查看: 38|回复: 1
[转贴] tessent top extract bsdl 怎么控制选择child_design 的BondingConfigurations
发表于 昨天 15:58 | 显示全部楼层 |阅读模式
悬赏200资产未解决
背景:
   同一个child block 内有2组BondingConfiguration, 一组是partial bscan ports, 另一组是all bscan ports.
   在top 抽bsdl 时候, 默认只抽partial port 那组bsdl。
   如下是manual 的描述:
   Any BondingConfiguration bypasses must be at the block level. Define these in the tcd_bscan file within a SegmentSelection wrapper. You can run Tessent Shell at the block level and use the BondingConfigurations wrapper to create these bypasses. For extraction, choose a configuration by applying the appropriate enable signal values. You can only extract one configuration at a time.
问题:
   top 抽bsdl 时,constraint enable = 0(enable =1,bypass all_bscan_port 内, partial bscan port 之外的部分) 选中all port那一组, 结果抽出来,还是partial bscan ports.
   抽出来的,始终都是partition bscan ports。
   请教大神,在top, 怎么才能把all bscan port 那一组抽出来? 换言之,怎么才能正确选中想要的SegmentSelection?
 楼主| 发表于 昨天 17:21 | 显示全部楼层
补充:
  (1)抽得上,和抽不上来的port, unused_tcd_bscan_external_port 属性都是false
  (2)child-block 的all bscan ports 和partial port 的bscan pat,都是仿真pass 的。
GMT+8, 2025-12-13 02:45 , Processed in 0.011423 second(s), 3 queries , Gzip On, Redis On.
