查看: 14942|回复: 197
[SOS]拜求个vc_static_vw-2024
发表于 2025-5-7 18:59:16 | 显示全部楼层 |阅读模式
小弟在此恳求各位乡亲父老兄弟姊妹们分享个vc_static_vw-2024.09-sp2 or sp1,
感激不尽!m( _ _ )m
Updated on May 13, 2025
看来也只有自己能回覆自己了,人心呐...
如果看到这篇更新,希望您是经过我同意才下载,并请勿用于一切商业与非法行为。
另寻24年或25年的Oasys-RTL以及rtl_arch_vW-2024.09-SP3
游客 ,如果您要查看本帖隐藏内容请回复
标题是:[SOS]拜求个vc_static_vw-2024
@ql_cat 请问这标题让人上什么当?为的是让要分享的您点进来上当?
若不是这样,您有这侠肠怎不见你在4~5楼表达些什么?
这篇发文沉到海底怎也不见你来发个回覆浮上水面?
您要不到糖就吵?
Updated on May 21, 2025
我啥时说我侠肠来着??倒是你还没回答我这标题是怎么骗你进来上当??你并未分享给我呀!到底上什么当??
标题不改是...犯法了??我确实在求档呀。
另外..."希望您是经过我同意才下载"...你没看见是吗??
何况就这么个工具而已,你已经搞到了,也能好心提醒他人,怎不分享出来??
点评
钓鱼贴主先喊别人一口一个“侠肠”,别人回敬你你听着不舒服,这就崩不住了?  发表于 2025-5-28 18:41
搞笑,钓鱼贴主还来劲了。我的渠道要求不扩散,当然照做。做人得有起码的诚信!!  发表于 2025-5-28 18:36
我在楼里好心提醒他人,下载分享已经结束,不要回帖了。你有侠肠,怎么不去改主贴,而是继续让大家回你的空贴?  发表于 2025-5-20 19:28
你结束分享应该在主贴里告知大家,而不是浪费大家的时间继续回你的贴。就这么个工具而已,我已经搞到,也不用在这下载。  发表于 2025-5-20 19:23
你发的贴我当时没看到,后来有人顶上来才发现,这也能怨别人?你的下载链接就是个图片,回帖也看不到链接。这不是骗回帖是什么?  发表于 2025-5-20 19:19
发表于 2025-5-8 14:22:37 | 显示全部楼层
同求
发表于 2025-5-8 16:03:52 | 显示全部楼层
确实没有,如果有肯定会分享。
点评
好的,感谢。  发表于 2025-5-8 18:50
发表于 2025-5-8 21:48:20 | 显示全部楼层
May I ask why you specifically need vc_static_vw-2024.09-sp2?
The file is quite large, so uploading it takes a significant amount of time.
Also, even if I share it, some additional setup or configuration is required to make it work properly.
Do you know how to do that? If not, the time spent uploading it may be wasted.
Sharing the method for getting it to work also requires a more compelling reason.
You already have a previous version, don’t you? It didn’t seem that outdated.
Unlike physical design tools where foundry models frequently change, logical design work usually doesn’t require the very latest version—so unless there’s a strong justification, the effort and time I put into uploading it won’t be meaningful.
4o
 楼主| 发表于 2025-5-8 22:31:28 | 显示全部楼层
The file is quite large, so upload ...
Thank you for your reply.
I don't think I need to specially create astory just to satisfy your question. Just like the things you needed, I alsospent time searching, downloading, and uploading them. However, I don't need toknow what you intend to do with them—I just hope you don't use them for profitor illegal activities.
Lastly, if you're not willing, I don't wantto force you to do something you don't want to do. Once again, thank you foryour reply.
发表于 2025-5-9 11:31:45 | 显示全部楼层
搭车寻 $家 S M S和YA tool
发表于 2025-5-13 22:53:26 | 显示全部楼层
感谢大好人分享!这个【另寻24年或25年的Oasys-RTL以及rtl_arch_vW-2024.09-SP3】确实没有,rtl_arch只有23版的。另外,从您这里下载的都是压缩包,解压密码可以私发一下吗?非常感谢!
发表于 2025-5-13 22:58:01 | 显示全部楼层
感谢分享
发表于 2025-5-13 23:05:22 | 显示全部楼层
hummmm....
发表于 2025-5-13 23:10:48 | 显示全部楼层
只有一个23版的
GMT+8, 2025-12-18 08:47 , Processed in 0.023570 second(s), 5 queries , Gzip On, Redis On.
