查看: 73339|回复: 418
IEEE上关于DC-DC的文章
发表于 2007-6-19 19:41:57 | 显示全部楼层 |阅读模式
32 V-300 A_60 kHz edge resonant soft-switching PWM DC-DC converter with DC rail series switch-parallel capacitor snubber assisted by high-frequency transformer parasitic components.pdf
A comparison of nondeterministic and deterministic switching methods for DC-DC power converters.pdf
A family of buck-type DC-DC converters with autotransformers.pdf
A low-ripple switched-capacitor DC-DC up converter for low-voltage applications.pdf
A magnetic-less DC-DC converter for dual voltage automotive systems.pdf
A modified current-doubler rectifier for DC-DC converters to achieve balanced average currents.pdf
A monolithic current-mode CMOS DC-DC converter with on-chip current-sensing technique.pdf
A new approach to low conversion ratio DC-DC converters.pdf
A new DC-DC converter for fuel cell powered distributed residential power generation systems.pdf
A new matrix integrated magnetics (MIM) structure for low voltage, high current DC-DC converters.pdf
A novel delta-sigma modulated DC-DC power converter utilizing dither signal.pdf
A novel full-bridge DC-DC converter for battery charging using secondary-side control combines soft switching over the full load range and low magnetics requirement.pdf
A planar 4.5-GHz DC-DC power converter.pdf
A resonant DC-DC transformer.pdf
A zero-voltage and zero-current switching full bridge DC-DC converter with transformer isolation.pdf
About the distinctive characteristics of DC-DC switch-mode converters under discontinuous conduction mode.pdf
Adaptive piezoelectric energy harvesting circuit for wireless remote power supply.pdf
Adaptive voltage regulation of PWM buck DC-DC converters using backstepping sliding mode control.pdf
Advanced high frequency transformer linked soft switching PWM DC-DC power converter with utility AC dual voltage
modes for low voltage and large current applications.pdf
Alternate forms of the PWM switch model in discontinuous conduction mode [DC-DC converters].pdf
An analytical technique for the analysis of switching DC-DC converters.pdf
Analysis and evaluation of a series-combined connected boost and buck-boost dc-dc converter for photovoltaic application.pdf
Analysis of EMC characteristics of DC-DC regulators with different power conversion methods.pdf
Bi-directional forward-flyback DC-DC converter.pdf
Calculation and stability investigation of periodic steady states of the voltage controlled Buck DC-DC converter.pdf
DC-DC converter-aware power management for battery-operated embedded systems.pdf
Derivation of the Cuk PWM DC-DC converter circuit topology.pdf
Design considerations for a fuel cell powered dc-dc converter for portable applications.pdf
Design of a 200 amp telecom rectifier family using 50 amp DC-DC converters.pdf
Design of a hybrid monolithic integrated switched capacitor DC-DC step-up converter.pdf
Design of low output voltage DC-DC converters through artificial evolution.pdf
Development of a zero-voltage-transition bidirectional DC-DC converter for a brushless DC machine EV propulsion system.pdf
Direct DC-DC electric vehicle charging with a grid connected photovoltaic system.pdf
Double-output Luo converters, an advanced voltage-lift technique.pdf
Dual-bridge DC-DC converter -- a new topology characterized with no deadtime operation.pdf
Efficient ZVS-PWM DC-DC power converter with active switches in secondary side of high-frequency transformer.pdf
EMI evaluation and hardening of DC-DC converters-a prime source for high conducted noise.pdf
Equivalent switching modeling of ZVZCS FB PWM converter.pdf
Evolution of soft-switched, high-frequency, high-power isolated DC-DC converter.pdf
Feasibility study of high frequency step-up transformer linked soft-switching PWM DC-DC converter with tapped inductor filter.pdf
General rules for signal flow graph modeling and analysis of dc-dc converters.pdf
Harmonic analysis of nondeterministic switching methods for DC-DC power converters.pdf
High input voltage step-down DC-DC converters for integration in a low voltage CMOS process.pdf
High performance coupled-inductor DC-DC converters.pdf
High-efficiency, high step-up DC-DC converters.pdf
High-power switching regulator type DC-DC converters controlled by time-sharing high-frequency thyristor choppers with energy-storage and -transfer reactors.pdf
High-power-density MHz-switching monolithic DC-DC converter with thin-film inductor.pdf
Hybridge zero-current-switching rectifier for high-frequency DC-DC converter applications.pdf
Inductor current sharing of current doubler rectifier in isolated DC-DC converters.pdf
