查看: 709|回复: 5
CYMCAP 9.0 and CYME 9.5 (2025 Versions)
发表于 2025-8-10 06:23:33 | 显示全部楼层 |阅读模式
CYME Power Engineering Applications for Distribution Network/System Analysis
To perform several types of analysis on balanced or unbalanced three-phase, two-phase and single-phase systems that are operated in radial, looped or meshed configurations. CYMDIST includes a full Network Editor as well as
- Unbalanced load flow
- Comprehensive fault flow analysis
- Load balancing
- Load allocation/estimation
- Optimal capacitor placement
Supports the collaborative and detailed preparation of a project that consists in modifications to the network with related simulations.
To create, view and modify time-dependent projects (using the CYME Advanced Project Manager) consisting in modifications to the network such as the addition of any load at a given date, change/replacement of power transformers within a substation, a rephasing/reconductoring project, network switching or reconfiguration, etc.
To perform accurate time range analysis based on a combination of AMR data and historical consumption patterns.
To analyze the unbalanced power flow and the voltages at every level of a distribution power system.
Provides a framework within which predictive and historical reliability assessment scenarios are run and the impacts of the related investment such as DA (Distribution Automation) can be evaluated and understood.
Facilitates the evaluation of the feasibility and the profitability of a project based on the factual system model.
To simulate the dynamic behavior of distribution systems with distributed generation under various transient events (fault application/clearing, large motor starting, disconnection of co-generation units, islanding, etc.)
Performs harmonic penetration analysis in electric power systems. It features single phase and full three-phase modeling capabilities and includes a large library of pre-defined models for network equipment and harmonic current sources.
The Frequency scan capability included in this module is also available as an independent module. This analysis provides full impedance scan results and allows the user to see problematic areas even before installing harmonic devices.
Time-series simulation to study the impact of irradiance variations, wind fluctuations and load variations on network controls such as regulators, load tap changers and switched capacitors, and on the behavior of battery energy storage devices.
Addresses DER and load interconnection issues by determining the maximum allowable capacity that can be added at any point of the network without violating a set of constraints. Allows to quickly assess the hosting capacity of the network and filter out interconnection requests that are non-compliant.
The calculation method provides aggregate and granular hosting capacity results for each distribution feeder and considers numerous circuit-specific attributes.
Assists engineers in their generation interconnection system impact studies. The analysis automates a series of time-consuming, repetitive and error-prone verifications and returns insightful results that clearly identify violations.
To determine the acceptability of a new load or generator interconnection by evaluating its impact on a series of power quality criteria.
Helps engineers design and verify their protection scheme, and address different coordination issues in any power system.
Module that assists in finding optimal settings for Volt/VAR control devices to optimize distribution networks.
Allows the installation of voltage regulators at optimal locations on a distribution feeder.
Designed to help engineers handle the complexity of the system reliability improvement issue.
To analyze and promote the electrical safety for employees working on or near electrical equipment. It computes the necessary parameters required to assess the risk level and adopt the adequate safety procedures.
Two modules are available to address specific needs. One for distribution networks, with arc flash hazards calculations based on the NESC© 2007 standard, and the second one based on the NFPA-70E© and IEEE-1584™ standards to analyze arc flash hazards in industrial power networks.
For the dynamic, locked rotor and maximum start size analyses, dedicated to simulating the effects of induction and synchronous motor starting in three-phase electric power systems.
To assist in power flow related static contingency analysis. To create contingency events and single- or multiple-outage scenarios and compare to a base case.
The module provides engineers with a wide range of tools to efficiently and accurately design and validate the coordination scheme of their power system.
Assists in determining the optimal feeder configuration that will minimize losses, improve the voltage profile and balance the load between feeders.
To study the impact of forced or planned outages on the electrical distribution system and find the optimal switching plan to restore electrical power to priority customers and to recover the maximum possible load in the affected areas.
To model all the major components of the distribution substation and any sub-network such as the detailed modeling of an industrial facility.
Allows the Power Flow and Short Circuit analyzes of heavily meshed secondary grid network distribution systems for any voltage level.
Functionality to model in detail low-voltage distribution systems within a one-line diagram.
To display raster or vector map images (geographical land-base such as DWG, DXF, SHP, etc) as layers directly underneath the electrical model.
Provides the capability to display Google™ maps and MapQuest™ Open maps as layers underneath the geographical view of your electrical network model.
Additional Engineering Applications and Facilities for Distribution:
The following applications are useful to the power engineers:
Scripting tool allows the execution of commands and scripts. Through Python scripts, you can extend the functionalities of the CYME software.
To create and maintain the CYME network data model. The connectivity network extracted from the GIS is accurate, electrically complete, with actual loads and switch status; and this network model can be updated easily.
