## C A L I B R E S Y S T E M ##
## L V S R E P O R T ##
REPORT FILE NAME: model2_temp.lvs.report
LAYOUT NAME: /home/IC/model2_temp.sp ('model2_temp')
SOURCE NAME: /home/IC/model2_temp.src.net ('model2_temp')
RULE FILE: /home/IC/_CSMC018_AB_SBCD_G1S_calLVS.rul_
CREATION TIME: Tue May 13 16:48:03 2025
CURRENT DIRECTORY: /home/IC
USER NAME: IC
CALIBRE VERSION: v2019.3_15.11 Tue Jul 2 12:24:58 PDT 2019
OVERALL COMPARISON RESULTS
# # INCORRECT #
Error: Different numbers of nets.
Error: Different numbers of instances.
Error: Connectivity errors.
Error: Property errors.
CELL SUMMARY
Result Layout Source
INCORRECT model2_temp model2_temp
LVS PARAMETERS
o LVS Setup:
// LVS COMPONENT TYPE PROPERTY
// LVS COMPONENT SUBTYPE PROPERTY
// LVS PIN NAME PROPERTY
LVS POWER NAME "VCC"
LVS GROUND NAME "GND"
LVS CELL SUPPLY NO
LVS RECOGNIZE GATES ALL
LVS IGNORE PORTS NO
LVS CHECK PORT NAMES YES
LVS IGNORE TRIVIAL NAMED PORTS NO
LVS BUILTIN DEVICE PIN SWAP YES
LVS ALL CAPACITOR PINS SWAPPABLE NO
LVS DISCARD PINS BY DEVICE NO
LVS SOFT SUBSTRATE PINS NO
LVS INJECT LOGIC YES
LVS EXPAND UNBALANCED CELLS YES
LVS FLATTEN INSIDE CELL NO
LVS EXPAND SEED PROMOTIONS NO
LVS PRESERVE PARAMETERIZED CELLS NO
LVS GLOBALS ARE PORTS YES
LVS REVERSE WL NO
LVS SPICE PREFER PINS NO
LVS SPICE SLASH IS SPACE YES
LVS SPICE ALLOW FLOATING PINS YES
// LVS SPICE ALLOW INLINE PARAMETERS
LVS SPICE ALLOW UNQUOTED STRINGS NO
LVS SPICE CONDITIONAL LDD NO
LVS SPICE CULL PRIMITIVE SUBCIRCUITS NO
// LVS SPICE EXCLUDE CELL SOURCE
// LVS SPICE EXCLUDE CELL LAYOUT
LVS SPICE IMPLIED MOS AREA NO
// LVS SPICE MULTIPLIER NAME
LVS SPICE OVERRIDE GLOBALS NO
LVS SPICE REDEFINE PARAM NO
LVS SPICE REPLICATE DEVICES NO
LVS SPICE SCALE X PARAMETERS NO
LVS SPICE STRICT WL NO
// LVS SPICE OPTION
LVS STRICT SUBTYPES NO
LVS EXACT SUBTYPES NO
LAYOUT CASE YES
SOURCE CASE YES
LVS COMPARE CASE NAMES TYPES SUBTYPES VALUES
LVS DOWNCASE DEVICE NO
LVS REPORT MAXIMUM 50
LVS PROPERTY RESOLUTION MAXIMUM 32
// LVS SIGNATURE MAXIMUM
LVS FILTER UNUSED OPTION AB AC AD RC
// LVS REPORT OPTION
LVS REPORT UNITS YES
// LVS NON USER NAME PORT
// LVS NON USER NAME NET
// LVS NON USER NAME INSTANCE
// LVS IGNORE DEVICE PIN
// LVS PREFER NETS FILTER SOURCE
// LVS PREFER NETS FILTER LAYOUT
LVS PREFER PORT NETS NO
// Device Type Map
LVS DEVICE TYPE MOS "mn5_iso_dn" [ S=S D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE MOS "mn5_iso_hn" [ S=S D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE MOS "mn5_iso_hndn" [ S=S D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE MOS "mp5_hn" [ S=S D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE MOS "mp5_dn" [ S=S D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE DIODE "dz_10x1" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE DIODE "dz_10x1_pzp" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE CAPACITOR "capnmos" [ POS=NG NEG=NDS ] SOURCE LAYOUT
LVS DEVICE TYPE CAPACITOR "capnmos_3t" [ POS=NG NEG=NDS ] SOURCE LAYOUT
LVS DEVICE TYPE RESISTOR "rnwell_sti_3t" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE RESISTOR "rnwell_aa_3t" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE RESISTOR "rnplus_3t" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE RESISTOR "rpplus_3t" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE RESISTOR "rnpoly_3t" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE RESISTOR "rppoly_3t" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE RESISTOR "rnplus_sab_3t" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE RESISTOR "rpplus_sab_3t" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE RESISTOR "rnpoly_sab_3t" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE RESISTOR "rppoly_sab_3t" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE RESISTOR "rhr_fake_3t" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE RESISTOR "rhr_3t" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
