2025年8月份合集
IEEE Transactions on Circuits and Systems I: Regular Papers
IEEE Transactions on Circuits and Systems II: Express Briefs
(txt文件为百度网盘链接,请勿重复下载)
仅供学习交流,请勿商用
压缩包为整个期刊的pdf合集
或选取下方百度网盘链接
TCAS I
SPECIAL ISSUE ON THE 2024 INTERNATIONAL MIDWEST SYMPOSIUM ON CIRCUITS
AND SYSTEMS (MWSCAS)
GUEST EDITORIAL
Special Issue Based on the 67th International Midwest Symposium on Circuits and Systems ...........................................
........................................................................................... M. Onabajo, S. Patón, B. D. Sahoo, and H. Jiang 3731
SPECIAL ISSUE PAPERS
A 430-mA Capacitor Less Analog Assisted Hybrid LDO With Fast Transient Algorithm ............ P. Leduc, X. Fu, and Y. Zhou 3733
An 89.5 dB SNDR 500 kHz BW Largely Passive Fourth-Order Noise-Coupled Delta-Sigma Modulator ..............................
............................................................................................ H. Wang, F. Adin, U.-K. Moon, and G. C. Temes 3744
Secure Controller Area Network (CAN) Transceiver With Embedded Authentication Support ...........................................
................................................................ W. Chen, X. Wen, C. Hong, T. W. Manikas, M. A. Thornton, and P. Gui 3753
Designing Low-Loss Single-Inductor Multiple-I/O (SL–MI/O) CMOS Power Supplies ............. L. Cui and G. A. Rincón-Mora 3766
Real-Time 5.7–5.8 GHz 32-Beam Approximate Discrete Fourier Transform Spectrum Sensor for RF Perception on Xilinx
Sx475T ..... A. Madanayake, U. Kumarasiri, S. Sivasankar, K. Lawrance, B. Gayanath, H. Silva, S. Mandal, and R. J. Cintra 3777
A Fractional Spur Cancellation Technique for Fractional-N Frequency Synthesizers Enabled by Dual Loop Phase Clamping ......
........................................................................................................ T. Yan, J. Jiang, and J. Silva-Martinez 3791
Design of a Contingent Decision Equalizer Using Analog-in-Time Processing for PAMN Wireline Receivers ........................
........................................................................................ A. Abdelaziz, K. Du, M. O. Abouzeid, and T. Musah 3802
REGULAR PAPERS
Analog and Mixed Mode Circuits and Systems
An Analysis and Design Guideline of High-Speed and Low-Distortion Bootstrapped Switches ............ J. Ma, J. Yu, and Y. Hu 3813
Selectivity Versus Noise Trade-Offs in Resistively Driven Passive Switched-Capacitor Infinite Impulse Response Low-Pass
Filters ...................................................... R. Plompen, J. Ponte, S. van Zanten, E. A. M. Klumperink, and B. Nauta 3825
60-dB 70-V/μs Three-Stage Op-Amp With Dual Single-Miller Frequency Compensation in GaN-IC Technology ....................
.................................................................................................... K. Samperi, U. Chatterjee, and S. Pennisi 3839
A Multi-Stage RC Compensation Technique for Decoupling the Transimpedance and BW: Creating High Speed and Low Noise
TIA Designs ................................................................................................ M. B. Babar and G. W. Roberts 3847
(Contents Continued on Page 3730)
(Contents Continued from Front Cover)
A 1.5–2.7 GHz 3-dB NF 32-dB Notch-Depth Channel-Selection Balun-LNA Employing Dual Feedback and Feedforward N-Path
Filter Loops for Advanced Cellular Application .......................................................... D. Lee, S. Yun, and K. Kwon 3861
Optimization of DTC-Based and Harmonic-Mixer-Based Fractional-N PLLs: Comparative Analysis of Jitter and Power
Trade-Offs ..................................................................................... Y. Zhu, M. Osada, H. Zhang, and T. Iizuka 3872
A 500-kS/s Continuous-Time Linear-Exponential Incremental ADC Achieving 90.1-dB DR and 103.1-dB SFDR ...................
.............................................................. W. Lee, H. Han, Y. Kwon, S. Yoon, J. Yoon, S. Lee, M. Jang, and Y. Chae 3886
An 80 MS/s 70.8 dB-SNDR Radiation-Tolerant Semi-Time-Interleaved Pipelined-SAR ADC for Space Applications ...............
