查看: 577|回复: 1
[求助] tessent 串 scan链,很多没有上chain
发表于 2025-9-18 14:40:08 | 显示全部楼层 |阅读模式
//  Warning: Model 'DRNQV0_12TUL40' has no muxscan scan equivalent and is treated as nonscan model
//  Warning: Model 'DRNQV0_12TR40' has no muxscan scan equivalent and is treated as nonscan model
//  Warning: Model 'DRNQV2SC_12TL40' has no muxscan scan equivalent and is treated as nonscan model
//  Warning: Model 'DSNQV0_12TR40' has no muxscan scan equivalent and is treated as nonscan model
//  Warning: Model 'DRNQV2_12TUL40' has no muxscan scan equivalent and is treated as nonscan model
//  Warning: Model 'DRNQV2_12TR40' has no muxscan scan equivalent and is treated as nonscan model
//  Warning: Model 'DQV0_12TR40' has no muxscan scan equivalent and is treated as nonscan model
//  Warning: Model 'DQV2_12TL40' has no muxscan scan equivalent and is treated as nonscan model
//  Warning: Model 'DRNQV0_12TL40' has no muxscan scan equivalent and is treated as nonscan model
//  Warning: Model 'DQV0_12TL40' has no muxscan scan equivalent and is treated as nonscan model
//  Warning: Model 'DRNQV2SC_12TUL40' has no muxscan scan equivalent and is treated as nonscan model
//  Warning: Model 'DRNQV8SC_12TUL40' has no muxscan scan equivalent and is treated as nonscan model
//  Warning: Model 'DRNQV2_12TL40' has no muxscan scan equivalent and is treated as nonscan model
看读入的fastscan库里面带个前缀S就是对应的scan cell 为什么工具不能替换,导致很多warning,
流程是直接改的tessent demo流程,因为是在不太懂,demo读的是rtl然后加edt occ,综合,插scan链,我直接读入综合网标,插入edt occ,然后再次综合,插入scan链,纯新手,只能改改scan library,其他实在不会改
希望路过的dft 大佬指点一下小弟
发表于 2025-9-28 15:29:33 | 显示全部楼层
可能是mdt里面找不到对应的nonscan_model导致的吧
GMT+8, 2025-11-4 19:34 , Processed in 0.150008 second(s), 3 queries , Gzip On, Redis On.
