查看: 425|回复: 2
在运行 Cadence VIP for PCIe-6 时遇到如下错误。运行 gen6_pipe_ep_dut 时出现该错误,需要帮助解决。
发表于 2025-9-17 21:27:32 | 显示全部楼层 |阅读模式
~/workspace/pcie_cdn_vip/pcie/examples/using_config_object/gen6_pipe_ep_dut$ ./example_setup_xrun.csh
**** cdn_vip_setup_env (WARNING): Install option specified for existing directory /user/workspace/pcie_cdn_vip/pcie/examples/using_config_object/gen6_pipe_ep_dut/vip_lib ****
        Executing Cadence VIP Installation script for Xcelium.
        This will take a few minutes. Please wait...
        Cadence VIP Installation script for Xcelium completed successfully.
**** cdn_vip_setup_env (WARNING): Over-writing existing cdn_vip_env_xrun_sv_uvm_64.csh ****
**** cdn_vip_setup_env:: Created cdn_vip_env_xrun_sv_uvm_64.csh with environment setup commands (xrun in mode 2s/64-bit mode). [2 warnings] ****
**** Please execute the following command to setup your environment:
        source cdn_vip_env_xrun_sv_uvm_64.csh
**** cdn_vip_setup_example (WARNING): The option "-cdnsvlib" is deprecated. By default examples are now setup with the SV integration library for IES and XM ****
**** cdn_vip_setup_example (WARNING): Over-writing existing cdn_vip_run_xrun_sv_uvm_64.sh ****
**** cdn_vip_setup_example:: Created cdn_vip_run_xrun_sv_uvm_64.sh with simulator compile/run commands (xmsim/64-bit mode). [2 warnings] ****
**** cdn_vip_check_env:: Completed All Environment Checks for xmsim in mode 2s/64-bit mode (0 warnings) ****
TOOL:        xrun(64)        23.03-s007: Started on Sep 17, 2025 at 12:39:19 EET
xrun(64): 23.03-s007: (c) Copyright 1995-2023 Cadence Design Systems, Inc.
TOOL:        xrun(64)        23.03-s007: Exiting on Sep 17, 2025 at 12:39:19 EET  (total: 00:00:00)
TOOL:        xrun(64)        23.03-s007: Started on Sep 17, 2025 at 12:39:20 EET
Loading snapshot worklib.tb:sv .................... Done
SVSEED default: 1
xcelium> source /user/tool/cadence/XCELIUM2303/tools/xcelium/files/xmsimrc
xcelium> source /user/tool/cadence/XCELIUM2303/tools/methodology/UVM/CDNS-1.1d/additions/sv/files/tcl/uvm_sim.tcl
xcelium> run
CDNS-UVM-1.1d (23.03-s007)
(C) 2007-2013 Mentor Graphics Corporation
(C) 2007-2013 Cadence Design Systems, Inc.
(C) 2006-2013 Synopsys, Inc.
(C) 2011-2013 Cypress Semiconductor Corp.
  ***********       IMPORTANT RELEASE NOTES         ************
  You are using a version of the UVM library that has been compiled
  with `UVM_NO_DEPRECATED undefined.
  See http://www.eda.org/svdb/view.php?id=3313 for more details.
  with `UVM_OBJECT_MUST_HAVE_CONSTRUCTOR undefined.
  See http://www.eda.org/svdb/view.php?id=3770 for more details.
      (Specify +UVM_NO_RELNOTES to turn off this notice)
Testbench tb_pcie_ep.v
Parameter tb.linkWidth = 8
UVM_INFO @ 0.0ns: reporter [RNTST] Running test gen6Init...
UVM_INFO cdnPcieUvmUserEpDutSve.sv(41) @ 0.0ns: uvm_test_top.pcieSve0 [SVE] In Build Phase
UVM_INFO cdnPcieUvmUserARcPEpEnv.sv(37) @ 0.0ns: uvm_test_top.pcieSve0.ARcPEpEnv0 [cdnPcieUvmUserARcPEpEnv] In Build phase
UVM_INFO /user/tool/cadence/VIPCAT11.30.074/tools.lnx86/denali_64bit/ddvapi/sv/uvm/pcie/cdnPcieUvmAgent.sv(122) @ 0.0ns: uvm_test_top.pcieSve0.ARcPEpEnv0.activeRc [cdnPcieUvmRcUserAgent] In Build Phase. connecting to signals at: 'tb.denali_model'
*Denali* Trace function enabled for Denali verification suite.
*Denali* History enabled for Denali verification suite.
*Denali*     Debug information will also be saved.
*Denali*                Cadence Purespec(TM), PureSuite(TM), MMAV(TM) Version 11.30.074
*Denali*  Copyright (c) 1996-2020 Cadence Design Systems, Inc. All Rights reserved worldwide.
# THIS SOFTWARE AND ON-LINE DOCUMENTATION CONTAIN CONFIDENTIAL AND
# PROPRIETARY INFORMATION OF CADENCE DESIGN SYSTEMS, INC.  UNAUTHORIZED USE,
# VIEWING, DISCLOSURE, OR DISTRIBUTION IS STRICTLY PROHIBITED.
# GLIB: Copyright (C) 1995-1997 Peter Mattis, Spencer Kimball and Josh MacDonald
#       See $DENALI/lib/LICENSE.glib for details.
# Judy: Copyright (C) 2000 - 2002 Hewlett-Packard Company
#       See $DENALI/lib/LICENSE.judy for details.
# libbacktrace: Copyright (C) 2012-2016 Free Software Foundation, Inc.
#       See $DENALI/lib/LICENSE.libbacktrace for details.
# ubiqx: Copyright (C) 1997 by Christopher R. Hertel
#       See $DENALI/lib/LICENSE.ubiqx for details.
*Cadence VIP* ERROR: *Cadence VIP* ERROR: failed to checkout VIP_PCIE_6
*Denali* Fatal error: Unable to continue simulation.
TOOL:        xrun(64)        23.03-s007: Exiting on Sep 17, 2025 at 12:39:22 EET  (total: 00:00:02)
发表于 2025-9-18 03:22:57 | 显示全部楼层
Isn't this pointing out a missing license feature in your license ?
 楼主| 发表于 2025-9-18 17:12:34 | 显示全部楼层
*Cadence VIP* ERROR: failed  ...
Yes, do you know how to add it?
I need it to learn how to use it.
GMT+8, 2025-9-29 10:10 , Processed in 0.015063 second(s), 3 queries , Gzip On, Redis On.
