查看: 1487|回复: 18
RockyLinux8.10虚拟机,启动pt报错
发表于 2025-8-17 01:28:31 | 显示全部楼层 |阅读模式
VMware版本:17.6.3
RockyLinux版本:8.10
scl版本:2025.03
pt版本:W-2023.12-SP2
在终端输入命令pt_shell启动时会报错:
Synopsys/prime/V-2023.12-SP2/linux64/syn/bin/pt_shell_exec: symbol lookup error: /lib64/libkrb5.so.3: undefined symbol: krb5int_c_deprecated_enctype, version k5crypto_3_MIT
求大神邦邦!!!
发表于 2025-8-17 10:52:38 | 显示全部楼层
同问,我rocky8.10启动icc2也会报这个错
 楼主| 发表于 2025-8-17 23:01:57 | 显示全部楼层
顶一手
发表于 2025-8-17 23:58:04 | 显示全部楼层
Folks, do you want to use a car without knowing how to change their tires, or do you depend of a mechanic to do it?
Please locate where in your system if you have this file: /lib64/libkrb5.so.3
  1. sudo ldconfig -p | grep libkrb5
    复制代码
Then verify if the application also has a "special" same file for it or if it exists in another path in your systems
  1. sudo find / | grep -iF "libkrb5.so.*"
    复制代码
If exists the file do exists inside the applicaton path or somewhere else, just create a new configuration to make that customization be prioritized by the system.
  1. echo '<path TO THE FOLDER where the correct file exists>' | sudo tee /etc/ld.so.conf.d/syn_pt_vV2023_12_sp2.conf
  2. sudo ldconfig
  3.
    复制代码
check if the customization become the first priority, it should appear at the top
  1. sudo ldcondig -p | grep libkrb5
  2.
    复制代码
Try run the app again...
if the file don't exists anywhere try to mock the application. Find among other files if any of them has the string 'krb5int_c_deprecated_enctype' or 'k5crypto_3_MIT' at the same time
  1. for FILE in $(find / 2>/dev/null | grep 'libkrb5.so.*' )
  2. do
  3.     echo "[${FILE}]: $(sudo strings $FILE | grep -iE 'k5crypto_3_MIT|krb5int_c_deprecated_enctype' | column)"
  4. done
  5.
    复制代码
when you find some that has the exact function then you can create a symlink to it to MOC the application....
  1. ...code to create a symlink....
  2. sudo ldconfig
  3.
    复制代码
Try again...
发表于 2025-8-18 01:02:42 | 显示全部楼层
发表于 2025-8-18 18:47:03 | 显示全部楼层
cyberwillis 发表于 2025-8-17 23:58
Folks, do you want to use a car without knowing how to change their tires, or do you depend of a mec ...
大哥强啊,点赞点赞
发表于 2025-8-18 21:44:48 | 显示全部楼层
我的解决方案是删掉安装目录下 linux64/nwtn/shlib/ 里的 libk5crypto 和 libcrypto
发表于 2025-8-18 22:03:52 | 显示全部楼层
无意冒犯,但这不是比赛。我的解决方案只需要创建一个配置文件,如果出现任何问题,你可以删除它,然后就完事了。另一位同事的解决方案需要删除一个文件,所以如果你的应用在你不知情的情况下停止运行,祝你好运,别忘了你删除了哪个库。
按照你喜欢的方式去做。
 楼主| 发表于 2025-8-19 00:48:29 | 显示全部楼层
First of all, thank you very much for your reply. I have tried a few things based on your response.
First, I located the libkrb5 library, and the result is as follows. Then, I checked for any libraries with duplicate names, and it appears there are none.
Next, I searched for all files named libkrb5.so* that also met two specific conditions. Surprisingly, only the system library contains krb5int_c_deprecated_enctype. This might offer some clues, but unfortunately, based on my understanding, the second method you provided is also not viable.
At the same time, I noticed that Verdi or DocNav also contain related libraries, but both Verdi and DocNav can start up normally, which is also very strange.
 楼主| 发表于 2025-8-19 00:51:29 | 显示全部楼层
GMT+8, 2025-10-17 08:28 , Processed in 0.042914 second(s), 4 queries , Gzip On, Redis On.
