查看: 963|回复: 4
calibre2023和2022license不兼容
发表于 2025-7-23 17:31:33 | 显示全部楼层 |阅读模式
//  Calibre DESIGNrev v2023.2_16.9    Tue Apr 4 17:38:58 PDT 2023
//  Calibre Utility Library   v0-10_13-2017-1    Tue Nov 8 14:13:57 PST 2022
//                  Copyright Siemens 1996-2023
//                       All Rights Reserved.
//   THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
//      WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
//        OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
//  The registered trademark Linux is used pursuant to a sublicense from LMI, the
//  exclusive licensee of Linus Torvalds, owner of the mark on a world-wide basis.
//  Mentor Graphics software executing under x86-64 Linux
//  64 bit virtual addressing enabled
//  ERROR: The following products could not be licensed sufficiently:
//  ERROR: - DESIGNrev
求助大佬为什么我同样的license在calibre2022上面可以正常使用,但是在2023上面会报错呢
 楼主| 发表于 2025-7-23 17:39:05 | 显示全部楼层
找到问题了,我用1patch打patch没用,要用pucky_verify打
发表于 2025-7-23 18:21:35 | 显示全部楼层
lmgrd版本升级了
发表于 2025-8-4 15:24:39 | 显示全部楼层
请问后面那个有包吗
发表于 2025-8-4 18:02:15 | 显示全部楼层
thanks
GMT+8, 2025-12-20 12:57 , Processed in 0.016090 second(s), 4 queries , Gzip On, Redis On.
