查看: 875|回复: 8
Design Compiler Encrypt
发表于 2025-8-13 18:28:35 | 显示全部楼层 |阅读模式
I used Design Compiler Encryption to encrypt a file,  but encountered an error related to license.
Although I had licenses, after the tool was patched with SynopsysMonoSlayer, it no longer appeared in the license server log.
/synopsys/syn/X-2025.06/linux64/syn/bin/synenc code.v
Information: License queuing is enabled. (SYNENC-12)
Error: This site is not licensed for 'DesignWare'. (SEC-51)
Error: This site is not licensed for 'DW-Developer'. (SEC-51)
发表于 2025-8-14 09:44:17 | 显示全部楼层
May the the 2025 version patched incompletely
发表于 2025-8-14 09:54:42 | 显示全部楼层
发包。否则没法试
发表于 2025-8-14 12:31:36 | 显示全部楼层
似乎是license feature 缺少DesignWare 及 DW-Developer
 楼主| 发表于 2025-8-14 14:24:53 | 显示全部楼层
This issue seems to be related to SynopsysMonoSlayer. Because after I patched the tool, I did not see it checking license in log file.
 楼主| 发表于 2025-8-14 14:26:58 | 显示全部楼层
Yes. I think so. I tried not only ver X-2025 but also ver W-2024.
发表于 2025-11-1 19:39:41 | 显示全部楼层
百度网盘共享一下24和25的DC,下载试试呗
发表于 2025-11-2 12:19:51 | 显示全部楼层
是你自己问题,  我用dc 2018加密代码没问题
发表于 2025-11-2 17:29:05 | 显示全部楼层
SynopsysMonoSlayer is not valid for 2024.09 version.
GMT+8, 2025-11-18 13:38 , Processed in 0.021409 second(s), 5 queries , Gzip On, Redis On.
