查看: 17839|回复: 22
[求助] 帮忙解释一下vcs安装问题 !
发表于 2011-6-19 19:26:23 | 显示全部楼层 |阅读模式
我安装vcs2005 用installer 2.0 工具安装时提示如下:应该选择那个路径啊?还是安装源文件有问题呢?
登录/注册后可看大图
发表于 2011-6-19 19:52:36 | 显示全部楼层
你需要管理员账户才能进行安装
 楼主| 发表于 2011-6-21 00:46:33 | 显示全部楼层
最后的时候出现这样的安装错误?大侠们帮忙啊?都折腾好几天了
./linux/include, 0 bytes
DO_INSTALL /home/xu/synopsys/vcs/vcs-mx_vD-2009/VMS/admin/install.sh -r /home/xu/synopsys/vcs/vcs-mx_vD-2009 -plat "linux"
ERROR : Failed to execute  /home/xu/synopsys/vcs/vcs-mx_vD-2009/VMS/admin/install.sh
ERROR :
Start VMS/admin/install.sh
untar var.tar.gz  ...
untar samples.tar.gz ...
setting synopsys_rman.setup ...
Platform linux dependent code found
chmod: 无法访问"var": 没有那个文件或目录
发表于 2011-6-21 09:54:52 | 显示全部楼层
LZ的VCS在哪下的?能不能给个链接啊?
发表于 2011-6-22 09:36:31 | 显示全部楼层
學習看看~
发表于 2011-6-28 21:51:37 | 显示全部楼层
我也遇到类似的问题
发表于 2011-11-14 15:46:45 | 显示全部楼层
一样的问题。在EETOP里面下载的安装包,折腾死了,安不起
发表于 2012-3-6 15:50:17 | 显示全部楼层
回复 7# lindan06090609
    我在eetop上下的这个版本的也是这个问题
发表于 2012-3-7 04:22:17 | 显示全部楼层
回复 2# haichao_xjtu
   同求。。。
发表于 2012-3-29 23:36:48 | 显示全部楼层
Linux version 'Fedora release 16 (Verne)' is not supported on 'x86_64'
  officially, assuming linux compatibility by default. Set VCS_ARCH_OVERRIDE
  to linux or suse32 to override.
  Please refer to release notes for information on supported platforms.
Warning-[LINX_KRNL] Unsupported Linux kernel
  Linux kernel '3.3.0-4.fc16.x86_64' is not supported.
  Supported versions are 2.4* or 2.6*.
Error-[VCS_COM_UNE] Cannot find VCS compiler
  VCS compiler 'VCS_HOME' not found. Environment variable
  /usr/eda/syn/vcsamd64/vcs_2011.1/linux
  (/usr/eda/syn/vcsamd64/vcs_2011.1/linux/bin/vcs1) is selecting a directory
  in which there isn't a compiler 'linux' for a machine of this type
  'VCS_HOME'.
  Please check whether 'VCS_HOME' is incorrect; if not, see below.
  'VCS_HOME'.
  <extra strings were given: <null string> >
Perhaps vcs hasn't been installed for machine of type "linux".
Or the installation has been damaged.
To verify whether vcsE-2011.03 supports machine of type "Linux 3.3.0-4.fc16.x86_64",
please look at ReleaseNotes for more details .
We determine the machine type from uname; maybe uname is incorrect.
You can fix installation problems by reinstalling from CDROM
or downloading it from the Synopsys ftp server.
For assistance, please contact vcs technical support
at vcs_support@synopsys.com or call 1-800-VERILOG
错误,有人帮解答下么?
GMT+8, 2025-11-2 19:26 , Processed in 0.202470 second(s), 7 queries , Gzip On, Redis On.
