查看: 17902|回复: 5
[求助] 请教 +pulse_r/100 +pulse_e/100
发表于 2010-10-13 09:40:28 | 显示全部楼层 |阅读模式
请教 +pulse_r/100 +pulse_e/100 是什么意思啊,说是与固有延迟和传输延迟有关,那位大哥能做个关于这条命令的详细解释啊?
1. 该命令用在哪里,code? DC ? VCS ?
2. _r 和 _e 还有后面的数字各代表什么意思啊?
谢谢啦
发表于 2010-10-17 20:44:06 | 显示全部楼层
看到过有人用在ius仿真,查过ncvlog,ncverilog,ncvhdl帮助,没发现这样的选项。感觉没啥用
 楼主| 发表于 2010-10-18 11:10:00 | 显示全部楼层
哦,谢谢2L的答复~
发表于 2011-9-5 16:05:48 | 显示全部楼层
vcs的仿真选线,在后仿时,如果pulse的宽度很小,如小于器件本身的延时的话,会直接被仿真器屏蔽且不会有任何报警。
可以通过增加+pulse_e/100 +pulse_r/100的仿真选项,将这些很小的毛刺报出来。
The +pulse_e/number option’s number argument specifies a percentage of the module path delay. VCS replaces pulses whose widths that are narrower than the specified percentage of the delay with an X value pulse on the output or inout port and displays a warning message.
The +pulse_r/number option’s number argument also specifies a percentage of the module path delay. VCS filters out the pulses whose widths are narrower than the specified percentage of the delay. With these pulses there is no warning message; VCS simply ignores these pulses.
发表于 2013-1-14 13:50:55 | 显示全部楼层
so?
okay
I see
thanks
发表于 2013-4-17 15:20:31 | 显示全部楼层
回复 4# niyifang
   thanks for ur reply; it's useful.
GMT+8, 2025-7-4 02:36 , Processed in 0.019443 second(s), 9 queries , Gzip On, MemCached On.
