查看: 946|回复: 5
wv23 lic feature
发表于 2025-7-3 12:12:20 | 显示全部楼层 |阅读模式
wv 2023 instantiation log down below.
what should i have to modify my license?
delete sx_wva and add cx_ultra?
[SCL] SCL trace is enabled.
FlexNet Licensing checkout error: License server system does not support this version of this feature. (-25,147)
license file(s):  27020@ic23
[SCL] 07/03/2025 13:06:25 PID:3656 Client:ic23 Checkout denied sx_wva 2023.12
[SCL] 07/03/2025 13:06:25 PID:3656 Client:ic23 Checkout denied spice_explorer 2023.12
[SCL] 07/03/2025 13:06:25 PID:3656 Client:ic23 Checkout denied custom_explorer 2023.12
[SCL] 07/03/2025 13:06:25 PID:3656 Client:ic23 Checkout denied cx_ultra 2023.12
-- Custom WaveView License Checkout Error : License server system does not support this version of this feature. (-25,234)
  no valid license found
  please contact your system administrator
发表于 2025-7-3 15:31:50 | 显示全部楼层
license file里面设置的版本低了,需要高于你运行的wv的版本。
 楼主| 发表于 2025-7-3 16:05:31 | 显示全部楼层
i use scl_licgen 2030 in this forum.
is there any newer licgen than scl_licegen 2030 in this forum?
发表于 2025-7-4 17:34:17 | 显示全部楼层
你的SCL是什么版本的
 楼主| 发表于 2025-7-4 18:14:08 | 显示全部楼层
pbsoft 发表于 2025-7-4 17:34
你的SCL是什么版本的
terrawilly's SCL25
 楼主| 发表于 2025-8-24 19:02:18 | 显示全部楼层
solved
executed well
GMT+8, 2025-12-20 21:07 , Processed in 0.017578 second(s), 4 queries , Gzip On, Redis On.
