查看: 76668|回复: 193
RTL级最强验证工具spyglass
发表于 2011-8-14 18:39:15 | 显示全部楼层 |阅读模式
包含四部分: LowPower, CDC, Constraint, DFT
以前发过不全,这次发全了。 注意必须要用haozip来解压缩
工具还是不错的,希望大家用正版软件
 楼主| 发表于 2011-8-14 19:03:26 | 显示全部楼层
回复 1# zhuzhzh
发表于 2011-8-18 23:24:32 | 显示全部楼层
按照下面的安装说明安装后,出现了以下问题中的问题,请教一下什么原因?是我哪个步骤操作错了?谢谢。
按照下面安装日志安装后,执行SPYGLASS_HOME/bin/spyglass,就出现了问题。
安装说明:
oftware Version:SpyGlass-4.2.0
1. $ mkdir /eda/atrenta
2. untar all .tar.gz files except LINUX64 cause it's not cracked.
   NOTE: You should first unpack the SpyGlass-<rev>.tar.gz archive and then the SpyBuilder-<rev>.tar.gz archive in the same directory when you are installing both
3. modify the file : Spyglass-4.2.0/SPYGLASS_HOME/auxi/tkgui-new/spygui.pl
   line 794 : $license_check_disabled =0 to 1;
   line 1776 : $can_license_check_be_disabled =0 to 1;
4. $ cd SpyGlass-4.2.0/SPYGLASS_HOME/obj
   $ sfk replace -bin /5589e557565383ec4c8b159cdf520985d20f84440300008b3d340c5209/31c0c357565383ec4c8b159cdf520985d20f84440300008b3d340c5209/ -dir . -yes
   (you can find a compitable version of sfk on sourceforge.net)
   (check.Linux2 will be patched).
5. config the environment viarible file atrenta.conf:
   #export ATRENTA_LICENSE_FILE=<license_file_path>
   export PATH=/eda/atrenta/SpyGlass-4.2.0/SPYGLASS_HOME/binPATH”
   alias spyglass='spyglass -32bit'
   if you don't specify the parameter -32bit when on the 64 bit OS, error will occur :
   $ spyglass -verilog test.v
   ***ERROR: Missing shared library '/mnt/eda/atrenta/SpyGlass-4.2.0/SPYGLASS_HOME/lib/libsgptmalloc-Linux4.so'
6. add command "source /eda/atrenta/atrenta.conf" to your .bashrc file.
7. done! enjoy it!
发表于 2011-8-18 23:26:49 | 显示全部楼层
 楼主| 发表于 2011-8-21 21:27:21 | 显示全部楼层
回复 3# tdscdma20
    没传全呢
 楼主| 发表于 2011-8-21 21:41:10 | 显示全部楼层
回复 1# zhuzhzh
 楼主| 发表于 2011-8-21 21:50:57 | 显示全部楼层
回复 6# zhuzhzh
 楼主| 发表于 2011-8-21 21:53:40 | 显示全部楼层
回复 7# zhuzhzh
 楼主| 发表于 2011-8-21 22:07:27 | 显示全部楼层
回复 8# zhuzhzh
 楼主| 发表于 2011-8-21 22:32:47 | 显示全部楼层
回复 9# zhuzhzh
GMT+8, 2025-11-10 17:06 , Processed in 1.542802 second(s), 8 queries , Gzip On, Redis On.