....................................................... Z. Li, L. Berti, J. Zhao, Q. Lin, M. Gorbunov, S. Wang, G. Thys, and P. Leroux 3897
A 0.3-mm2 1.3 μW Wireless Monitoring System IC for Hermeticity Testing of Biomedical Implants .................................
.................................................................................................. G. Rodrigues, T. Rabuske, and J. Fernandes 3911
Advancement of High-Impedance Fault Detection in Primary Distribution Systems Using a Sequence Components Energy
Detector .............................................................. P. V. Dhawas, P. P. Bedekar, S. Dambhare, and P. V. Nandankar 3924
An Efficient, Dynamically Adjustable, Multipurpose Ultrasound Digitizer Array in 40 nm CMOS .....................................
.............................................................................................. K. Pelzers, H. Xin, E. Cantatore, and P. Harpe 3935
Design, Implementation, and Analysis of an Integrated Switched Capacitor Analog Neuron for Edge Computing AI
Accelerators .................................... M. Ronchi, S. Di Giacomo, M. Amadori, G. Borghi, M. Carminati, and C. Fiorini 3947
A Compact Wideband SPDT Switch Using Compensating Inductors and Highpass Matching Network ................................
............................................................................................. P. Zhou, G. Shen, W. Feng, Q. Xue, and W. Che 3961
Digital Circuits and Systems and VLSI
Advancements in Content-Addressable Memory (CAM) Circuits: State-of-the-Art, Applications, and Future Directions in the AI
Domain .................................................................................... T. Molom-Ochir, B. Taylor, H. Li, and Y. Chen 3971
Rethinking the Designing of Convolution Engine for Reconfigurable CNN Accelerator Using Sparse-Based Design Scheme ......
........................................................................ Y. Meng, J. Wang, S. Xiang, J. Hou, Z. Lin, K. Mei, and C. Yang 3983
A Design Framework of Heterogeneous Approximate DCIM-Based Accelerator for Energy-Efficient NN Processing ...............
..................................................................................................................... K. Lee, H. Lee, and J. Park 3997
FireFly-S: Exploiting Dual-Side Sparsity for Spiking Neural Networks Acceleration With Reconfigurable Spatial
Architecture ...................................................................... T. Li, J. Li, G. Shen, D. Zhao, Q. Zhang, and Y. Zeng 4007
State-of-the-Art ASCON ASIC Achieving 4.3 Gbps@0.8V and 3.5Tb/J@0.6V Outperforming AES by 25 Times ...................
........................................................................................................................... I. Elsadek, E. Elgendy,
S. Abouzeid, A. Z. Ghonem, J. R. Wallrabenstein, E. MacLean, D. Gardner, S. Aftabjahani, R. Cammarota, and E. Y. Tawfik 4021
A 97.8 GOPS/W FPGA-Based Residual-Block-Aware CNN Accelerator Featuring Multi-Clock PW2 Pipeline and
Adaptive-Resolution Quantization .................................... J. Li, K. Li, K.-F. Un, W.-H. Yu, R. P. Martins, and P.-I. Mak 4031
A Low-Latency, Highly-Pipelined Hardware Architecture for H.266/VVC Dependent Quantization ....................................
............................................................................................................... J. Zhang, W. Bian, and H. Zhang 4040
Multilogic Sense Amplifier With a Circuit for Dynamic Reference Voltage Generation ...................................................
.......................................................................................... Y.-J. Chang, K.-L. Tsai, C. Cheng, and X.-Y. Chen 4052
Hardware-Efficient Architecture for Multiple Quantized Gaussian Noise Generation ......................... K. Choi and I.-C. Park 4064
OFQ-LLM: Outlier-Flexing Quantization for Efficient Low-Bit Large Language Model Acceleration ..................................
................................................................................................... G. Wang, S. Cai, W. Li, D. Lyu, and G. He 4077
FACET: On-the-Fly Activation Compression for Efficient Transformer Training ..... S. Lee, G. Yun, X. T. Nguyen, and H.-J. Lee 4091
Nonlinear Circuits and Systems
Practical Finite-Time Synchronization of Fractional-Order Complex Dynamical Networks With Application to Lorenz’s
Circuit ................................................................................................. C. Wei, X. Wang, J. Lai, and Z. Zeng 4103
Memristor-Emulator-Based Crossbar Array for Object Detection and Recognition .........................................................