LVS DEVICE TYPE CAPACITOR "cmom" [ POS=N1 NEG=N2 ] SOURCE LAYOUT
LVS DEVICE TYPE CAPACITOR "cmom_3t" [ POS=N1 NEG=N2 ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mn7vt" [ S=BS D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mn9vt" [ S=BS D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mn10vt" [ S=BS D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mp7vt" [ S=S D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mp10vt" [ S=S D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mn10vta" [ S=S D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mn23vta" [ S=BS D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mn23vta2" [ S=S D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mn35vta" [ S=BS D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mp23vta" [ S=S D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mp35vta" [ S=S D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mn40vta2" [ S=BS D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mn60vta2" [ S=BS D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mp40vta" [ S=S D=D G=G ] SOURCE LAYOUT
LVS DEVICE TYPE LDDMOS "mp60vta" [ S=BS D=D G=G ] SOURCE LAYOUT
// Reduction
LVS REDUCE SERIES MOS NO
LVS REDUCE PARALLEL MOS YES
LVS REDUCE SEMI SERIES MOS NO
LVS REDUCE SPLIT GATES YES
LVS REDUCE PARALLEL BIPOLAR YES
LVS REDUCE SERIES CAPACITORS YES
LVS REDUCE PARALLEL CAPACITORS YES
LVS REDUCE SERIES RESISTORS YES
LVS REDUCE PARALLEL RESISTORS YES
LVS REDUCE PARALLEL DIODES YES
LVS REDUCE mn5_iso_dn PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mn5_iso_hn PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mn5_iso_hndn PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mp5_hn PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mp5_dn PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE esd_mn5_io_3t PARALLEL [ TOLERANCE l 0 w 0 ]
LVS REDUCE esd_mn5_pp_3t PARALLEL [ TOLERANCE l 0 w 0 ]
LVS REDUCE esd_mp5_io_3t PARALLEL [ TOLERANCE l 0 w 0 ]
LVS REDUCE dz_10x1 PARALLEL [ TOLERANCE A 0 ]
LVS REDUCE dz_10x1_pzp PARALLEL [ TOLERANCE A 0 ]
LVS REDUCE capnmos PARALLEL [ TOLERANCE l 0 w 0 ]
LVS REDUCE capnmos_3t PARALLEL [ TOLERANCE l 0 w 0 ]
LVS REDUCE jfet_30xd9 PARALLEL [ TOLERANCE w 0 ]
LVS REDUCE jfet_20x1d2 PARALLEL [ TOLERANCE w 0 ]
LVS REDUCE rnwell_aa_3t PARALLEL [ TOLERANCE L 0 ]
LVS REDUCE rnwell_aa_3t SERIES PLUS MINUS [ TOLERANCE W 0 ]
LVS REDUCE rnwell_sti_3t PARALLEL [ TOLERANCE L 0 ]
LVS REDUCE rnwell_sti_3t SERIES PLUS MINUS [ TOLERANCE W 0 ]
LVS REDUCE rnplus_sab_3t PARALLEL [ TOLERANCE L 0 ]
LVS REDUCE rnplus_sab_3t SERIES PLUS MINUS [ TOLERANCE W 0 ]
LVS REDUCE rpplus_sab_3t PARALLEL [ TOLERANCE L 0 ]
LVS REDUCE rpplus_sab_3t SERIES PLUS MINUS [ TOLERANCE W 0 ]
LVS REDUCE rnplus_3t PARALLEL [ TOLERANCE L 0 ]
LVS REDUCE rnplus_3t SERIES PLUS MINUS [ TOLERANCE W 0 ]
LVS REDUCE rpplus_3t PARALLEL [ TOLERANCE L 0 ]
LVS REDUCE rpplus_3t SERIES PLUS MINUS [ TOLERANCE W 0 ]
LVS REDUCE rnpoly_3t PARALLEL [ TOLERANCE L 0 ]
LVS REDUCE rnpoly_3t SERIES PLUS MINUS [ TOLERANCE W 0 ]
LVS REDUCE rppoly_3t PARALLEL [ TOLERANCE L 0 ]
LVS REDUCE rppoly_3t SERIES PLUS MINUS [ TOLERANCE W 0 ]
LVS REDUCE rnpoly_sab_3t PARALLEL [ TOLERANCE L 0 ]
LVS REDUCE rnpoly_sab_3t SERIES PLUS MINUS [ TOLERANCE W 0 ]
LVS REDUCE rppoly_sab_3t PARALLEL [ TOLERANCE L 0 ]
LVS REDUCE rppoly_sab_3t SERIES PLUS MINUS [ TOLERANCE W 0 ]
LVS REDUCE rhr_fake_3t PARALLEL [ TOLERANCE L 0 ]
LVS REDUCE rhr_fake_3t SERIES PLUS MINUS [ TOLERANCE W 0 ]
LVS REDUCE rhr_3t PARALLEL [ TOLERANCE L 0 ]
LVS REDUCE rhr_3t SERIES PLUS MINUS [ TOLERANCE W 0 ]
LVS REDUCE cmom PARALLEL [ TOLERANCE nv 0 l 0 stm 0 spm 0 ]