Isolated interleaved-phase-shift-PWM DC-DC ZVS converters.pdf
Low-voltage-swing monolithic dc-dc conversion.pdf
Modeling the closed-current loop of PWM boost DC-DC converters operating in CCM with peak current-mode control.pdf
Modelling and control of DC-DC converters.pdf
Monolithic DC-DC converter analysis and MOSFET gate voltage optimization.pdf
Multiphase voltage-mode hysteretic controlled DC-DC converter with novel current sharing.pdf
Negative output Luo converters -- voltage lift technique.pdf
New substrate for micro DC-DC converter.pdf
Novel soft-commutation DC-DC power converter with high-frequency transformer secondary side phase-shifted PWM active rectifier.pdf
On some general laws of DC-DC regulators.pdf
On the periodic behavior of PWM DC-DC converters.pdf
On-Chip Compensated Error Amplifier for Fast Transient DC-DC Converters.pdf
Optimum design method of CMOS IC for DC-DC converter that integrates power stage MOSFETs.pdf
Output ripple analysis of switching DC-DC converters.pdf
Performance prediction of DC-DC converters with impedances as loads.pdf
Positive output Luo converters -- voltage lift technique.pdf
Power line communication in dc-dc converters using switching frequency modulation.pdf
Power saving of a dynamic width controller for a monolithic current-mode CMOS DC-DC converter.pdf
Resonant pole-assisted soft switching DC-DC power converter with phase-shifted PWM scheme of active switches in transformer secondary-side.pdf
Reversed-output current-assisted ZVS phase-shift PWM DC-DC power converter using synchronous rectifier.pdf
Robust control of DC-DC converter by good approximate 2-degree-of-freedom system.pdf
Robust control of DC-DC converter by high-order approximate 2-degree-of-freedom digital controller.pdf
Self-lift DC-DC converters.pdf
Seven self-lift DC-DC converters, voltage lift technique.pdf
Single-power-stage three-phase AC-DC-DC converter with power factor correction.pdf
Soft switching PWM DC-DC flyback converter with transformer - assisted pulse current regenerative passive resonant snubbers.pdf
Stability analysis of parallel DC-DC converters.pdf
Steady state analysis & design of switched capacitor DC-DC convertors.pdf
Synchronous active rectifier-assisted soft-switching PWM DC-DC power converter with high-frequency link.pdf
Tapped inductor filter-assisted soft-switching PWM DC-DC power converter with high frequency transformer link for automotive AC power supply.pdf
Tapped-inductor filter assisted soft-switching PWM DC-DC power converter.pdf
The LC-PWM-SF-RDC cell in the application of DC-DC converters and DC-link inverters.pdf
Ultra compact DC-DC converters for the digital age.pdf
Unified analog and digital models for half bridge DC-DC converter with current doubler rectifier.pdf
Unified steady-state and dynamic modeling for symmetric and asymmetric half-bridge DC-DC converters with current doubler rectifiers.pdf
Unified steady-state model and DC analysis of half-bridge DC-DC converters with current doubler rectifier.pdf
file:///C:/DOCUME%7E1/JASONW%7E1/LOCALS%7E1/Temp/moz-screenshot.jpgfile:///C:/DOCUME%7E1/JASONW%7E1/LOCALS%7E1/Temp/moz-screenshot-1.jpgfile:///C:/DOCUME%7E1/JASONW%7E1/LOCALS%7E1/Temp/moz-screenshot-2.jpg
DC-DC.part01.rar
4.77 MB, 下载次数: 1260 , 下载积分: 资产 -3 信元, 下载支出 3 信元
IEEE - DC-DC
 楼主| 发表于 2007-6-19 19:46:05 | 显示全部楼层
IEEE - DC-DC
DC-DC.part02.rar
4.77 MB, 下载次数: 1262 , 下载积分: 资产 -3 信元, 下载支出 3 信元
IEEE - DC-DC
 楼主| 发表于 2007-6-19 19:50:31 | 显示全部楼层
IEEE - DC-DC
DC-DC.part03.rar
4.77 MB, 下载次数: 1373 , 下载积分: 资产 -3 信元, 下载支出 3 信元
IEEE - DC-DC
 楼主| 发表于 2007-6-19 19:55:47 | 显示全部楼层
IEEE - DC-DC
DC-DC.part04.rar
4.77 MB, 下载次数: 1328 , 下载积分: 资产 -3 信元, 下载支出 3 信元
IEEE - DC-DC
 楼主| 发表于 2007-6-19 20:01:22 | 显示全部楼层
IEEE - DC-DC
DC-DC.part05.rar
4.77 MB, 下载次数: 1170 , 下载积分: 资产 -3 信元, 下载支出 3 信元
IEEE - DC-DC
 楼主| 发表于 2007-6-19 20:07:13 | 显示全部楼层
IEEE - DC-DC
DC-DC.part06.rar
4.77 MB, 下载次数: 1127 , 下载积分: 资产 -3 信元, 下载支出 3 信元
IEEE - DC-DC
 楼主| 发表于 2007-6-19 20:23:38 | 显示全部楼层
IEEE - DC-DC
DC-DC.part07.rar
4.77 MB, 下载次数: 1195 , 下载积分: 资产 -3 信元, 下载支出 3 信元
IEEE - DC-DC
 楼主| 发表于 2007-6-19 20:28:40 | 显示全部楼层
IEEE - DC-DC
DC-DC.part08.rar
4.77 MB, 下载次数: 1217 , 下载积分: 资产 -3 信元, 下载支出 3 信元
IEEE - DC-DC
 楼主| 发表于 2007-6-19 20:32:45 | 显示全部楼层
IEEE - DC-DC
DC-DC.part09.rar
4.77 MB, 下载次数: 1159 , 下载积分: 资产 -3 信元, 下载支出 3 信元
IEEE - DC-DC
 楼主| 发表于 2007-6-19 20:35:45 | 显示全部楼层
IEEE - DC-DC
DC-DC.part10.rar
4.77 MB, 下载次数: 1019 , 下载积分: 资产 -3 信元, 下载支出 3 信元
IEEE - DC-DC
GMT+8, 2025-10-29 03:36 , Processed in 0.026958 second(s), 6 queries , Gzip On, Redis On.
