查看: 833|回复: 4
[资料] 分享下参与的负压Buck芯片TPE论文
发表于 2025-7-12 16:49:58 | 显示全部楼层 |阅读模式
Design and Analysis of a Hybrid Inverting Buck Converter with 5μs Response Time and 92.9% Efficiency for Micro-LED Displays
Item TypeJournal Article
AuthorXingfa Yan
AuthorGang Liu
AuthorChen Hu
AuthorKaisong Zhu
AuthorZhaojun Liu
AuthorXun Liu
AuthorJunmin Jiang
AbstractA hybrid inverting buck (HIB) DC-DC converter with adjustable negative output voltage is designed for micro-LED display applications. The HIB converter achieved a voltage conversion ratio (VCR) of -D and only needs three power switches, one flying capacitor, and one inductor, and brings the benefits of simple buck-like PWM control and a compact volume compared to the existing designs. HIB converter's losses and small-signal model are analyzed and compared with the inverting buck-boost (IBB) and Cuk converters. The proposed HIB converter enables smaller passive components and simplified compensation control with only one pair of complex poles. The advantages include continuous output current capability, fast load transient response, and low output voltage ripple. The converter was fabricated using a 180nm process, and the measured results show that the converter delivers a negative voltage output of -1 to -2V within an input voltage range of 3 to 4V. The converter achieves a transient response time of 5μs, a peak efficiency of 92.9%, a maximum load current of 2.2A, and a maximum voltage ripple of only 10mV.
Date2025
Library CatalogIEEE Xplore
URLhttps://ieeexplore.ieee.org/document/11059803/
Accessed7/2/2025, 9:40:02 AM
Pages1-11
PublicationIEEE Transactions on Power Electronics
DOI10.1109/TPEL.2025.3584285
ISSN1941-0107
Yan et al. - 2025 - Design and Analysis of a Hybrid Inverting Buck Converter wit.pdf
6.73 MB, 下载次数: 59 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2025-7-12 17:32:01 | 显示全部楼层
下载看看,谢谢分享
发表于 2025-7-12 20:52:21 | 显示全部楼层
谢谢分享
发表于 2025-7-12 22:12:41 | 显示全部楼层
多谢分享
发表于 2025-7-13 12:13:13 | 显示全部楼层
Thanks!!!
GMT+8, 2025-12-3 14:19 , Processed in 0.099030 second(s), 4 queries , Gzip On, Redis On.
