查看: 2810|回复: 21
[资料] The Art of ARM Assembly 2025
发表于 2025-5-17 15:44:37 | 显示全部楼层 |阅读模式
The Art of ARM Assembly.Volume 1 - 64-Bit ARM Machine Organization and Programming 2025
Modern Instructions for 64-Bit ARM CPUs
Building on Randall Hyde’s iconic series, The Art of ARM Assembly delves into programming 64-bit ARM CPUs—the powerhouses behind iPhones, Macs, Chromebooks, servers, and embedded systems.
Following a fast-paced introduction to the art of programming in assembly and the GNU Assembler (Gas) specifically, you’ll explore memory organization, data representation, and the basic logical operations you can perform on simple data types. You’ll learn how to define constants, write functions, manage local variables, and pass parameters efficiently. You’ll explore both basic and advanced arithmetic operations, control structures, numeric conversions, lookup tables, and string manipulation—in short, you’ll cover it all.
You’ll also dive into ARM SIMD (Neon) instructions, bit manipulation, and macro programming with the Gas assembler, as well as how to:
• Declare pointers and use composite data structures like strings, arrays, and unions
• Convert simple and complex arithmetic expressions into machine instruction sequences
• Use ARM addressing modes and expressions to access memory variables
• Create and use string library functions and build libraries of assembly code using makefiles
This hands-on guide will help you master ARM assembly while revealing the intricacies of modern machine architecture. You’ll learn to write more efficient high-level code and gain a deeper understanding of software-hardware interactions—essential skills for any programmer working with ARM-based systems.
The Art of ARM Assembly 2025.part1.rar (10 MB , 下载次数: 127 )
The Art of ARM Assembly 2025.part2.rar (4.94 MB , 下载次数: 115 )
发表于 2025-5-17 17:28:04 | 显示全部楼层
感谢楼主共享
发表于 2025-5-17 19:03:46 | 显示全部楼层
thanks
发表于 2025-5-17 22:48:49 | 显示全部楼层
谢谢大佬
发表于 2025-5-18 09:57:47 | 显示全部楼层
谢谢分享,学习ARM64汇编必备
发表于 2025-5-18 16:43:21 | 显示全部楼层
Thanks
发表于 2025-5-19 06:54:19 | 显示全部楼层
Good!
发表于 2025-5-19 08:07:51 | 显示全部楼层
谢谢分享
发表于 2025-5-21 03:08:09 | 显示全部楼层
volume 1
发表于 2025-5-21 09:02:59 | 显示全部楼层
感谢楼主分享
GMT+8, 2025-12-28 04:28 , Processed in 0.029309 second(s), 4 queries , Gzip On, Redis On.
