查看: 1451|回复: 5
IC618_360 Hotfix => PATCH
发表于 2025-6-25 02:14:03 | 显示全部楼层 |阅读模式
Has anyone here successfully installed AND patched IC618 hotfix ISR36 ?
I have a problem to patch it. According to README file this product was integrated with FlexNet version 11.16.4.0.
1patch.sh is programmed to work with these signatures:
/5589...
/5589...
/4157...
Does someone know new ECC signatures?
发表于 2025-6-25 08:17:44 | 显示全部楼层
RHEL7.9下1patch IC618_360正常使用
 楼主| 发表于 2025-6-25 18:47:35 来自手机 | 显示全部楼层
I saw that some errors after to apply patch. I think that some files are without permission to  write
发表于 2025-6-26 12:05:12 | 显示全部楼层
我的也失败了,报license问题,退回到ic618 base就可以了
 楼主| 发表于 2025-7-16 05:45:20 来自手机 | 显示全部楼层
I installed hotfix ISR 360 on CentOS 7.9 and applied the patch, but license don't work.
 楼主| 发表于 2025-7-17 07:09:23 来自手机 | 显示全部楼层
After many attempts, I finally solved the problem:
I applied the patch developed by tanker.
It found ALL point with ECC signatures and fixed it successful.
GMT+8, 2025-11-9 16:12 , Processed in 0.013555 second(s), 3 queries , Gzip On, Redis On.