................................................................ J. S. Verma, P. Kumar, B. S. Makhdoomi, R. K. Ranjan, and S.-M. Kang 4115
Memristor-Based Circuit Design of Biological Behavior Chain ........... L. Yang, R. Cai, M. Cheng, Z. Ding, S. Li, and Z. Zeng 4127
Knowledge Distillation and Contrastive Learning for Detecting Visible-Infrared Transmission Lines Using Separated Stagger
Registration Network ...................................................................................... W. Zhou, Y. Wang, and X. Qian 4140
Computer Aided Design and Electronic Design Automation
ZDD: A Zero Delay Deviation Variability-Aware Golden Free Hardware Trojan Detection Using Physical Unclonable
Function ................................................................... F. S. Hossain, A. Seum, M. R. Z. Chowdhury, and F. Ahmed 4153
NoCiPUF: NoC-Based Intrinsic PUF for MPSoC Authentication .............................................................................
....................................................... D. Grover, T. Sharma, S. Agarwal, S. S. Rout, Anushka, M. Kumar, and S. Deb 4167
Circuits and Systems for Communications
Hardware Implementation of Projection-Aggregation Decoders for Reed-Muller Codes ..................................................
................................................... M. Hashemipour-Nazari, A. Nardi-Dei, K. Goossens, and A. Balatsoukas-Stimming 4181
VbPWM-Based ADT: An Iterative Deduction Approach Restricting the Traversal of MPWM at the Cost of In-Band SNR ........
.................................................................................................. Y. Xian, K. Gao, S. Ma, K. Li, and J. Wang 4195
Quaternion Recursive Maximum Correntropy and Versoria Criterion Algorithm for Channel Estimation Under Impulsive
Noise ............................................................................... A. Ranjan, S. Yadav, S. Jain, R. Mitra, and M. Uysal 4209
(Contents Continued on Back Cover)
(Contents Continued from Page 3730)
Passive Post-Resonance Tuned Reflectors to Achieve Both 10-bit Phase-Shifting Resolution and Low Insertion Loss Across
20–30 GHz ........................................................................................................... B. Govind and A. Apsel 4223
UniDec: A Unified Factor-Graph-Based Decoder Fully Compatible With 5G NR LDPC/Polar Codes ..................................
.................................................................................. H. Ji, Y. Zhang, Y. Sun, Y. Huang, X. You, and C. Zhang 4235
Dynamic Periodic Event-Triggered Adaptive Prescribed Performance Control of Uncertain Semi-Strict Feedback Systems With
Application ..................................................................................................... X. Xu, M. Hou, and G. Duan 4248
Flexible Quadrature Spatial Modulation: Transmission, Detection, and Implementation ...................................................
.......................................................................... M.-H. Yen, H.-Y. Lu, G.-Y. Li, Y.-C. Xu, Y.-J. Li, and S. P. Azizi 4261
Control Theory and Systems
Observability Verification System Analysis for Observability and Reconstructibility of Probabilistic Logical Control Networks ...
........................................................................................................................ Y. Li, H. Li, and G. Xiao 4273
Bias-Policy Iteration-Based Adaptive Dynamic Programming for Optimal Control of Discrete-Time Nonlinear Systems ............
.......................................................................................................... H. Jiang, X. Li, B. Zhou, and X. Cao 4284
Two-Group Distributed Optimization Under Cooperative-Collaborative Networks With Linear Convergence ..........................
................................................................................................. Z. Dong, S. Mao, W. Du, Y. Jin, and Y. Tang 4297
Byzantine-Resilient Impulsive Control for Bipartite Consensus of Heterogeneous Multiagent Systems .................................
............................................................................... Y. Cui, Z. Zhang, B. Min, C. Zheng, J. Shen, and T. Huang 4309
Adaptive Tracking Control for Nonlinear Fully Actuated Systems With Input Quantization .................... L. Liu and G. Duan 4322
Finite-/Fixed-Time Synchronization of Coupled Memristive Neural Networks With Actuator Nonlinearity and Applications in Secure
Communication .................................................................................. M. Wang, S. Zhu, W. Luo, and Z. Zhang 4334
Pursuit-Evasion Game for Spacecraft With Incomplete Information Under J2 Perturbation ..............................................
............................................................................... Z. Mu, M. Ji, P. Guo, Q. Zhang, B. Xiao, L. Cao, and J. Yu 4346
Power Systems and Electronic Circuits
A Soft-Switching Boost-Type Resonant Forward Converter With Load-Adaptive Efficiency Optimization .............................