LVS REDUCE cmom_3t PARALLEL [ TOLERANCE nv 0 l 0 stm 0 spm 0 ]
LVS REDUCE mn23vta PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mn23vta2 PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mp23vta PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mn7vt PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mn9vt PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mn10vt PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mn10vta PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mp7vt PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mp9vt PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mp10vt PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mn35vta PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mp35vta PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mn40vta2 PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mn60vta2 PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mp40vta PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE mp60vta PARALLEL [ TOLERANCE L 0 W 0 ]
LVS REDUCE esd_qlp_7v_9v_sp_nw_3t PARALLEL [ TOLERANCE w 0 ]
LVS REDUCE esd_qlp_10v_sp_nw_3t PARALLEL [ TOLERANCE w 0 ]
LVS REDUCE esd_qlp_18v_23v_sp_nw_sp_hn_2s_3t PARALLEL [ TOLERANCE w 0 ]
LVS REDUCE esd_qlp_23v_sp_hn_2s_3t PARALLEL [ TOLERANCE w 0 ]
LVS REDUCE esd_qlp_30v_sp_nw_3s_3t PARALLEL [ TOLERANCE w 0 ]
LVS REDUCE esd_qlp_35v_sp_hn_2s_3t PARALLEL [ TOLERANCE w 0 ]
LVS REDUCE esd_qlp_40v_sp_nw_1s_sp_hn_2s_3t PARALLEL [ TOLERANCE w 0 ]
LVS REDUCE esd_qlp_40v_hn_ptm_1s_3t PARALLEL [ TOLERANCE w 0 ]
LVS REDUCE esd_qlp_60v_sp_nw_1s_sp_hn_3s_3t PARALLEL [ TOLERANCE w 0 ]
LVS REDUCE esd_qlp_60v_hn_ptm_1s_3t PARALLEL [ TOLERANCE w 0 ]
LVS REDUCTION PRIORITY PARALLEL
LVS SHORT EQUIVALENT NODES NO
// Trace Property
TRACE PROPERTY mn5_iso_dn w w 0
TRACE PROPERTY mn5_iso_dn l l 0
TRACE PROPERTY mn5_iso_dn mf mf 0
TRACE PROPERTY mn5_iso_hn w w 0
TRACE PROPERTY mn5_iso_hn l l 0
TRACE PROPERTY mn5_iso_hn mf mf 0
TRACE PROPERTY mn5_iso_hndn w w 0
TRACE PROPERTY mn5_iso_hndn l l 0
TRACE PROPERTY mn5_iso_hndn mf mf 0
TRACE PROPERTY mp5_hn w w 0
TRACE PROPERTY mp5_hn l l 0
TRACE PROPERTY mp5_hn mf mf 0
TRACE PROPERTY mp5_dn w w 0
TRACE PROPERTY mp5_dn l l 0
TRACE PROPERTY mp5_dn mf mf 0
TRACE PROPERTY m(mn5) w w 0
TRACE PROPERTY m(mn5) l l 0
TRACE PROPERTY m(mp5) w w 0
TRACE PROPERTY m(mp5) l l 0
TRACE PROPERTY m(mn5_native) w w 0
TRACE PROPERTY m(mn5_native) l l 0
TRACE PROPERTY esd_mn5_io_3t w w 0
TRACE PROPERTY esd_mn5_io_3t l l 0
TRACE PROPERTY esd_mn5_io_3t mf mf 0
TRACE PROPERTY esd_mn5_io_3t dnw_area dnw_area 0
TRACE PROPERTY esd_mn5_io_3t m m 0
TRACE PROPERTY esd_mn5_pp_3t w w 0
TRACE PROPERTY esd_mn5_pp_3t l l 0
TRACE PROPERTY esd_mn5_pp_3t mf mf 0
TRACE PROPERTY esd_mn5_pp_3t dnw_area dnw_area 0
TRACE PROPERTY esd_mn5_pp_3t m m 0
TRACE PROPERTY esd_mp5_io_3t w w 0
TRACE PROPERTY esd_mp5_io_3t l l 0
TRACE PROPERTY esd_mp5_io_3t mf mf 0
TRACE PROPERTY esd_mp5_io_3t dnw_area dnw_area 0
TRACE PROPERTY esd_mp5_io_3t m m 0
TRACE PROPERTY q(qvp5_d6xd6) a a 0
TRACE PROPERTY q(qvp5_2x2) a a 0
TRACE PROPERTY q(qvp5_5x5) a a 0
TRACE PROPERTY q(qvp5_10x10) a a 0
TRACE PROPERTY q(qvpp_2x2) a a 0
TRACE PROPERTY q(qvpp_5x5) a a 0
TRACE PROPERTY q(qvpp_10x10) a a 0
TRACE PROPERTY q(qvn5_d6xd6) a a 0
TRACE PROPERTY q(qvn5_2x2) a a 0
TRACE PROPERTY q(qvn5_5x5) a a 0
TRACE PROPERTY q(qvn5_10x10) a a 0
TRACE PROPERTY q(qvnptm_2x2) a a 0
TRACE PROPERTY q(qvnptm_5x5) a a 0
TRACE PROPERTY q(qvnptm_10x10) a a 0
TRACE PROPERTY q(qvpptm_2x2) a a 0
TRACE PROPERTY q(qvpptm_5x5) a a 0
TRACE PROPERTY q(qvpptm_10x10) a a 0
TRACE PROPERTY q(qvppb_2x2) a a 0
TRACE PROPERTY q(qvppb_5x5) a a 0
TRACE PROPERTY q(qvppb_10x10) a a 0
TRACE PROPERTY q(qvppm_2x2) a a 0
