查看: 263|回复: 2
sent@urus的例子没法运行
发表于 7 天前 | 显示全部楼层 |阅读模式
有没有大佬知道为啥sentaurus的Mystic_tutorial 这个例子运行到一半就会报错呀
Total run time: 0hr 0min 26s
free(): invalid pointer
Finished: Tue Oct 21 01:59:28 EDT 2025
/home/centos_stu/Program/sentaurus/STDB/Applications_Library/GettingStarted/tcadtospice/mystic/Mystic_tutorial/n3896_/Mystic/3896-low-drain/batch_script_1: line 7: 170527 Aborted                 $STROOT/bin/Mystic /home/centos_stu/Program/sentaurus/STDB/Applications_Library/GettingStarted/tcadtospice/mystic/Mystic_tutorial/n3896_/Mystic/3896-low-drain/a7766954fb82a73d -d /home/centos_stu/Program/sentaurus/STDB/Applications_Library/GettingStarted/tcadtospice/mystic/Mystic_tutorial/enigma/mongodb.conf -m /home/centos_stu/Program/sentaurus/STDB/Applications_Library/GettingStarted/tcadtospice/mystic/Mystic_tutorial/./pp3896_mys.mod -ds 3896-low-drain
+--------------------- Traceback (most recent call last) ----------------------+
| <string>:11 in <module>                                                      |
| /remote/swefs1/PE/products/tcad/x2025.09_rel/clientstore/tcad_x2025.09_rel_b |
| uild2/enigma/lib/python3.11/site-packages/enigma/enigma3.py:806 in           |
| run_script        |
| [Errno 2] No such file or directory: '/remote/swefs1/PE/products/tcad/x2025. |
| 09_rel/clientstore/tcad_x2025.09_rel_build2/enigma/lib/python3.11/site-packa |
| ges/enigma/enigma3.py'                                                       |
| uild2/enigma/lib/python3.11/site-packages/enigma/enigma3.py:802 in           |
| run_script        |
| /home/centos_stu/Program/sentaurus/STDB/Applications_Library/GettingStarted/ |
| tcadtospice/mystic/Mystic_tutorial/n3896_eng.py:16 in <module>               |
|   13        |
|   14 mystic.inputfile  = mystic_inputfile1                                   |
|   15 mystic.args.model = initial_modelcard                                   |
| ❱ 16 mystic(previous=None,   dataset=f"{node}-low-drain")                    |
|   17        |
|   18 mystic.inputfile  = mystic_inputfile2                                   |
|   19 mystic.args.model = None                                                |
| uild2/enigma/lib/python3.11/site-packages/enigma/apps/base.py:321 in         |
| __call__        |
| ges/enigma/apps/base.py'                                                     |
| uild2/enigma/lib/python3.11/site-packages/enigma/apps/mystic.py:118 in       |
| simulate        |
| ges/enigma/apps/mystic.py'                                                   |
| uild2/enigma/lib/python3.11/site-packages/enigma/apps/base.py:435 in         |
| simulate        |
| uild2/enigma/lib/python3.11/site-packages/enigma/apps/mystic.py:96 in _wait  |
| uild2/libjambon/lib/python3.11/site-packages/libjambon/frontend.py:688 in    |
| wait_local        |
| 09_rel/clientstore/tcad_x2025.09_rel_build2/libjambon/lib/python3.11/site-pa |
| ckages/libjambon/frontend.py'                                                |
JobError: Some backend jobs have failed. Please check the Enigma screen output
for a list of failed jobs
ERROR on evaluation of Python script
 楼主| 发表于 5 天前 | 显示全部楼层
有没有大佬知道为啥在sprocess调用topo的时候,这段代码topo define_etch_machine name=depo_machine model=depo_model species_distribution=Ti_distribution 明明在命令行状态下能够运行,可是在swb里面就运行不了,这是为啥呢?
 楼主| 发表于 4 天前 | 显示全部楼层
顶一顶
GMT+8, 2025-10-28 22:21 , Processed in 0.018887 second(s), 5 queries , Gzip On, Redis On.
