The_Designer's_Guide_to_Jitter_in_Ring_Oscillators.rar
(3.88 MB , 下载次数:
3728 )
The Designer's Guide to Jitter in Ring OscillatorsSeries: The Designer's Guide Book Series
McNeill, John A., Ricketts, David
2009, XX, 276 p. 140 illus., Hardcover
ISBN: 978-0-387-76526-6
Due: 五月 2009
About this book
- Emphasizes jitter for time domain applications so that there is not a need to translate from frequency domain
- Provides a more direct path to the results for designing in an application area where performance is specified in the time domain
- Includes classification of oscillator types and an exhaustive guide to existing research literature
- Covers the classification of measurement techniques
The Designer’s Guide to Jitter in Ring Oscillators provides information for engineers on designing voltage controlled oscillators (VCOs) and phase-locked loops (PLLs) for low jitter applications such as serial data communication and clock synthesis. The material is presented in a clear, intuitive fashion at both the system level and the circuit level to help designers improve their understanding of fundamental noise sources and design low jitter circuitry within power, area, and process constraints so that ultimate performance meets system level requirements.
At the system level, the authors describe and specify different methods of measuring jitter to characterize time domain uncertainty. Although the emphasis is on time-domain measures of oscillator performance, a simple method of translating performance to frequency domain (phase noise) measures is also included.
At the circuit level, the authors include techniques for design of low jitter delay elements for use in ring oscillators, as well as relating the circuit-level characteristics to system-level performance. The authors discuss a classification scheme for delay stages to help guide the designer’s choice with regard to signal type (single-ended vs. differential), output format (single phase vs. multiple phase), and tuning method. Simple mathematical expressions are developed describing the noise-power tradeoffs for each type of stage, so the designer can quickly estimate the power dissipation required to achieve a desired level of jitter.
The Designer’s Guide to Jitter in Ring Oscillators is an excellent resource for engineers and researchers interested in jitter and ring oscillators and their application in communication systems.
Written for:
Circuits and systems designers
Keywords:
- Low Jitter Oscillators
- McNeill
- Ricketts
- design optimization
- measurement techniques
- probability background
- system level behavioral simulation
- time domain applications
