查看: 34320|回复: 142
[资料] Altera Quartus II 10.1 (needn't run crack program)
发表于 2011-1-23 00:47:14 | 显示全部楼层 |阅读模式
Altera Quartus II 10.1 crack
for Windows 32-bit and 64-bit
Needn't run any crack program to avoid back door virus.
Add absent feature by yourself.
Only needs 3 steps:
#. copy \bin   to \altera\101\quartus\bin\
#. copy \bin64 to \altera\101\quartus\bin64\
#, directly use 'license.xxx.dat' and replace HOSTID=xxxxxxxxxxxx in
   'license.xxx.dat' as your network interface card (NIC) MAC assress
NOTE for 'license.xxx.dat':
(1) you can use windows command "ipconfig /all" to see "Physical Address"
     and removing character '-' to obtain the 12-digit number for MAC address
(2) add missing component code, such as 6AF7_9999, to PACKAGE CORE1 ~ CORE5
     if output message of Quartus shows the follows for this component code:
       "Warning: OpenCore Plus Hardware Evaluation feature is turned on for
       the following cores"
Altera_Quartus_II.10.1_crack.zip (894.59 KB , 下载次数: 1078 )
发表于 2011-1-23 10:02:35 | 显示全部楼层
總算有license了,thanks!!
发表于 2011-1-23 10:22:28 | 显示全部楼层
裡面的license.xxx.dat改掉HOSTID還是不能用,
不過改直接用以前9.1的license.dat居然沒問題
 楼主| 发表于 2011-1-23 10:55:29 | 显示全部楼层
Can you describe more details of it?
For example, the message of Quartus when you use "license.xxx.dat" file.
I use it without any problem at least for 5 PCs with Win XP x64 edition.
Thanks!
发表于 2011-1-23 10:56:57 | 显示全部楼层
谢谢,很好的资料~~~~
发表于 2011-1-23 11:13:44 | 显示全部楼层
谢谢,很好的资料~~~~
发表于 2011-1-30 21:15:52 | 显示全部楼层
It's more safe
发表于 2011-2-6 17:36:18 | 显示全部楼层
看看是否功能全
发表于 2011-2-10 15:04:38 | 显示全部楼层
同感,终于有license了
发表于 2011-2-10 23:13:57 | 显示全部楼层
试试看.
GMT+8, 2025-9-23 09:15 , Processed in 0.054173 second(s), 7 queries , Gzip On, Redis On.