.................................................................................................................. W. Zhao, Y. Yang, and T. Qian 4359
A Reconfigurable Wireless Power Receiver With Shared-Inductor Buck-Boost Converter for NFC-Powered Battery-Less Electronic
Shelf Label ................................................................... T.-N. Liu, D.-H. Yao, Y.-A. Ai, C.-W. Liu, and P.-H. Chen 4370
An Improved Dual-Output Five-Level Buck PFC Rectifier With Reduced Switch Count ...... A. Koli, N. Sandeep, and H. Tiwari 4380
Analysis of Inductor Current Ripple Minimization in PV-Fed Modular Multilevel DC–DC Converter With Distributed MPPT
Control .................................................................. V. Sukanya, G. V. Sumesh, S. J. L. Prakash, and B. Bijukumar 4389
TCAS II
SPECIAL ISSUE ON MIDWEST SYMPOSIUM ON CIRCUITS AND SYSTEMS (MWSCAS) 2024
SPECIAL ISSUE ON MWSCAS 2024
An FPGA-Accelerated Platform for Post-FEC BER Analysis of 200 Gb/s Wireline Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . R. Barrie, M. Yang, H. Shakiba, and A. C. Carusone 978
Enabling Long Chain Lengths and High-Throughput for Time-Domain Neuromorphic Computing . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . K. Bergthold, H. Hendy, E. Greenfield, C. Merkel, and T. Das 983
98-dB SNDR Multi-Residue Two-Step Incremental ADC With Two-Capacitor SAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . F. Adin, H. Wang, L. Shi, R. Singh, E. Hancioglu, and G. C. Temes 988
Enhanced U-Net Architecture for Brain Tumor Localization and Segmentation in T1-WeightedMRI . . . . S. Davar and T. Fevens 993
REGULAR PAPERS
A 28.4-to-39.2 GHz Low-Power Injection-Locked Frequency Quadrupler With Reconfigurable Pre-Filter-Amplifier . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . K. Li, Z. Wang, F. Meng, K. Ma, and K. Wang 998
SPECTRUM1k –75 μm Pixels Pitch ICWith In-Pixel Histogramming for X-Ray Color Imaging . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . P. Kmon, R. Kleczek, R. Szczygiel, and G. Wegrzyn 1003
A Neural Network-Enhanced Digital Background Calibration Algorithm for Residue Amplifier Nonlinearity in Pipelined
ADCs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Y. Peng, Z. Lai, H. Wang, J. Zhang, D. Fu, Y. Ni, T. Liu, Z. Lu, X. Peng, and H. Tang 1008
Discharge Correction Under Asymmetric Electrode-Electrolyte Interfaces in Bipolar Stimulation . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . J. Wu, S. Yin, Y. Zhou, and K. Wang 1013
Calibration-Free Edge-Computing IMCMacroWith Direct Current-to-Digital Conversion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . A. Fasolino, R. Liguori, L. Di Benedetto, A. Rubino, and G. D. Licciardo 1018
A 0.2-19GHz Zero-IF Reconfigurable Quadrature Transmitter With T-Coil Matching Network . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . A. Sun, Y. Zeng, H. Qin, H. Xu, R. Yin, X. Shen, L. Bian, and N. Yan 1023
A 28-GHz CMOS Power Amplifier With Adaptive Bias and Phase Compensation for Gain and Phase Linearity Enhancement. . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . L.-C. Tsai, Z.-J. Li, and L.-H. Lu 1028
Parallel and Pipelined BRAM-Based Matrix Transposition for 6G . . . . . . . . . . . . . . . . . . . . J. Chen, C. Yang, X. Zhou, and M. Peng 1033
Improved Disturbance Rejection and Noise Suppression Properties for PMSM Speed Control Systems Using Different Order Fast
Finite-Time Extended State Observers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Q. Hou, H. Wang, S. Ding, C. Ding, and C. H. T. Lee 1038
An Encoding–Decoding-Based State Estimation Scheme for State-Saturated Systems Under Buffer-Aided Mechanism . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . C. Huang, L. Zhu, W. Ding, P. Mei, S. Yang, and Q. Shi 1043
Hybrid Scheduling-Based Asynchronous H∞ Control for Markov Jump Power Systems With Cyber Attacks . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Y. Lu, X. Wu, Y. Wang, R. Wu, Y. Zhong, and J. Xie 1048