Generates the time-current characteristic curves for the protective devices of a given feeder. The results can be visualized on-screen, plotted on standard log-log paper and/or routed to various printers. The Arc Flash Hazards analysis module can be added to the CYMTCC software to further complement the analyses.
To optimize the design of new grids and reinforce existing grids, of any shape, by virtue of built-in danger point evaluation facilities.
CYME Power Engineering Applications for Transmission and Industrial Network/System Analysis
The Network Editor is the graphical user interface underlying the CYME analyzes modules. It provides the user with great flexibility in creating the one-line diagram of the network as well as providing a wide variety of options to customize the displays and reports.
All the modules presented in this section require the Network Editor to run.
To perform power flow analysis in three-phase electric power networks. The module utilizes state of the art sparse matrix/vector methods and multiple solution algorithms.
For the determination of short-circuit currents that result from different fault phenomena, the estimation of fault locations, the identification of under-rated equipment in electric power systems and the sizing of various system components.
To help engineers identify arc flash risk levels of their DC network and adopt the necessary safety measures
To select the right type of cable for low voltage installations
To perform harmonic penetration analysis in electric power systems. It features single phase and full three-phase modeling capabilities and includes a large library of pre-defined models for network equipment and harmonic current sources.
The DC Load Flow and Short-Circuit Analysis modules enhance the capabilities of the software to execute simulations on DC back-up systems and safe supplies.
To simulate the electro-mechanical response of an electric power system to transient disturbances. It includes a large library of pre-defined models for network equipment and control systems.
To assess the ability of a power system to maintain stable voltages under different contingencies and loading conditions.
Allows the user to engage in advanced system planning studies to optimize system performance, examine cost-efficient operational planning alternatives, articulate system control strategies and rationalize equipment utilization, resulting in better overall system asset management.
CYMFLOW is recommended to fully benefit from the capabilities of this module.
CYME 9.5 What's New?
Introduction
Welcome the new version of CYME 9.5, where we unveil significant updates and improvements designed to enhance performance and operational efficiency for our users. This document aims to familiarize you with the key changes and upgrades that come with CYME 9.5, ensuring you can make the most of its new features.
In the fast-paced realm of electrical engineering software, staying current with the latest advancements is essential. CYME 9.5 brings a range of new functionalities and enhancements that will elevate your user experience. Significant investments were made to improve the CYME Protective Device Analysis and to develop a new exclusive Time-Series Database (TSDB database). These updates are crafted to optimize your work processes.
Key highlights of CYME 9.5 include:
• Protective Device Analysis:
o New Recloser Technology: Integration of the next generation of recloser technology, featuring Cooper Form 4D and Form 7 closer controls.
o Automatic Transformer Shift Factor Calculations: For systems with transformers, all the time-current curves (TCCs) can now be shifted automatically not only based on the voltage levels, but also on the transformer connections and fault types, such that they are aligned based on their true monitored current.
o Sequence Coordination: The Sequence Coordination functionality of microprocessorbased reclosers is now available and implemented in the Sequence of Operations analysis.
o Improvements to the TCC View: Several enhancements were made to the TCC View tools to improve the user experience.
• Database Enhancements: Added features to assist Database Administrators (DBAs) in maintaining database integrity, including verification tools, special query script tools and
advanced database maintenance options.
• In the context of Long-Term Planning Solution (LTPS), the Steady State Analysis with Profiles – Multiprocessing module is equipped with Time-Series Database (TSDB) which is the new
generation of profile database in CYME that offers enhanced flexibility and improved performance.
• A new planning tool for behind-the-meter technology planning assessment, the CYME Behind-the-meter Scenario Analysis module, addresses the challenges stemming from major increases in grid-edge technologies, helping planners navigate through the energy transition. This first release of the tool will help distribution planners assess multiple scenarios of increased
penetration rates and distribution probabilities for electric vehicles leveraging the CYME model and the profile database.
Overall, CYME 9.5 aims to provide the essential tools and functionalities needed for efficient and effective distribution planning studies. Eaton strives to deliver a powerful yet user-friendly power system analysis software that caters to both simple and advanced engineering studies. For detailed information on each new feature and enhancement, please refer to the reference manuals.
CYMCAP 9.0 Cable Ampacity Calculations
Performs ampacity and temperature rise calculations for power cable installations.
The additional modules listed below require CYMCAP to run.
Determines the steady state ampacity of cables installed in several neighboring duct banks and/or backfills with different thermal resistivity.
Determines the temperature, steady state, cyclic and transient ampacity of cables installed in unventilated tunnels.
Determines the thermal rating of cables installed in filled or in unfilled troughs.
