查看: 40527|回复: 191
经典讲义:麻省理工《数字通信原理》
发表于 2009-5-14 19:30:32 | 显示全部楼层 |阅读模式
麻省理工经典讲义《数字通信原理》
MIT
6.450 Principles of Digital Communications
Lecture 1: Introduction to Digital Communication (PDF)
Lecture 2: Coding for Discrete Sources (PDF)
Lecture 3: Coding for Discrete Sources (continued) (PDF)
Lecture 4: Coding for Sequences of Source Symbols (PDF)
Lecture 5: Sources With Memory and the Lempel-Ziv Algorithm (PDF)
Lecture 6: Quantization (PDF)
Lecture 7: High-Rate Entropy-Coded Quantization (PDF)
Lecture 8-9: Analog Sources: Waveforms ↔ Sequences (PDF)
Lecture 10: Waveforms as Vectors in Signal-Space (PDF)
Lecture 11: Introduction to Channels and PAM (PDF)
Lecture 12: QAM (PDF)
Lecture 13: QAM and Noise (PDF)
Lecture 14: Noise and Gaussian Random Processes (PDF)
Lecture 15: Gaussian Noise, Covariance and Spectral Density (PDF)
Lecture 16: Spectral Density, Orthonormal Expansions (PDF)
Lecture 17-18: Detection (PDF)
Lecture 19: The Irrelevance Theorem and Orthogonal Signal Sets (PDF)
Lecture 20: Wireless Communication Systems (PDF)
Lecture 21: Input/Output Models for Wireless (PDF)
Lecture 22: Stochastic Wireless Models (PDF)
Lecture 23: Channel Measurement and Rake Receivers (PDF)
Lecture 24: Coding, IS-95, and CDMA (PDF)
MIT 6.450 Principles of Digital Communications.rar
2.62 MB, 下载次数: 1364 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-5-14 22:48:05 | 显示全部楼层
Thanks a lot !!!!!!!!!!!!!!!
发表于 2009-5-15 01:17:50 | 显示全部楼层
seeeeeeeeeeeeeeeeeeeeee
发表于 2009-5-15 06:52:06 | 显示全部楼层
very good
发表于 2009-5-15 11:48:27 | 显示全部楼层
very good thanks a lot
发表于 2009-5-15 11:55:57 | 显示全部楼层
very good thanks
发表于 2009-5-15 22:19:58 | 显示全部楼层
非常感谢 !!
发表于 2009-5-15 22:38:31 | 显示全部楼层
发表于 2009-8-20 13:07:45 | 显示全部楼层
很不错
发表于 2009-8-20 23:28:56 | 显示全部楼层
财务代理 工商注册
登录/注册后可看大图
登录/注册后可看大图
登录/注册后可看大图
登录/注册后可看大图
登录/注册后可看大图
GMT+8, 2025-11-8 08:07 , Processed in 0.028504 second(s), 9 queries , Gzip On, Redis On.
