open the Website
1159483 PCB_LIBRARIAN SETUP part developer crashing with
1159516 ALLEGRO_EDITOR EDIT_ETCH Unable to slide cline segment with new slide.
1159959 ALLEGRO_EDITOR GRAPHICS 3D viewer displays clines arcs incorrectly
1160004 SCM UI The RMB->Paste does not insert signal names.
1160410 ALLEGRO_EDITOR DATABASE Lock databse with View Lock option is misleading
1160529 SCM SCHGEN Schematic generation stopped because the tool was unable to create an appropriate internal symbol structure
1160537 SPIF OTHER Cannot start PCB Router
1161363 ALLEGRO_EDITOR SYMBOL Getting error SPMHGE-73 when trying to mirror symbol
1161781 CONSTRAINT_MGR CONCEPT_HDL SigXp crash when selecting ECset in design
1161896 ALLEGRO_EDITOR DRAFTING Tolerance value added for Dimensions is not working correctly (HF11-12)
1162193 SIP_LAYOUT DIE_ABSTRACT_IF shapes in dia file not linked to the die after edit co-design die
1162754 APD VIA_STRUCTURE Replace Via Structure command selecting dummy nets. |
Hotfix_SPB16.60.013_wint_1of1.part20.rar
14.31 MB, 下载次数: 96
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part01.rar
14.31 MB, 下载次数: 87
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part02.rar
14.31 MB, 下载次数: 74
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part03.rar
14.31 MB, 下载次数: 70
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part04.rar
14.31 MB, 下载次数: 61
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part05.rar
14.31 MB, 下载次数: 51
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part06.rar
14.31 MB, 下载次数: 67
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part07.rar
14.31 MB, 下载次数: 39
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part08.rar
14.31 MB, 下载次数: 59
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part09.rar
14.31 MB, 下载次数: 74
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part10.rar
14.31 MB, 下载次数: 39
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part11.rar
14.31 MB, 下载次数: 47
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part12.rar
14.31 MB, 下载次数: 36
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part13.rar
14.31 MB, 下载次数: 38
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part14.rar
14.31 MB, 下载次数: 27
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part15.rar
14.31 MB, 下载次数: 30
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part16.rar
14.31 MB, 下载次数: 32
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part17.rar
14.31 MB, 下载次数: 30
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part18.rar
14.31 MB, 下载次数: 29
, 下载积分:
资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.013_wint_1of1.part19.rar
14.31 MB, 下载次数: 30
, 下载积分:
资产 -5 信元, 下载支出 5 信元
