发表于 2011-5-12 22:28:21
显示全部楼层
回复 9# tottionly
Yes, the regulator's stability is highly dependent on its load.
I cannot imagine what takes place when the collector of the PNP is disconnected from the power supply pin of the PHY.
My speculation is that the PNP would find its collector current load suddenly disappears (from, for instance, several milli-amperes) to zero, So the collector terminal voltage would jump up to VCC - VCE(saturation) ~= 3.3 V. VCTL would go up only if the regulator loop thinks VCC_2.5V is too high.
On the other hand, if VCC_2.5V already lost its supply source (which once was from the collector of the PNP), how could it be charged too high?
Regarding the reason why simple resistive load would cause instability:
Question: what is the resistance of the resistor you tried?
1 KOhm?
You may want to shunt an additional capacitor with the resistor and try its stability again. You may want to try 1 nF to 10 nF.
I anticipate the on-chip decoupling capacitor has the capacitance in the aforementioned range (between VCC_2.5V to ground). |
