查看: 410|回复: 1
[资料] 后仿 no
发表于 2025-7-4 09:29:10 | 显示全部楼层 |阅读模式
ifdef SDF
    TIMING_CHK=ON
    COMMON_CMP_OPTS += +define+SDFSIM -negdelay +neg_tchk -sdfretain +sdfverbose -diag=sdf:verbose
    COMMON_CMP_OPTS += -sdf ${TYPE}:tb.u_dut.u_top{CORNER}
    COMMON_CMP_OPTS += +optconfigfile+../cfg/notiming_chk.cfg
    COMMON_CMP_OPTS += +optconfigfile+../cfg/nospecify.cfg
endif
##-- postsim options
GATESIM=
# SDF= ff|ss|tt to specify sdf corner
SDF =
# TYPE= min|typ|max to specify delay type
TYPE=
#refert to correct corner file due to $SDF
CORNER=
ifdef SDF
    GATESIM=ON
    sdf_en =1
    ifeq ($(SDF), ff)
        TYPE=min
        SIM_OPTION += +corner=sdf_ff_min
        USER_CMP_OPTS +=+define+SDF_FF_MIN
        USER_CMP_OPTS +=+mindelays
        CORNER=${NETLIST_DIR}/top_ew_FUNC_ffpg_0p8250v_125c_Cmin_HOLD.sdf.gz
    else ifeq ($(SDF), ss)
        TYPE=max
        SIM_OPTION += +corner=sdf_ss_max
        USER_CMP_OPTS += +define+SDF_SS_MAX
        USER_CMP_OPTS += +maxdelays
        CORNER=${NETLIST_DIR}/top_ew_FUNC_sspg_0p6750v_m40c_Cmax_SETUP.sdf.gz
    else
        CORNER=${NETLIST_DIR}/top_ew_FUNC_tt_0p7500v_85c_nominal_SETUP.sdf.gz
        ifeq ($(TYPE), min)
            SIM_OPTION += +corner=sdf_tt_min
            USER_CMP_OPTS += +define+SDF_TT_MIN
            USER_CMP_OPTS += +typdelays
        else
            SIM_OPTION += +corner=sdf_tt_max
            USER_CMP_OPTS += +define+SDF_TT_MAX
        endif #ifeq ($(TYPE), min)
    endif #ifeq($(SDF), ff)
endif #ifdef SDF
>>>>>>>nospecify.cfg
tree { PLL_TOP } {noSpecify};
tree { DLL_TOP  } {noSpecify};
tree { ZQ_TOP  } {noSpecify};
>>>>>>>>notiming_chk.cfg
instance {
tb.u_dut.u_top.u_rstn_sync_apb.u_resetn_sync.GEN_FST4_U_SAMPLE_META_4.Usync4_0_,
tb.u_dut.u_top.u_rstn_sync_tdr.u_resetn_sync.GEN_FST4_U_SAMPLE_META_4.Usync4_0_
}{noTiming};
发表于 2025-7-11 13:55:02 来自手机 | 显示全部楼层
你这个notiming最好还是精确到寄存器端口吧,整个寄存器notiming有点激进
GMT+8, 2025-10-19 09:34 , Processed in 0.013644 second(s), 5 queries , Gzip On, Redis On.