TRACE PROPERTY q(qvppm_5x5) a a 0
TRACE PROPERTY q(qvppm_10x10) a a 0
TRACE PROPERTY q(qvnpm_10x10) a a 0
TRACE PROPERTY d(dppnw_5) a a 0
TRACE PROPERTY d(dnppw_5) a a 0
TRACE PROPERTY d(dpwdn_5) a a 0
TRACE PROPERTY d(dnwpsub_5) a a 0
TRACE PROPERTY d(dpbhn) a a 0
TRACE PROPERTY d(dpmhn) a a 0
TRACE PROPERTY d(dhnpsub) a a 0
TRACE PROPERTY dz_10x1 a a 0
TRACE PROPERTY dz_10x1 ptm_area ptm_area 0
TRACE PROPERTY dz_10x1 hnw_area hnw_area 0
TRACE PROPERTY dz_10x1 mf mf 0
TRACE PROPERTY dz_10x1_pzp a a 0
TRACE PROPERTY dz_10x1_pzp mf mf 0
TRACE PROPERTY capnmos w w 0
TRACE PROPERTY capnmos l l 0
TRACE PROPERTY capnmos mf mf 0
TRACE PROPERTY capnmos_3t w w 0
TRACE PROPERTY capnmos_3t l l 0
TRACE PROPERTY capnmos_3t mf mf 0
TRACE PROPERTY jfet_30xd9 w w 0
TRACE PROPERTY jfet_30xd9 l l 0
TRACE PROPERTY jfet_30xd9 mf mf 0
TRACE PROPERTY jfet_30xd9 m m 0
TRACE PROPERTY jfet_20x1d2 w w 0
TRACE PROPERTY jfet_20x1d2 l l 0
TRACE PROPERTY jfet_20x1d2 mf mf 0
TRACE PROPERTY jfet_20x1d2 m m 0
TRACE PROPERTY r(rhr_2t) w w 0
TRACE PROPERTY r(rhr_2t) l l 0
TRACE PROPERTY r(rm6t_35k) w w 0
TRACE PROPERTY r(rm6t_35k) l l 0
TRACE PROPERTY r(rm5) w w 0
TRACE PROPERTY r(rm5) l l 0
TRACE PROPERTY r(rm4) w w 0
TRACE PROPERTY r(rm4) l l 0
TRACE PROPERTY r(rm3) w w 0
TRACE PROPERTY r(rm3) l l 0
TRACE PROPERTY r(rm2) w w 0
TRACE PROPERTY r(rm2) l l 0
TRACE PROPERTY r(rm1) w w 0
TRACE PROPERTY r(rm1) l l 0
TRACE PROPERTY r(rnwell_sti_2t) w w 0
TRACE PROPERTY r(rnwell_sti_2t) l l 0
TRACE PROPERTY r(rnwell_aa_2t) w w 0
TRACE PROPERTY r(rnwell_aa_2t) l l 0
TRACE PROPERTY r(rnpoly_sab_2t) w w 0
TRACE PROPERTY r(rnpoly_sab_2t) l l 0
TRACE PROPERTY r(rnpoly_2t) w w 0
TRACE PROPERTY r(rnpoly_2t) l l 0
TRACE PROPERTY r(rppoly_sab_2t) w w 0
TRACE PROPERTY r(rppoly_sab_2t) l l 0
TRACE PROPERTY r(rppoly_2t) w w 0
TRACE PROPERTY r(rppoly_2t) l l 0
TRACE PROPERTY r(rnplus_sab_2t) w w 0
TRACE PROPERTY r(rnplus_sab_2t) l l 0
TRACE PROPERTY r(rnplus_2t) w w 0
TRACE PROPERTY r(rnplus_2t) l l 0
TRACE PROPERTY r(rpplus_sab_2t) w w 0
TRACE PROPERTY r(rpplus_sab_2t) l l 0
TRACE PROPERTY r(rpplus_2t) w w 0
TRACE PROPERTY r(rpplus_2t) l l 0
TRACE PROPERTY r(rhr_fake_2t) w w 0
TRACE PROPERTY r(rhr_fake_2t) l l 0
TRACE PROPERTY rhr_3t w w 0
TRACE PROPERTY rhr_3t l l 0
TRACE PROPERTY rnwell_sti_3t w w 0
TRACE PROPERTY rnwell_sti_3t l l 0
TRACE PROPERTY rnwell_aa_3t w w 0
TRACE PROPERTY rnwell_aa_3t l l 0
TRACE PROPERTY rnplus_3t w w 0
TRACE PROPERTY rnplus_3t l l 0
TRACE PROPERTY rpplus_3t w w 0
TRACE PROPERTY rpplus_3t l l 0
TRACE PROPERTY rnplus_sab_3t w w 0
TRACE PROPERTY rnplus_sab_3t l l 0
TRACE PROPERTY rpplus_sab_3t w w 0
TRACE PROPERTY rpplus_sab_3t l l 0
TRACE PROPERTY rnpoly_3t w w 0
TRACE PROPERTY rnpoly_3t l l 0
TRACE PROPERTY rppoly_3t w w 0
TRACE PROPERTY rppoly_3t l l 0
TRACE PROPERTY rppoly_sab_3t w w 0
TRACE PROPERTY rppoly_sab_3t l l 0
TRACE PROPERTY rnpoly_sab_3t w w 0
TRACE PROPERTY rnpoly_sab_3t l l 0
TRACE PROPERTY rhr_fake_3t w w 0
TRACE PROPERTY rhr_fake_3t l l 0
TRACE PROPERTY c(cmim_5t) c c 0
TRACE PROPERTY cmom nv nv 0
TRACE PROPERTY cmom l l 0
TRACE PROPERTY cmom stm stm 0
TRACE PROPERTY cmom spm spm 0
TRACE PROPERTY cmom mf mf 0
TRACE PROPERTY cmom_3t nv nv 0
TRACE PROPERTY cmom_3t l l 0
TRACE PROPERTY cmom_3t stm stm 0
TRACE PROPERTY cmom_3t spm spm 0
TRACE PROPERTY cmom_3t mf mf 0
TRACE PROPERTY mn23vta w w 0
TRACE PROPERTY mn23vta l l 0
TRACE PROPERTY mn23vta mf mf 0
TRACE PROPERTY mn23vta m m 0
TRACE PROPERTY mn23vta2 w w 0
TRACE PROPERTY mn23vta2 l l 0
TRACE PROPERTY mn23vta2 mf mf 0
TRACE PROPERTY mn23vta2 m m 0
TRACE PROPERTY mp23vta w w 0
TRACE PROPERTY mp23vta l l 0
TRACE PROPERTY mp23vta mf mf 0
TRACE PROPERTY mp23vta m m 0
TRACE PROPERTY mn7vt w w 0
TRACE PROPERTY mn7vt l l 0
TRACE PROPERTY mn7vt mf mf 0
