查看: 802|回复: 5
[资料] 分享一篇参与的四相位直流升压变换器TCASI
发表于 2025-7-14 10:19:18 | 显示全部楼层 |阅读模式
A Single-Stage Four-Phase Hybrid Boost Converter With 11-to-20 VCRs for LiDAR Driver Applications
Item TypeJournal Article
AbstractThis paper presents a monolithic single-stage, 4-phase switched-capacitor (SC) hybrid boost converter with 11-to- 20\times voltage conversion ratios (VCRs). The 4-phase operating SC hybrid topology is proposed to achieve high VCRs with only three flying capacitors and one inductor. With the SC topology, the average inductor current and the inductor current ripple are much reduced, releasing both power loss and size requirement for the inductor. A four-phase pulse width modulation (PWM) controller is proposed. A successive ramp generation scheme ensures identical pulse widths across three consecutive phases. A driver-assisted auxiliary charge pump provides sufficient driving voltages for the high-side driver and simplifies the overall circuitry. The proposed hybrid boost converter was implemented in a 0.18 \mu m process. The measurement results show that the converter achieved a 20-24V output voltage range with a 1.2-1.8 V input voltage. 76.7% peak efficiency was achieved at 13\times VCR and power density was 12 mW/mm3.
Date2025
Library CatalogIEEE Xplore
URLhttps://ieeexplore.ieee.org/document/11048654/
Accessed6/25/2025, 5:03:36 PM
Pages1-11
PublicationIEEE Transactions on Circuits and Systems I: Regular Papers
DOI10.1109/TCSI.2025.3580499
ISSN1558-0806
不增加电容的数量,如何提高拓扑的升压比,这篇文章提供了一个可能性。
Hu et al. - 2025 - A Single-Stage Four-Phase Hybrid Boost Converter With 11-to-2.pdf
6.73 MB, 下载次数: 24 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2025-7-14 10:59:48 | 显示全部楼层
eetop何德何能,一山能容下二胡
发表于 2025-7-14 23:46:01 | 显示全部楼层
多谢分享
 楼主| 发表于 2025-7-15 17:34:06 | 显示全部楼层
happylly 发表于 2025-7-14 10:59
eetop何德何能,一山能容下二胡
另一个胡是?
发表于 2025-7-15 17:52:32 | 显示全部楼层
胡道擦 发表于 2025-7-15 17:34
另一个胡是?
版主啊,Yizhe Hu教授
 楼主| 发表于 2025-7-21 17:09:36 | 显示全部楼层
happylly 发表于 2025-7-15 17:52
版主啊,Yizhe Hu教授
小弟怎配跟中科大胡教授比
GMT+8, 2025-12-27 01:39 , Processed in 0.020272 second(s), 5 queries , Gzip On, Redis On.
