查看: 770|回复: 4
EMTP 4.5 with LIOV and Complete Modules
发表于 2025-7-29 08:25:45 | 显示全部楼层 |阅读模式
EMTP or EMTPWorks or EMTP-RV is one of the most efficient software for advanced analysis and simulation of the transient state of the power system.
The EMTP-RV software is capable of simulating transient states with very high accuracy, but this software does not have a toolbox to calculate the use of databases and iterative solutions in the issue of substation insulation coordination.  For this reason, it is necessary to prepare a program with an emphasis on the possibility of modeling substation equipment in transient conditions so that the topic of insulation coordination in substations can be done easily and at high speed.  On the other hand, due to the fact that these results require statistical analysis and  processing, these items will also be seen in the preparation of the program in order to provide a complete tool to system designers and analysts.
Features and features of EMTP software:
- The very diverse and different examples included in this version is one of its outstanding features.
- The outputs of the software can be seen with the SCOPE VIEW program.
- The output of the plots can be exported to Autocad software.
- Program outputs in different formats can be exported to different environments, including Matlab software, which significantly increases the efficiency of this version compared to other versions. And it is easy to connect simulations in different environments.
- Increasing the speed and improving the graphical interface of the program
- EMTP WORK graphical interface is used in this version of the software. This graphical interface creates a NET LIST from the single-line circuit to be executed in the main program
Other Applications Include
  • Transient Recovery Voltage
  • Large Scale Complex Systems
  • Load-Flow Analysis
  • Railway Systems
  • Renewable Energy Systems
  • Insulation Coordination
  • Geomagnetic Disturbances
  • Transient Stability
  • Power Electronics
  • Switching Transients
  • Power Quality
  • HVDC
  • Microgrid and Very Fast Transients
  • Protection
For more information about  EMTP 4.5 with LIOV and complete features , please contact  fast.forever24@gmail.com
发表于 2025-7-29 09:37:55 | 显示全部楼层
感谢分享
发表于 2025-7-30 03:41:04 | 显示全部楼层
thanks
发表于 2025-8-7 08:38:08 | 显示全部楼层
联系微信:1400155802@qq.com
发表于 2025-11-5 11:12:50 | 显示全部楼层
EMTP-RV (EMTPWorks) 4.5 + LIOV完美联系1400155802@qq.com
GMT+8, 2025-12-19 04:48 , Processed in 0.020609 second(s), 4 queries , Gzip On, Redis On.
