查看: 12776|回复: 21
ADS2012 CRACK求助啊啊 !
发表于 2012-12-6 11:31:33 | 显示全部楼层 |阅读模式
哪位大哥大姐有ADS2012的破解说明啊  !
发表于 2012-12-6 18:47:06 | 显示全部楼层
ADS2011.10的破解文件不能破解ADS2012.08吗?
 楼主| 发表于 2012-12-6 19:55:56 | 显示全部楼层
回复 2# zhule
    没试过啊?不知道怎么样啊 ?这个我也没有啊 !
发表于 2012-12-8 11:01:22 | 显示全部楼层
如沐春風,多謝多謝
发表于 2012-12-9 10:27:26 | 显示全部楼层
NEW LICENSES REQUIRED
New licenses are required for this release. If you are a supported customer, login to the Agilent Software Manager (ASM) to obtain your updated licenses before installation. For other licensing tasks, see "How to Obtain a License". If you upgrade your license to 3.0 version and use ADS 2009 or 2009 Update 1 you need to install the Agilent EEsof Licensing Tools. This will allow your licensing to function properly, and address certain lingering license issues.
ADS2012.08 的 许可证又换了,2011的理论上应该不能用
发表于 2012-12-9 11:12:43 | 显示全部楼层
2011 not suitble for 2012.
发表于 2012-12-9 17:40:41 | 显示全部楼层
希望cr@参考快点出来啊
发表于 2012-12-9 19:04:24 | 显示全部楼层
一起呼唤啊
发表于 2012-12-10 16:36:33 | 显示全部楼层
在此呼唤啊
发表于 2012-12-12 11:58:35 | 显示全部楼层
Any update for the 2012 solution?
GMT+8, 2025-10-5 14:38 , Processed in 0.021554 second(s), 6 queries , Gzip On, Redis On.
