查看: 460|回复: 4
求CONFORMAL (R) 和谐工具
发表于 2025-8-6 09:30:42 | 显示全部楼层 |阅读模式
悬赏150资产未解决
                          CONFORMAL (R)
                   Version 23.20-p100 (23-Nov-2023) (64 bit executable)
   Copyright (c) Cadence Design Systems, Inc., 1997-2023. All Rights Reserved
This program is proprietary and confidential information belonging to
Cadence Design Systems, Inc., and may be used and disclosed only as authorized
in a license agreement controlling such use and disclosure.
// Warning: This version is 621 days old. You can download the latest version from http://downloads.cadence.com.
FlexNet Licensing checkout error: Invalid (inconsistent) license key.
The license key and data for the feature do not match.
This usually happens when a license file has been altered.
Feature:       Conformal_Asic
License path:  /edatools/license/cadence/cadence.dat:
FlexNet Licensing error:-8,523
license file(s):  /edatools/license/cadence/cadence.dat
// Fail to check out Conformal_Asic 23.2 license
// License check failed!
发表于 2025-8-6 09:58:42 | 显示全部楼层
patch过了么?
 楼主| 发表于 2025-8-6 10:06:11 | 显示全部楼层
Lover_Momo 发表于 2025-8-6 09:58
patch过了么?
patch了,应该是做lic的工具问题
 楼主| 发表于 2025-8-6 11:23:24 | 显示全部楼层
patch过了么?
重新做patch.  加FEATURE就可以了
发表于 2025-8-6 11:40:38 | 显示全部楼层
嗯,一般判断就是 确认feature在lic中有没有,如果没有就添加;如果有,可能就是Patch的问题;
GMT+8, 2025-9-22 20:39 , Processed in 0.013433 second(s), 3 queries , Gzip On, Redis On.
