查看: 371|回复: 1
Introducing Ranplan Professional 7.1
发表于 2025-9-29 14:42:07 | 显示全部楼层 |阅读模式
Advancing 3D Visualization, 5G Optimization and BIM/IFC Workflow Efficiency
As modern network deployments become more complex, the need for open integration, high-performance solutions, and automated workflows continues to grow. Engineers and planners require tools that not only enhance accuracy but also simplify operations, accelerating project execution and improving overall efficiency. This latest release empowers professionals to design networks with greater ease and precision.
Enhanced 3D View for Improved Usability and Performance
Building on the foundation of the new 3D view introduced in version 7.0, this update brings major usability improvements and expanded functionality.
  • Improved UI: A new side navigator for easy access to tools.
  • Dynamic Project Tree & Layer Management: Improved visibility and control over project elements.
  • Customizable Material & Device Display Settings: Modify base colour, texture, opacity, metallic, roughness, and advanced textures.
  • Advanced Search Functionality: Quickly locate project elements, layers, materials, and devices.
  • Light & Dark Mode Support: Adapt to different working environments.
  • Performance Boost: Faster interactions for an optimized workflow.
Introducing Instance-Based Models
Take full control of building models with an intuitive and efficient workflow, including seamless model creation, management, and sharing:
  • Instance-Based BIM Models: Create, reuse, and modify building elements efficiently. Modelled elements are saved automatically for easy reuse.
  • Model Library & Default Models: Import/export models effortlessly and access preloaded default models for quick implementation.
  • Expanded Format Support: Import and export models in both Mesh and IFC formats, improving interoperability.
  • Performance Enhancements: Optimized handling of large-scale models for improved efficiency and faster processing.
Greater IFC/BIM Management
  • Enhanced IFC/BIM Import Controls: Select which layers, objects, and structures to import, ensuring only relevant data is included.
  • Seamless Building Merging: Easily copy and transfer building data between different IFC files.
5G Multi-TRP for MIMO Enhancement
Optimize 5G network performance and reliability by leveraging Multi-TRP technology, enhancing both capacity and signal reliability in industrial and high-density environments:
  • Joint Transmission Mode: Increases data capacity using multiple transmission points.
  • Spatial Diversity Mode: Enhances reliability by reducing signal degradation and improving coverage consistency.
  • Comprehensive Evaluation & Optimization: Analyze Multi-TRP effects within System Performance Evaluation (SPE) and Wireless Network Simulation (WNS).
Device Mounting Type for Realistic Modelling
Easily define and modify mounting types for devices to reflect real-world installation scenarios, with automatic adjustments to antenna patterns:
  • Mounting Type Options: Assign Ceiling, Wall, or Ground within Ranplan Device Hub.
  • Post-Placement Modifications: Change mounting types after placement.
  • Automatic Antenna Pattern Rotation: Ensures accurate signal representation.
  • Seamless Report Integration: Mounting type details included in Antenna EIRP and Link Budget reports.
Customizable Labels and Smart Cable Routine
Improve label management and streamline cable routing for better project visualization and reporting:
  • Flexible Label Customization: Modify text style, alignment, background, border, and fill colours to match your project needs.
  • Organized Label Management: Device labels are managed within device settings, while system labels are controlled through system settings for structured organization.
  • Smart Cable Routine & Placement: Automatically define cable and label placement based on configuration settings, or manually adjust labels for precise positioning while maintaining device placement.
Streamlined Simulation and KPI Management
Enhance accuracy and efficiency in simulations and compliance tracking with intuitive new tools:
  • One-Click Exclusion of Buildings & Foliage: Refine outdoor calculation areas effortlessly.
  • Multi-Region KPI Support: Set distinct compliance targets for indoor and outdoor environments within a single KPI.
  • Improved Performance for Large Projects: Creation of mesh-based regions enhances indoor and outdoor calculation speeds and PDF export efficiency.
发表于 2025-9-29 19:44:31 | 显示全部楼层
thanks
GMT+8, 2025-10-16 17:35 , Processed in 1.545422 second(s), 4 queries , Gzip On, Redis On.
