查看: 1386|回复: 18
[资料] [2025]Long Range Inductive Power Transfer
发表于 2025-9-27 09:42:07 | 显示全部楼层 |阅读模式
Overview
Authors:
Yijie Wang , Jianwei Mai , Peng Gu , Dianguo Xu
Analysis of Key Factors for Weakly Coupled Inductive Power Transfer
Analysis and Design of Novel Magnetic Coupling Structures
Typical Application Scenarios for Long Range Inductive Power Transfer
Long Range Inductive Power Transfer.pdf (16.59 MB , 下载次数: 273 )
This book is inductive power transfer (IPT) in power electronics. In order to improve the coupling coefficient, improve the quality factor, and control the harmonics, the method of analysis and design of the IPT system is proposed. By increasing the coupling coefficient of the magnetic coupling structure and improving the quality factor of the system, the efficiency of the system is improved and the distance of IPT is extended. The applicable readers are scholars, undergraduates and postgraduates in the field of power electronics.
发表于 2025-9-27 10:09:54 | 显示全部楼层
学习一下,谢谢!
发表于 2025-9-27 12:11:57 来自手机 | 显示全部楼层
学习学习
发表于 2025-9-27 13:31:54 | 显示全部楼层
Thanks for sharing
发表于 2025-9-27 13:58:50 | 显示全部楼层
正在做IPD的设计和仿真,学习一下
发表于 2025-9-27 14:32:08 | 显示全部楼层
Good.
发表于 2025-9-27 17:32:25 | 显示全部楼层
谢谢分享
发表于 2025-9-27 17:38:49 | 显示全部楼层
学习学习
发表于 2025-9-27 23:34:14 | 显示全部楼层
kankan
发表于 2025-9-28 08:51:49 | 显示全部楼层
感谢分享
GMT+8, 2025-12-27 07:46 , Processed in 0.020325 second(s), 4 queries , Gzip On, Redis On.