TRACE PROPERTY mn7vt m m 0
TRACE PROPERTY mn9vt w w 0
TRACE PROPERTY mn9vt l l 0
TRACE PROPERTY mn9vt mf mf 0
TRACE PROPERTY mn9vt m m 0
TRACE PROPERTY mn10vt w w 0
TRACE PROPERTY mn10vt l l 0
TRACE PROPERTY mn10vt mf mf 0
TRACE PROPERTY mn10vt m m 0
TRACE PROPERTY mn10vta w w 0
TRACE PROPERTY mn10vta l l 0
TRACE PROPERTY mn10vta mf mf 0
TRACE PROPERTY mn10vta m m 0
TRACE PROPERTY mp7vt w w 0
TRACE PROPERTY mp7vt l l 0
TRACE PROPERTY mp7vt mf mf 0
TRACE PROPERTY mp7vt m m 0
TRACE PROPERTY mp9vt w w 0
TRACE PROPERTY mp9vt l l 0
TRACE PROPERTY mp9vt mf mf 0
TRACE PROPERTY mp9vt m m 0
TRACE PROPERTY mp10vt w w 0
TRACE PROPERTY mp10vt l l 0
TRACE PROPERTY mp10vt mf mf 0
TRACE PROPERTY mp10vt m m 0
TRACE PROPERTY mn35vta w w 0
TRACE PROPERTY mn35vta l l 0
TRACE PROPERTY mn35vta mf mf 0
TRACE PROPERTY mn35vta m m 0
TRACE PROPERTY mp35vta w w 0
TRACE PROPERTY mp35vta l l 0
TRACE PROPERTY mp35vta mf mf 0
TRACE PROPERTY mp35vta m m 0
TRACE PROPERTY mn40vta2 w w 0
TRACE PROPERTY mn40vta2 l l 0
TRACE PROPERTY mn40vta2 mf mf 0
TRACE PROPERTY mn40vta2 m m 0
TRACE PROPERTY mn60vta2 w w 0
TRACE PROPERTY mn60vta2 l l 0
TRACE PROPERTY mn60vta2 mf mf 0
TRACE PROPERTY mn60vta2 m m 0
TRACE PROPERTY mp40vta w w 0
TRACE PROPERTY mp40vta l l 0
TRACE PROPERTY mp40vta mf mf 0
TRACE PROPERTY mp40vta m m 0
TRACE PROPERTY mp60vta w w 0
TRACE PROPERTY mp60vta l l 0
TRACE PROPERTY mp60vta mf mf 0
TRACE PROPERTY mp60vta m m 0
TRACE PROPERTY esd_qlp_7v_9v_sp_nw_3t w w 0
TRACE PROPERTY esd_qlp_7v_9v_sp_nw_3t mf mf 0
TRACE PROPERTY esd_qlp_7v_9v_sp_nw_3t area_1 area_1 0
TRACE PROPERTY esd_qlp_7v_9v_sp_nw_3t hnw_area hnw_area 0
TRACE PROPERTY esd_qlp_7v_9v_sp_nw_3t m m 0
TRACE PROPERTY esd_qlp_10v_sp_nw_3t w w 0
TRACE PROPERTY esd_qlp_10v_sp_nw_3t mf mf 0
TRACE PROPERTY esd_qlp_10v_sp_nw_3t area_1 area_1 0
TRACE PROPERTY esd_qlp_10v_sp_nw_3t nw_area nw_area 0
TRACE PROPERTY esd_qlp_10v_sp_nw_3t m m 0
TRACE PROPERTY esd_qlp_18v_23v_sp_nw_sp_hn_2s_3t w w 0
TRACE PROPERTY esd_qlp_18v_23v_sp_nw_sp_hn_2s_3t mf mf 0
TRACE PROPERTY esd_qlp_18v_23v_sp_nw_sp_hn_2s_3t area_1 area_1 0
TRACE PROPERTY esd_qlp_18v_23v_sp_nw_sp_hn_2s_3t hnw1_area hnw1_area 0
TRACE PROPERTY esd_qlp_18v_23v_sp_nw_sp_hn_2s_3t hnw2_area hnw2_area 0
TRACE PROPERTY esd_qlp_18v_23v_sp_nw_sp_hn_2s_3t m m 0
TRACE PROPERTY esd_qlp_23v_sp_hn_2s_3t w w 0
TRACE PROPERTY esd_qlp_23v_sp_hn_2s_3t mf mf 0
TRACE PROPERTY esd_qlp_23v_sp_hn_2s_3t area_1 area_1 0
TRACE PROPERTY esd_qlp_23v_sp_hn_2s_3t hnw_area hnw_area 0
TRACE PROPERTY esd_qlp_23v_sp_hn_2s_3t m m 0
TRACE PROPERTY esd_qlp_30v_sp_nw_3s_3t w w 0
TRACE PROPERTY esd_qlp_30v_sp_nw_3s_3t mf mf 0
TRACE PROPERTY esd_qlp_30v_sp_nw_3s_3t m m 0
TRACE PROPERTY esd_qlp_35v_sp_hn_2s_3t w w 0
TRACE PROPERTY esd_qlp_35v_sp_hn_2s_3t mf mf 0
TRACE PROPERTY esd_qlp_35v_sp_hn_2s_3t area_1 area_1 0
TRACE PROPERTY esd_qlp_35v_sp_hn_2s_3t hnw_area hnw_area 0
TRACE PROPERTY esd_qlp_35v_sp_hn_2s_3t m m 0
TRACE PROPERTY esd_qlp_40v_sp_nw_1s_sp_hn_2s_3t w w 0
TRACE PROPERTY esd_qlp_40v_sp_nw_1s_sp_hn_2s_3t mf mf 0
TRACE PROPERTY esd_qlp_40v_sp_nw_1s_sp_hn_2s_3t m m 0
TRACE PROPERTY esd_qlp_40v_hn_ptm_1s_3t w w 0
TRACE PROPERTY esd_qlp_40v_hn_ptm_1s_3t mf mf 0
TRACE PROPERTY esd_qlp_40v_hn_ptm_1s_3t m m 0
TRACE PROPERTY esd_qlp_60v_sp_nw_1s_sp_hn_3s_3t w w 0
TRACE PROPERTY esd_qlp_60v_sp_nw_1s_sp_hn_3s_3t mf mf 0
TRACE PROPERTY esd_qlp_60v_sp_nw_1s_sp_hn_3s_3t m m 0
TRACE PROPERTY esd_qlp_60v_hn_ptm_1s_3t w w 0
TRACE PROPERTY esd_qlp_60v_hn_ptm_1s_3t mf mf 0
TRACE PROPERTY esd_qlp_60v_hn_ptm_1s_3t m m 0
CELL COMPARISON RESULTS ( TOP LEVEL )
# # INCORRECT #
Error: Different numbers of nets (see below).
Error: Different numbers of instances (see below).
LAYOUT CELL NAME: model2_temp
SOURCE CELL NAME: model2_temp
INITIAL NUMBERS OF OBJECTS
