查看: 26505|回复: 103
变容管: Design and Characterization of Integrated Varactors for RF Applications
发表于 2008-8-11 22:17:11 | 显示全部楼层 |阅读模式
登录/注册后可看大图
[size=120%]Design and Characterization of Integrated Varactors for RF Applications
By Inigo Gutierrez, Juan Meléndez, Erik Hernández
  • Publisher:   Wiley
  • Number Of Pages:   180
  • Publication Date:   2007-02-16
  • ISBN-10 / ASIN:   0470025875
  • ISBN-13 / EAN:   9780470025871
  • Binding:   Hardcover
Product Description:
Varactors are passive semiconductor devices used in electronic circuits, as a voltage-controlled way of storing energy in order to boost the amount of electric charge produced. In the past, the use of low-cost fabrication processes such as complementary metal oxide semiconductor (CMOS) and silicon germanium (SiGe) were kept for integrated circuits working in frequency ranges below the GHz. Now, the increased working frequency of radio frequency integrated circuits (RF ICs) for communication devices, and the trend of system-on-chip technology, has pushed the requirements of varactors to the limit. As the frequency of RF applications continues to rise, it is essential that passive devices such as varactors are of optimum quality, making this a critical design issue. Initially describing the physical phenomena that occur in passive devices within standard IC fabrication processes, Design and Characterization of Integrated Varactors for RF Applications goes on to:
  • present information on the design of wide band electrical varactor models (up to 5 GHz) which enable the accurate prediction of device performance;
  • propose a specific methodology for the measurement of integrated varactors, covering on-wafer measurement structures, the calibration process, and detailed descriptions of the required equipment;
  • explain de-embedding techniques and also analyse confidence level and uncertainty linked to the test set-up;
  • examine the design of a voltage controlled oscillator (VCO) circuit as a practical example of the employment of methods discussed in the book.
Providing the reader with the necessary technical knowledge for dealing with challenging VCO designs, this book is an essential guide for practising RF and microwave engineers working on the design of electronic devices for integrated circuits. It is also a useful reference for postgraduate students and researchers interested in electronic design for RF applications.
Design and Characterization of Integrated Varactors for RF Applications.rar
1.74 MB, 下载次数: 792 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-8-11 23:21:59 | 显示全部楼层
真没想到做varactor都能写本书,佩服!
发表于 2008-8-12 01:14:57 | 显示全部楼层
thanks for your information..........................
thanks..........................................................
发表于 2008-8-12 02:27:47 | 显示全部楼层
Thanks, this is great
发表于 2008-8-12 03:21:35 | 显示全部楼层
thanks
发表于 2008-8-12 05:16:37 | 显示全部楼层
是看有人用这个东西的。谢谢楼主
发表于 2008-8-12 08:18:36 | 显示全部楼层
哦的神啊。继续支持ing。。。
发表于 2008-8-12 08:45:44 | 显示全部楼层
谢谢楼主
发表于 2008-8-12 08:50:34 | 显示全部楼层
thanks
发表于 2008-8-12 10:12:25 | 显示全部楼层
thanks!
GMT+8, 2025-11-1 12:58 , Processed in 0.019867 second(s), 7 queries , Gzip On, Redis On.
