查看: 18467|回复: 69
我来发吧!2009年11月JSSC全集
发表于 2009-11-4 14:46:49 | 显示全部楼层 |阅读模式
1、A 2.4 GHz Low-Power Sixth-Order RF Bandpass $DeltaSigma$ Converter in CMOS
2、Design of a 770-MHz, 70-mW, 8-bit Subranging ADC Using Reference Voltage Precharging Architecture
3、A 4 Gb/s 3-bit Parallel Transmitter With the Crosstalk-Induced Jitter Compensation Using TX Data Timing Control
4、A 1.25–5 GHz Clock Generator With High-Bandwidth Supply-Rejection Using a Regulated-Replica Regulator in 45-nm CMOS
5、A World-Band Triple-Mode 802.11a/b/g SOC in 130-nm CMOS
6、A Hybrid Spur Compensation Technique for Finite-Modulo Fractional-N Phase-Locked Loops
7、ROM-Based Logic (RBL) Design: A Low-Power 16 Bit Multiplier
8、A 0.7-V 1.8-mW H.264/AVC 720p Video Decoder
9、A Power, Performance Scalable Eight-Cores Media Processor for Mobile Multimedia Applications
10、A 0.5 V 4.85 Mbps Dual-Mode Baseband Transceiver With Extended Frequency Calibration for Biotelemetry Applications
11、Accurate Array-Based Measurement for Subthreshold-Current of MOS Transistors
12、BER Measurement of a 5.8-Gb/s/pin Unidirectional Differential I/O for DRAM Application With DIMM Channel
13、A 1.12 pJ/b Inductive Transceiver With a Fault-Tolerant Network Switch for Multi-Layer Wearable Body Area Network Applications
14、High-Efficiency Differential-Drive CMOS Rectifier for UHF RFIDs
15、A 2.4-GHz Resistive Feedback LNA in 0.13-$mu$m CMOS
16、A 6-bit, 0.2 V to 0.9 V Highly Digital Flash ADC With Comparator Redundancy
17、A 10-Bit 500-MS/s 55-mW CMOS ADC
18、A 1-GS/s 6-Bit Two-Channel Two-Step ADC in 0.13-$mu$m CMOS
19、A 107.4 dB SNR Multi-Bit Sigma Delta ADC With 1-PPM THD at $-$0.12 dB From Full Scale Input
20、A CMOS Time-to-Digital Converter (TDC) Based On a Cyclic Time Domain Successive Approximation Interpolation Method
21、Low Phase Noise G$ _{m}$-Boosted Differential Gate-to-Source Feedback Colpitts CMOS VCO
22、RF Oscillator Based on a Passive RC Bandpass Filter
23、An Edge Missing Compensator for Fast Settling Wide Locking Range Phase-Locked Loops
24、A 1.5 GHz All-Digital Spread-Spectrum Clock Generator
25、An 8$,times,$ 5 Gb/s Parallel Receiver With Collaborative Timing Recovery
26、A Delay-Locked Loop Synchronization Scheme for High-Frequency Multiphase Hysteretic DC-DC Converters
27、A 0.13-$mu$ m CMOS 6 Gb/s/pin Memory Transceiver Using Pseudo-Differential Signaling for Removing Common-Mode Noise Due to SSN
28、A Reconfigurable 8T Ultra-Dynamic Voltage Scalable (U-DVS) SRAM in 65 nm CMOS
29、Large-Scale SRAM Variability Characterization in 45 nm CMOS
30、A Micropower $DeltaSigma$-Based Interface ASIC for a Capacitive 3-Axis Micro-Accelerometer
JSSC200911.part01.rar
4.77 MB, 下载次数: 229 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC200911.part02.rar
4.77 MB, 下载次数: 242 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC200911.part03.rar
4.77 MB, 下载次数: 232 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC200911.part04.rar
4.77 MB, 下载次数: 230 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC200911.part05.rar
4.77 MB, 下载次数: 226 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC200911.part13.rar
2.36 MB, 下载次数: 211 , 下载积分: 资产 -2 信元, 下载支出 2 信元
JSSC200911.part06.rar
4.77 MB, 下载次数: 216 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC200911.part07.rar
4.77 MB, 下载次数: 246 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC200911.part08.rar
4.77 MB, 下载次数: 231 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC200911.part09.rar
4.77 MB, 下载次数: 234 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC200911.part10.rar
JSSC200911.part11.rar
4.77 MB, 下载次数: 224 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC200911.part12.rar
 楼主| 发表于 2009-11-4 14:54:02 | 显示全部楼层
发表于 2009-11-4 15:23:08 | 显示全部楼层
发表于 2009-11-4 15:29:24 | 显示全部楼层
我靠  这个东西太好了
发表于 2009-11-4 15:31:28 | 显示全部楼层
Thanks for sharing!
发表于 2009-11-4 16:19:53 | 显示全部楼层
现在怎么设置了下载时间限制啊 很不方便啊
是不是服务器的负担太大了?
发表于 2009-11-4 18:08:13 | 显示全部楼层
同6楼的哥们。。。
发表于 2009-11-4 18:18:03 | 显示全部楼层
Thanks a lot
发表于 2009-11-4 20:32:54 | 显示全部楼层
真是快啊!!!
发表于 2009-11-4 21:16:16 | 显示全部楼层
好东西,谢谢分享
GMT+8, 2025-11-17 07:56 , Processed in 0.024503 second(s), 7 queries , Gzip On, Redis On.