Layout Source Component Type
Ports: 5 5
Nets: 60 18 *
Instances: 156 15 * M (4 pins)
5 5 mp5_hn (5 pins)
4 4 mn60vta2 (4 pins)
4 4 mp60vta (4 pins)
1 1 Q (3 pins)
5 2 * R (2 pins)
1 1 dz_10x1_pzp (3 pins)
Total Inst: 176 32
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports: 5 5
Nets: 57 18 *
Instances: 46 15 * M (4 pins)
2 2 mp5_hn (5 pins)
1 1 mn60vta2 (4 pins)
2 2 mp60vta (4 pins)
1 1 Q (3 pins)
2 2 R (2 pins)
Total Inst: 55 24
* = Number of objects in layout different from number in source.
INCORRECT OBJECTS
LEGEND:
ne = Naming Error (same layout name found in source
circuit, but object was matched otherwise).
INCORRECT NETS
DISC# LAYOUT NAME SOURCE NAME
1 Net VEN VEN
--- 7 Connections On This Net --- --- 3 Connections On This Net ---
X180/X1/M0(414.940,-127.630):d ** missing connection **
X179/X1/M0(414.940,-130.530):d ** missing connection **
X179/X0/M0(408.120,-130.530):d ** missing connection **
X177/X1/M0(401.300,-130.530):d ** missing connection **
2 Net 6 net120
--- 13 Connections On This Net --- --- 5 Connections On This Net ---
X180/X0/M0(408.120,-127.630):d ** missing connection **
X178/X0/M0(394.480,-127.630):d ** missing connection **
X177/X0/M0(394.480,-130.530):d ** missing connection **
X176/M0(421.760,-127.630):d ** missing connection **
X180/X1/M0(414.940,-127.630):g ** missing connection **
X179/X1/M0(414.940,-130.530):g ** missing connection **
X179/X0/M0(408.120,-130.530):g ** missing connection **
X177/X1/M0(401.300,-130.530):g ** missing connection **
3 Net 4 net125
--- 23 Connections On This Net --- --- 7 Connections On This Net ---
X166/X0/M0(436.920,-127.630):g ** missing connection **
X165/X0/M0(436.920,-130.530):g ** missing connection **
X164/X1/M0(376.280,-127.630):g ** missing connection **
X166/X1/M0(446.780,-127.630):d ** missing connection **
X166/X1/M0(446.780,-127.630):g ** missing connection **
X165/X1/M0(446.780,-130.530):d ** missing connection **
X165/X1/M0(446.780,-130.530):g ** missing connection **
X164/X0/M0(366.420,-127.630):d ** missing connection **
X173/M0(428.580,-127.630):g ** missing connection **
X172/M0(428.580,-130.530):g ** missing connection **
X171/M0(386.140,-127.630):g ** missing connection **
X170/M0(386.140,-130.530):g ** missing connection **
X180/X0/M0(408.120,-127.630):g ** missing connection **
X178/X0/M0(394.480,-127.630):g ** missing connection **
X177/X0/M0(394.480,-130.530):g ** missing connection **
X176/M0(421.760,-127.630):g ** missing connection **
4 Net 1 net126
--- 24 Connections On This Net --- --- 13 Connections On This Net ---
X166/X0/M0(436.920,-127.630):s ** missing connection **
X165/X0/M0(436.920,-130.530):s ** missing connection **
X164/X1/M0(376.280,-127.630):s ** missing connection **
X166/X1/M0(446.780,-127.630):s ** missing connection **
X165/X1/M0(446.780,-130.530):s ** missing connection **
X173/M0(428.580,-127.630):s ** missing connection **
X172/M0(428.580,-130.530):s ** missing connection **
X171/M0(386.140,-127.630):s ** missing connection **
X170/M0(386.140,-130.530):s ** missing connection **
X180/X0/M0(408.120,-127.630):s ** missing connection **
X178/X0/M0(394.480,-127.630):s ** missing connection **
X177/X0/M0(394.480,-130.530):s ** missing connection **
X176/M0(421.760,-127.630):s ** missing connection **
X180/X1/M0(414.940,-127.630):s ** missing connection **
X179/X1/M0(414.940,-130.530):s ** missing connection **
X179/X0/M0(408.120,-130.530):s ** missing connection **
X177/X1/M0(401.300,-130.530):s ** missing connection **
** missing connection ** MPM15:b
** missing connection ** MPM17:b
** missing connection ** MPM19:b
** missing connection ** MPM20:b
** missing connection ** MPM21:b
** missing connection ** MPM26:b
5 Net 17 net113
--- 13 Connections On This Net --- --- 3 Connections On This Net ---