Allows the user to determine the steady state unequally loaded ampacity and/or temperature rating of cables installed in one or more non-magnetic casings buried, laying on the sea bed or completely immersed in water.
Determines the optimal placement of several circuits within a duct bank. More specifically, the module can recommend the various circuit disposition within the duct bank
Computes the magnetic flux density at any point on or above the surface of an underground cable installation.
Calculates the electrical parameters for cables necessary for performing network studies at the power frequency (50/60 Hz).
Calculates the rating of cables for short circuit currents.
To correctly take into consideration the derating effect that two circuits crossing have on the ampacity of each other, depending on their crossing angle.
Evaluates the temperature at which underground cable systems have operated during their in-service life.
What's new in CYMCAP 9.0?
CYMCAP 9.0, the first release in the 9 series and a valuable addition to our Brightlayer Utilities suite, expands our software portfolio with innovative tools, empowering engineers with new modeling capabilities in cable projects requiring precise ampacity calculations in complex cable installations.
CYMCAP 9.0 introduces the CYMCAP 3D Modeling add-on module , a cutting-edge tool that enables a three-dimensional thermal analysis for complex cable installations. It allows modeling non-standard cable geometries that are very often observed in congested areas where multiple circuits are crossing each other in different angles. Additionally, it can be used to analyze effects produced by cable bending, sudden changes in the cable depth, and inclination.
CYMCAP 9.0 presents a new Advanced tunnel modeling add-on module with extended capabilities for modeling and computing steady-state ampacity for multiple dissimilar cables in random geometric arrangements installed in ventilated tunnels.
CYMCAP 9.0 also brings new features and enhancements, aiming to improve the user experience with increased efficiency. In this document, you will find information about enhancements in the performance for the short-circuit rating add-on module, new view for cables crossing visualization, graphical user interface enhancements, new tutorials and more.
New CYMCAP 3D Modeling add-on module
One of the primary assumptions supporting the current methodology for standard ampacity calculations is that the cable laying conditions are unchanged for a large extension. This assumption simplifies the analysis into a two-dimensional problem, where the heat is mainly transferred radially from the conductors to the environment. However, cables installed in congested areas near the substations can involve multiple circuits crossing or changing direction (or depth) to avoid obstacles. These complex cable installations often fall out of the scope of the methodology described in the standards for cable ampacity calculations.
In the absence of a clear methodology for complex cable installations, some companies use conservative approaches that may involve assuming cables running in parallel or introducing derating factors to keep the results on the safe side. Another common practice is to ignore problematic sections, falsely assuming that the impact of short sections is insignificant when compared to the full circuit length. Modeling the installation with a full finite element software is also a possible option. However, this approach requires deep knowledge of cables thermal behavior and strong modeling skills. Sometimes the complexity of the installation can make this process extremely difficult or inefficient.
The CYMCAP 3D modeling module (CYMCAP/3DM) is an optional add-on that enables a threedimensional thermal analysis allowing the user to conduct the steady-state analysis in temperature mode for complex cable arrangements. It can handle non-parallel complex cable geometries and provides valuable insights into the effects produced by bending, sudden changes in cable depth and inclination, or a combination of these factors.
Key benefits
Efficiency and productivity: CYMCAP/3DM is designed to streamline the process of modeling complex cable installations. Completing your models is possible in just a few steps
and within minutes, allowing for rapid prototyping and iterative design processes.
Reliability and validation: CYMCAP/3DM has been rigorously validated against full finite elements software. It has been tested and endorsed by international experts in the field,
ensuring the reliability of the provided results.
Consistency with standards: The methodology builds upon the existing methodology described in the international standards for ampacity calculations. Moreover, results are
consistent with those obtained for cables in parallel and single crossings when following the methodology described in the IEC standard 60287, while also providing new calculations
that go beyond the scope of the standards.
To perform ampacity calculations in a 3D modeling installation, each cable is subdivided into small components (point sources), considering the electrical connection and thermal interaction between components within the same cable and across different cables in the same installation. An iterative methodology computes the temperature rise produced by each component and the heat dissipated in the surrounding medium until convergence is reached in the system.
For more information about CYMCAP 9.0 and CYME 9.5, please contact   fast.forever24@gmail.com
发表于 2025-8-10 21:10:54 | 显示全部楼层
thanks
发表于 2025-8-11 10:27:15 | 显示全部楼层
thans
发表于 2025-8-14 15:25:15 | 显示全部楼层
感谢楼主分享
发表于 2025-8-18 18:03:10 | 显示全部楼层
感谢分享
发表于 2025-9-27 11:46:18 | 显示全部楼层
CYMCAP 9.0 最新最新版联系1739083603@qq.com
GMT+8, 2025-10-7 07:48 , Processed in 0.020396 second(s), 5 queries , Gzip On, Redis On.