Privacy-Preserving Optimal Battery Control for Energy Storage Systems Using Adaptive Dynamic Programming . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . J. Wang and J. Sun 1053
The Three-Stage IdentificationMethod of the SandwichModelWith Hysteresis . . . . . . . . . . . . . . . . . . . . Y. Gu, H. Hou, and Y. Tan 1058
A Benders-Combined Safe Reinforcement Learning Framework for Risk-Averse Dispatch Considering Frequency Security
Constraints . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .J. Feng, Z. Ren, C. Li, and W. Li 1063
A Cost and Speed Co-Optimized Parallel Stochastic Multiplier for Binary Inputs Supporting Variable Bit-Widths . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Q. He, Y. Zhao, Z. Zhang, G. Du, X. Nie, Y. Lu, S. Xiong, and K. Zhao 1068
KV-Cache Oriented Query-Aware Sparse Attention Accelerator With Cross-Stage Precision-Configurable Digital CIM . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Y. Zhang, X. Kang, W. Wang, Y. Ding, L. Ren, Y. Zhang, R. Tan, Z. Wang, H. Cai, and B. Liu 1073
Efficient Hardware Architecture Design of K-Means Clustering Algorithm for AV1 Palette Mode Coding . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . X. Huang, J. Lin, F. Liu, W. Ji, H. Yin, and S. Ma 1078
HIMAM: Hardware Implementation of Multiply-and-Max/Min Layers for Energy-Efficient DNN Inference . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . F. Spagnolo, P. Corsonello, and S. Perri 1083
UniPRE: An SNN-ANN Accelerator With Unified Max-Pooling Prediction and Redundancy Elimination . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . T. Zhang, Y. Zhong, Y. Yang, Z. Wang, Z. Zhang, and Y. Wang 1088
Single-Event Upset Monitor-Based Radiation-Hardened Latch for Multi-Node Upset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Z. Zheyu, L. Hainan, L. Duoli, M. Quangang, Z. Wenxin, Y. Zhenzhen, and L. Bo 1093
Body-Biased Hybrid Sense Amplifier With High Offset Tolerance for Low-Voltage SRAMs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . M. Jia, P. Zhao, L. Li, X. Li, Z. Li, H. Zhao, and S. Qiao 1098
A Switch-as-Resistor Self-Adaptive Gate-Biasing Technique for Optimized Forward and Reverse Conduction in a CMOS Rectifier
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Y. C. Lee, H. Ramiah, T. S. Ho, F. Q. Chua, W. X. Lian, K. K. P. Churchill, and Y. Chen 1103
A 1.8–5.5-V LDO–BGR System With LACM Buffer for High PSRR in Camera Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . W.-G. Kim, S.-Y. Nam, Y.-J. Jeon, and S.-W. Hong 1108
Small-Signal Modeling of an S-S Compensated IPT System Under Frequency Modulation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . T. Li, G. Zheng, C. Qi, H. Wang, Y. Liu, and M. Fu 1113
Bumpless Transfer Control for Discrete Semi-Markov Switching Power System With Cyber Attack . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Z. Li, W. Qi, J. H. Park, and Z.-G. Wu 1118
Signal Processing
Mamba-Unet-Depth: Enhancing Long-Range Dependency for Photon-Efficient Imaging . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Y. Pu, C. Zhu, G. Yao, Y. Pan, K. Yang, and Q. Yang 1123
TCASI_2508.part1.rar
30 MB, 下载次数: 64
, 下载积分:
资产 -9 信元, 下载支出 9 信元
1.1
TCASI_2508.part2.rar
30 MB, 下载次数: 58
, 下载积分:
资产 -9 信元, 下载支出 9 信元
1.2
TCASI_2508.part3.rar
30 MB, 下载次数: 62
, 下载积分:
资产 -9 信元, 下载支出 9 信元
1.3
TCASI_2508.part4.rar
30 MB, 下载次数: 58
, 下载积分:
资产 -9 信元, 下载支出 9 信元
1.4
TCASI_2508.part5.rar
12.16 MB, 下载次数: 56
, 下载积分:
资产 -5 信元, 下载支出 5 信元
1.5
TCASII_2508.part1.rar
30 MB, 下载次数: 54
, 下载积分:
资产 -9 信元, 下载支出 9 信元
2.1
TCASII_2508.part2.rar
17.59 MB, 下载次数: 62
, 下载积分:
资产 -6 信元, 下载支出 6 信元
2.2
TCAS_I_Table_of_Contents.pdf
91.73 KB, 下载次数: 15
, 下载积分:
资产 -2 信元, 下载支出 2 信元
Table1
TCAS_II_Table_of_Contents.pdf
368.3 KB, 下载次数: 14
, 下载积分:
资产 -2 信元, 下载支出 2 信元
Table2
TCAS2508.txt
166 Bytes, 下载次数: 22
, 下载积分:
资产 -2 信元, 下载支出 2 信元
售价: 30
信元资产
[记录]
Baidu Wangpan