X166/X0/M0(436.920,-127.630):d ** missing connection **
X165/X0/M0(436.920,-130.530):d ** missing connection **
X164/X1/M0(376.280,-127.630):d ** missing connection **
X161/X1/X1/M0(445.320,-146.215):g ** unmatched connection **
X161/X1/X0/M0(441.540,-146.215):g ** unmatched connection **
X161/X0/X1/M0(437.760,-146.215):g ** unmatched connection **
X161/X0/X0/M0(433.980,-146.215):g ** unmatched connection **
X160/X1/X1/M0(430.200,-146.215):g ** unmatched connection **
X160/X1/X0/M0(426.420,-146.215):g ** unmatched connection **
X160/X0/X1/M0(422.640,-146.215):g ** unmatched connection **
X160/X0/X0/M0(418.860,-146.215):g ** unmatched connection **
** unmatched connection ** MPM13:g
6 Net 14 net115
--- 11 Connections On This Net --- --- 4 Connections On This Net ---
X162/X1/X1/M0(460.440,-146.215):g ** unmatched connection **
X162/X1/X0/M0(456.660,-146.215):g ** unmatched connection **
X162/X0/X1/M0(452.880,-146.215):g ** unmatched connection **
X162/X0/X0/M0(449.100,-146.215):g ** unmatched connection **
X159/X1/X1/M0(415.080,-146.215):g ** unmatched connection **
X159/X1/X0/M0(411.300,-146.215):g ** unmatched connection **
X159/X0/X1/M0(407.520,-146.215):g ** unmatched connection **
X159/X0/X0/M0(403.740,-146.215):g ** unmatched connection **
** unmatched connection ** MPM14:g
7 Net 22 ** no similar net **
8 Net 18 ** no similar net **
9 Net 15 ** no similar net **
10 Net 16 ** no similar net **
11 Net X159/X0/X0/5 ** no similar net **
12 Net X159/X0/X1/5 ** no similar net **
13 Net X159/X1/X0/5 ** no similar net **
14 Net X159/X1/X1/5 ** no similar net **
15 Net X160/X0/X0/5 ** no similar net **
16 Net X160/X0/X1/5 ** no similar net **
17 Net X160/X1/X0/5 ** no similar net **
18 Net X160/X1/X1/5 ** no similar net **
19 Net X161/X0/X0/5 ** no similar net **
20 Net X161/X0/X1/5 ** no similar net **
21 Net X161/X1/X0/5 ** no similar net **
22 Net X161/X1/X1/5 ** no similar net **
23 Net X162/X0/X0/5 ** no similar net **
24 Net X162/X0/X1/5 ** no similar net **
25 Net X162/X1/X0/5 ** no similar net **
26 Net X162/X1/X1/5 ** no similar net **
27 Net X163/X0/5 ** no similar net **
28 Net X163/X1/5 ** no similar net **
29 Net X164/X0/5 ** no similar net **
30 Net X164/X1/5 ** no similar net **
31 Net X165/X0/5 ** no similar net **
32 Net X165/X1/5 ** no similar net **
33 Net X166/X0/5 ** no similar net **
34 Net X166/X1/5 ** no similar net **
35 Net X170/5 ** no similar net **
36 Net X171/5 ** no similar net **
37 Net X172/5 ** no similar net **
38 Net X173/5 ** no similar net **
39 Net X175/5 ** no similar net **
40 Net X176/5 ** no similar net **
41 Net X177/X0/5 ** no similar net **
42 Net X177/X1/5 ** no similar net **
43 Net X178/X0/5 ** no similar net **
44 Net X178/X1/5 ** no similar net **
45 Net X179/X0/5 ** no similar net **
46 Net X179/X1/5 ** no similar net **
47 Net X180/X0/5 ** no similar net **
48 Net X180/X1/5 ** no similar net **
49 ** no similar net ** net119
50 ** no similar net ** net116
PROPERTY ERRORS
DISC# LAYOUT SOURCE ERROR
51 X178/X1/M0(401.300,-127.630) M(mp5) MPM15 M(mp5)
w: 3 u w: 15 u 80%
52 X175/M0(421.760,-130.530) M(mp5) MPM26 M(mp5)
w: 3 u w: 15 u 80%
53 X163/X0/M0(366.420,-130.530) M(mp5) MPM20 M(mp5)
w: 5 u w: 20 u 75%
54 X164/X0/M0(366.420,-127.630) M(mp5) MPM21 M(mp5)
w: 5 u w: 16 u 68.8%
55 X163/X1/M0(376.280,-130.530) M(mp5) MPM17 M(mp5)
w: 5 u w: 20 u 75%
INFORMATION AND WARNINGS
Matched Matched Unmatched Unmatched Component
Layout Source Layout Source Type
Ports: 5 5 0 0
Nets: 15 15 42 3
Instances: 7 7 0 0 M(mn5)
6 6 33 2 M(mp5)
2 2 0 0 mp5_hn
1 1 0 0 mn60vta2
2 2 0 0 mp60vta
1 1 0 0 Q(qvpp_5x5)
2 2 0 0 R(rnwell_sti_2t)
1 1 0 0 dz_10x1_pzp
Total Inst: 22 22 33 2
o Statistics:
152 layout mos transistors were reduced to 34.
