查看: 3599|回复: 13
TCM的第一篇经典文章
发表于 2008-3-6 23:06:07 | 显示全部楼层 |阅读模式
A bstruct- A coding technique is described which improves error performance
of synchronous data links without sacrificing data rate or requiring
more bandwidth. This is achieved by channel coding with expanded sets of
multilevel/phase signals in a manner which increases free Euclidean distance.
Soft maximum-likelihood (ML) decoding using the Viterbi algorithm
is assumed. Following a discussion of channel capacity, simple
hand-designed trellis codes are presented for 8 phase-shift keying (PSK)
and 16 quadrature amplitude-shift keying (QASK) modulation. These
simple codes achieve coding gains in the order of 3-4 dB. It is then shown
that the codes can be interpreted as binary convolutional codes with a
mapping of coded bits into channel signals, which we call “mapping by set
partitioning.” Based on a new distance measure between binary code
sequences which efficiently lower-bounds the Euclidean distance between
Manuscript received May 24, 1977; revised January 7, 1981.
the corresponding channel signal sequences, a search procedure for more
powerful codes is developed. Codes with coding gains up to 6 dB are
obtained for a variety of multilevel/phase modulation schemes. Simulation
results are presented and an example of carrier-phase tracking is discussed.
Ungerboeck_IT_TCM.rar
1.16 MB, 下载次数: 66 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-3-24 19:12:37 | 显示全部楼层
thx a lot
发表于 2008-3-25 20:56:33 | 显示全部楼层
kan
发表于 2008-3-25 21:00:31 | 显示全部楼层
发表于 2009-6-23 17:08:23 | 显示全部楼层
十分感谢
发表于 2009-6-23 17:09:55 | 显示全部楼层
谢谢了啊
发表于 2009-8-24 10:36:25 | 显示全部楼层
谢谢了trellis coded modulation
发表于 2009-11-9 09:38:28 | 显示全部楼层
xiexie lZ
发表于 2009-12-17 19:57:14 | 显示全部楼层
谢谢了。好资料
发表于 2010-5-10 19:23:17 | 显示全部楼层
XIEXIE LE
GMT+8, 2025-12-25 17:41 , Processed in 0.025937 second(s), 7 queries , Gzip On, Redis On.
