查看: 1714|回复: 13
$entaurus的lic可以用source执行,但lmgrd无法识别
发表于 2025-5-16 17:01:02 | 显示全部楼层 |阅读模式
各位大佬,
小弟最近在折腾sentaurus 2022,尝试使用了:
./pubkey_verify -y
./synopsys_checksum -y
./SynopsysMonoSlayer -a
制作的lic格式如下:
SERVER rhel79-sps22 000c298bb9c7 30000
DAEMON snpslmd /SPS_2022/scl/2021.12/linux64/bin/snpslmd
INCREMENT 3D snpslmd 2100.000 permanent uncounted HOSTID=000c298bb9c7 SIGN2
INCREMENT 3P snpslmd 2100.000 permanent uncounted HOSTID=000c298bb9c7 SIGN2
INCREMENT 8alaxy-Zroute snpslmd 2100.000 permanent uncounted HOSTID=000c298bb9c7 SIGN2
INCREMENT A3200DX snpslmd 2100.000 permanent uncounted HOSTID=000c298bb9c7 SIGN2
INCREMENT A42MX snpslmd 2100.000 permanent uncounted HOSTID=000c298bb9c7 SIGN2
INCREMENT A500K snpslmd 2100.000 permanent uncounted HOSTID=000c298bb9c7 SIGN2
然后尝试启动swb,环境变量如下:
# The following settings are for synopsys
# set license
export SNPSLMD_LICENSE_FILE=$SYNOPSYS_DIR/license/synopsys.lic
#export SNPSLMD_LICENSE_FILE=30000@rhel79-sps22
# scl
export SCL_HOME=$SYNOPSYS_DIR/scl/$SET_SCL_VERSION
export PATH=$SCL_HOME/linux64/binPATH
# sentaurus
export SENTAURUS_HOME=$SYNOPSYS_DIR/sentaurus/$SET_SENTAURUS_VERSION
export PATH=$SENTAURUS_HOME/binPATH
发现SNPSLMD_LICENSE_FILE指定lic路径可以正常起swb,但用"端口@host"这种形式就不行。
lmgrd启动后日志如下:
1:38:45 (snpslmd) XC4000EX     XC4000L         XC4000XL
1:38:45 (snpslmd) XC4000XLA    XC4000XV        XC5200
1:38:45 (snpslmd) XC9500               XC9500XL        XC9500XV
1:38:45 (snpslmd) xp           xsim            XVCSDebugger
1:38:45 (snpslmd) XVCSiDebugger        XVVCDebugger    yopsys-Release
1:38:45 (snpslmd)
1:38:45 (snpslmd) Licenses are case sensitive for TE_CATS
1:38:45 (snpslmd)
1:38:45 (snpslmd) EXTERNAL FILTERS are OFF
1:38:45 (lmgrd) snpslmd using TCP-port 58157
1:38:45 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  atrenta  avantd  CADABRA  chrysalisd  cowared  doradod  EPIC  eved  extremed  hscd  innologd  ISE-TCADd  knights  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  perflmd  riod  saber_dmn  sandwork  sclmgrd  sigmacd  SIINT  simple  snpsOEM1  snslmgrd  ssilmd  synforad  synopsysd  synplctyd  targetld  TAVEREN  TE_CATS  tmald  vastlmd  vcsd  wlld
05/16/2025 01:38:45 (snpslmd) ------------------------------------------------------------------
05/16/2025 01:38:45 (snpslmd) Checking the integrity of the license file...
05/16/2025 01:38:45 (snpslmd) The SSS features are garbled.
05/16/2025 01:38:46 (snpslmd) All revenue keys ("SN=RK:..." on feature line) have been excluded.
05/16/2025 01:38:46 (snpslmd) ------------------------------------------------------------------
lmgrd版本如下:
lmgrd v11.16.4.0 build 252457 x64_lsb
操作系统:RHEL 7.9
请各位大佬赐教,非常迷惑。
发表于 2025-5-17 08:55:56 | 显示全部楼层
hi 你好,“发现SNPSLMD_LICENSE_FILE指定lic路径可以正常起swb,但用"端口@host"这种形式就不行。",现在解决了嘛?
1可以再仔细看一下环境变量里面写的路径有没有”手误“
2不知道是不是可能etc/rc.local里面没有写开机运行lmgrd那些cmd?或者etc/rc.local这个文件忘了加可执行权限了?
我之前折腾安装的时候也碰到过你说的这个情况,最后排查下来是上述两种情况或者之一造成的,希望有用
发表于 2025-5-17 22:54:49 | 显示全部楼层
i am beat,  just wanna lie down
发表于 2025-5-17 23:08:32 | 显示全部楼层
license 再重做。
 楼主| 发表于 2025-5-19 08:03:37 | 显示全部楼层
CSFOC 发表于 2025-5-17 08:55
hi 你好,“发现SNPSLMD_LICENSE_FILE指定lic路径可以正常起swb,但用"端口@host"这种形式就不行。",现在 ...
感谢回复,检查过,lic路径正确。
发表于 2025-5-19 11:33:24 | 显示全部楼层
你这个就是sss和feature不匹配导致,要么启动lmgrd后用lmreread重新加载一次lic文件,要么就是用工具重做一个完整的lic文件,不要用网上不同的lic进行拼凑
发表于 2025-5-19 16:23:21 | 显示全部楼层
没写LM_LICENSE_FILE的路径,和snp..那个一致就行
发表于 2025-6-12 17:05:15 | 显示全部楼层
应该lic的制作工具已经不能在2022版本上用了
 楼主| 发表于 2025-6-13 08:57:12 | 显示全部楼层
rs6000 发表于 2025-5-19 11:33
你这个就是sss和feature不匹配导致,要么启动lmgrd后用lmreread重新加载一次lic文件,要么就是用工具重做一 ...
感谢回复,用新的工具制作后可以了。
发表于 2025-8-13 17:23:58 | 显示全部楼层
cxk520 发表于 2025-6-13 08:57
感谢回复,用新的工具制作后可以了。
老大,分享一下新的license之作工具呗!
GMT+8, 2025-12-18 07:03 , Processed in 0.017672 second(s), 4 queries , Gzip On, Redis On.