118 mos transistors were deleted by parallel reduction.
12 source mos transistors were reduced to 4.
4 series layout resistors were reduced to 1. 3 connecting nets were deleted.
o Initial Correspondence Points:
Ports: VCC GND V2 V1 VEN
DETAILED INSTANCE CONNECTIONS
(This section contains detailed information about connections of
matched instances that are involved in net discrepancies).
g: 6 g: net120
s: 1 s: net126
d: VEN d: VEN
b: X178/X1/5 ** no similar net **
** 1 ** b: net126
g: 4 g: net125
s: 1 s: net126
d: 6 d: net120
b: X175/5 ** no similar net **
** 1 ** b: net126
g: 4 g: net125
s: 1 s: net126
d: 4 d: net125
b: X163/X0/5 ** no similar net **
** 1 ** b: net126
g: 4 g: net125
s: 1 s: net126
d: 4 ** net125 **
b: X164/X0/5 ** no similar net **
** no similar net ** d: net118
** 1 ** b: net126
g: 4 g: net125
s: 1 s: net126
d: 17 d: net113
b: X163/X1/5 ** no similar net **
** 1 ** b: net126
M5(358.840,-148.440) M(mp5) MPM19 M(mp5)
g: 4 g: net125
s: 1 s: net126
d: 14 d: net115
b: 22 ** no similar net **
** 1 ** b: net126
UNMATCHED OBJECTS
LAYOUT SOURCE
X177/X1/M0(401.300,-130.530) M(mp5) ** unmatched instance **
X179/X0/M0(408.120,-130.530) M(mp5) ** unmatched instance **
X179/X1/M0(414.940,-130.530) M(mp5) ** unmatched instance **
X180/X1/M0(414.940,-127.630) M(mp5) ** unmatched instance **
X176/M0(421.760,-127.630) M(mp5) ** unmatched instance **
X177/X0/M0(394.480,-130.530) M(mp5) ** unmatched instance **
X178/X0/M0(394.480,-127.630) M(mp5) ** unmatched instance **
X180/X0/M0(408.120,-127.630) M(mp5) ** unmatched instance **
X170/M0(386.140,-130.530) M(mp5) ** unmatched instance **
X171/M0(386.140,-127.630) M(mp5) ** unmatched instance **
X172/M0(428.580,-130.530) M(mp5) ** unmatched instance **
X173/M0(428.580,-127.630) M(mp5) ** unmatched instance **
X165/X1/M0(446.780,-130.530) M(mp5) ** unmatched instance **
X166/X1/M0(446.780,-127.630) M(mp5) ** unmatched instance **
X164/X1/M0(376.280,-127.630) M(mp5) ** unmatched instance **
X165/X0/M0(436.920,-130.530) M(mp5) ** unmatched instance **
X166/X0/M0(436.920,-127.630) M(mp5) ** unmatched instance **
X159/X0/X0/M0(403.740,-146.215) M(mp5) ** unmatched instance **
X159/X0/X1/M0(407.520,-146.215) M(mp5) ** unmatched instance **
X159/X1/X0/M0(411.300,-146.215) M(mp5) ** unmatched instance **
X159/X1/X1/M0(415.080,-146.215) M(mp5) ** unmatched instance **
X162/X0/X0/M0(449.100,-146.215) M(mp5) ** unmatched instance **
X162/X0/X1/M0(452.880,-146.215) M(mp5) ** unmatched instance **
X162/X1/X0/M0(456.660,-146.215) M(mp5) ** unmatched instance **
X162/X1/X1/M0(460.440,-146.215) M(mp5) ** unmatched instance **
X160/X0/X0/M0(418.860,-146.215) M(mp5) ** unmatched instance **
X160/X0/X1/M0(422.640,-146.215) M(mp5) ** unmatched instance **
X160/X1/X0/M0(426.420,-146.215) M(mp5) ** unmatched instance **
X160/X1/X1/M0(430.200,-146.215) M(mp5) ** unmatched instance **
X161/X0/X0/M0(433.980,-146.215) M(mp5) ** unmatched instance **
X161/X0/X1/M0(437.760,-146.215) M(mp5) ** unmatched instance **
X161/X1/X0/M0(441.540,-146.215) M(mp5) ** unmatched instance **
X161/X1/X1/M0(445.320,-146.215) M(mp5) ** unmatched instance **
** unmatched instance ** MPM14 M(mp5)
** unmatched instance ** MPM13 M(mp5)
SUMMARY
Total CPU Time: 0 sec
Total Elapsed Time: 0 sec
