查看: 5200|回复: 18
{2003 paper} Improve IP3 as large as 10 dB_A low-power highly linear amplifier
发表于 2007-3-14 22:36:42 | 显示全部楼层 |阅读模式
想增加iip3的可以看看这篇文章
Abstract—A low-power highly linear CMOS RF amplifier
circuit composed of a Multiple-Gated common-source FET
TRansistor (MGTR) in cascode configuration is reported. In a
MGTR amplifier, linearity is improved by using transconductance
linearization which can be achieved by canceling the negative
peak value of of the main transistor with the positive one
in the auxiliary transistor having a different size and gate drive
combined in parallel. This enhancement, however, is limited by
the distortion originated from the combined influence of
and harmonic feedback, which can greatly be reduced by the
cascoding MGTR output. IP3 improvement as large as 10 dB
has been obtained from an experimental RF amplifier designed
at 900 MHz and fabricated using 0.35 m BiCMOS technology
using only CMOS at a similar power consumption and gain as
those obtainable from conventional cascode single gate transistor
amplifiers.
Index Terms—CMOS, IP3, MGTR, nonlinearity.
abbr_6dc4da715a2e3233ad4a7c95b66d1396.pdf
301.04 KB, 下载次数: 67 , 下载积分: 资产 -2 信元, 下载支出 2 信元
想增加iip3的可以看看这篇文章
发表于 2007-3-14 23:19:09 | 显示全部楼层
下来看看先
发表于 2007-3-14 23:33:06 | 显示全部楼层
就是给出的信息量太少,复制不出来
头像被屏蔽
发表于 2007-4-30 06:17:06 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-10-11 15:40:21 | 显示全部楼层
好好
好好
好好
好好
发表于 2009-10-28 21:34:06 | 显示全部楼层
先下下来看看
发表于 2009-11-21 20:20:57 | 显示全部楼层
hen bu cuo de wenzhang!!!
发表于 2009-11-23 23:00:00 | 显示全部楼层
感谢分享
发表于 2009-11-24 23:42:05 | 显示全部楼层
thanks for you sharing
发表于 2009-11-25 16:48:03 | 显示全部楼层
目前正在研究这块,谢谢共享!
GMT+8, 2025-9-14 03:42 , Processed in 0.021978 second(s), 6 queries , Gzip On, Redis On.
